2022 Tundra TRD factory lift kit upgrade…. Any updates on when this will be available?
Discussion in '3rd Gen Tundras (2022+)' started by Sgakusa, Jul 23, 2022.
  1. Oct 10, 2022 at 10:46 PM
    #91
    havasubud
    havasubud Owner ESP Truck Accessories Vendor
    Earl
    Corona, California
    2022 Tundra CrewMax Limited TRD OR 4x4
    Factory Tube Steps, TraiFX tri fold tonneau cover
    1. Any Toyota part or accessory is warrantied for one year unlimited mileage. If the accessory is purchased as part of the original purchase agreement, then it is covered under the 3/36 warranty. This comes from 23 years in Toyota Service.
    2. Correct you couldn't buy it as late as July, so you wouldn't have been able to include it to your purchase. So this would make it one year on the warranty.
  2. Oct 10, 2022 at 11:07 PM
    #92
    havasubud
    Earl
    Corona, California
    Here is the one I did. The sway bar is installed the same way as the one shown above.
    ryanwgregg and Yaboy like this.
  3. Oct 10, 2022 at 11:22 PM
    #93
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Did the first one at work. Not a fan of the sway bar decision they made. But it does drive nice. 275/65r20, programmed PCs and all that jazz just fine.
    [​IMG] [​IMG]
    I’ll be keeping my first gen though after seeing the price. Oof
    ryanwgregg likes this.
  4. Oct 10, 2022 at 11:46 PM
    #94
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    How long did it take?
  5. Oct 10, 2022 at 11:49 PM
    #95
    bigjuice
    WA State
    2024 Terra TRD Pro
    same question…how long did the install take?
    …and does it look like the Pro Sway bar and end links may change the situation (I.E fit on this non pro one with the lift kit?)
  6. Oct 11, 2022 at 12:26 AM
    #96
    empty_lord
    05 rollover special
    Haven’t had a pro yet to look at. Install took a full day. ~8hrs. (To be fair, had to setup the new strut compressor which took a bit of time)
    ryanwgregg, bigjuice[QUOTED] and Kap1 like this.
  7. Oct 11, 2022 at 3:00 AM
    #97
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    I see you removed the driving lights, could you have left those in at the customer's request?
  8. Oct 11, 2022 at 7:59 AM
    #98
    empty_lord
    05 rollover special
    I would personally. This trucks getting sold with all this. Legally we have to remove them in Indiana
  9. Oct 11, 2022 at 12:53 PM
    #99
    Chikwaters
    Chikwaters New Member
    Hawaii
    2023 Tundra TRD Pro, 2010 FJ Cruiser, 1989 Land Cruiser
    I wonder how these compare to the TRD Pro’s stock Fox suspensions as far as ride quality. Toyota should’ve just offered a 3” Fox option instead of just having the 1” that comes with the Pros. It would’ve saved me the extra headache.
  10. Oct 11, 2022 at 1:08 PM
    #100
    empty_lord
    05 rollover special
    I find it drives well. No idea how the pro drives yet. Still stock rear springs. So I’m sure the pro is fairly soft feeling in the back compared to the TRD lift
    Chikwaters[QUOTED] likes this.
  11. Oct 11, 2022 at 5:40 PM
    #101
    havasubud
    Earl
    Corona, California
    It took about 7 hours, but we were doing a video at the same time, and it was the first one. It will go a lot quicker next time. Had to take it to get aligned afterwards. Only charged the customer $1149 for labor including the alignment, but would probably charge $1500 on the next one plus $149 for an alignment.
    bigjuice[QUOTED] and t300 like this.
  12. Oct 22, 2022 at 4:27 AM
    #102
    Pilotjoe123
    Pilotjoe123 New Member
    Joe
    2019 Tundra Sport red
    throw the swayer in the trash
  13. Apr 1, 2023 at 6:45 AM
    #103
    Cdunner
    Cdunner New Member
    2023 White Sequoia SR5 TRD Off-road
    Does anyone know if the front lift is built into the trd shock or the trd spring or both? Looking to piece together my own kit like I did with my 4runner, it worked out very well. I ran 5100s front and back, toytec front springs, UCAs, and a 1” rear spacer. Im only looking for a 2” front lift (level) and Firestone airbags in the rear (.5” ish lift and keep me level under tow). I would rather avoid spacers and the need for UCAs this time. Steering towards the trd lift kit front bilstein shocks on oem springs and the Firestone bags in the rear. I haven’t ran across any aftermarket stiffer springs yet so it would be a bit different than my 4runner setup. Any solid insight would be appreciated but I know I may be making my own finds on this one.
  14. Apr 2, 2023 at 3:27 PM
    #104
    bigjuice
    WA State
    2024 Terra TRD Pro
    Both I think is the answer you are look for if I recall correctly. FF and watch from 3:30 of this video and I think it will answer your question.
    A lot of folks in your situation are seemingly going with Dobinson rear springs (you can get them in 3 different stiffness) and it has the 2” rear lift built in.
    https://www.dobinsonsdirect.com/pages/product-result?rq=mk_toyota~md_tundra~yr_2022-on
    https://youtu.be/Pg_45Pz80KA
    Cdunner[QUOTED] and 4mm like this.
  15. Apr 2, 2023 at 8:50 PM
    #105
    Cdunner
    Cdunner New Member
    There’s definitely a difference in overall height in the video but it’s hard to tell where the spring seat is at. Thanks for the help!
  16. Apr 3, 2023 at 4:45 AM
    #106
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    The TRD lift is from the springs and rear block not the shocks. I know what you’re saying with 5100 OEM springs raised, I had that on my Tacoma. The TRD lift front shock doesn’t have an adjustable ring it’s a 3” spring. You can just buy front assembled shocks and the rear airbags to achieve what you want and Dobinsons 2” front would be nice or one with an adjustable coil, you don’t need a UCA unless you want to buy one or you are 3+” lift.
  17. Apr 3, 2023 at 4:57 AM
    #107
    Cdunner
    Cdunner New Member
    Hmm take a look at the pic I attached. Thanks for the info on the other options. I appreciate it.
  18. Apr 3, 2023 at 6:40 AM
    #108
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    I see it, you could level it with the shocks.
  19. Apr 3, 2023 at 6:44 AM
    #109
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Yep it’s a Mickey Mouse setup
  20. Apr 3, 2023 at 7:47 AM
    #110
    Cdunner
    Cdunner New Member
    Maybe, possibly. But… no different than adjusting 5100s. I’m willing to try it and come back with results good or bad.
  21. Apr 3, 2023 at 7:58 AM
    #111
    Cdunner
    Cdunner New Member
    Yes agreed but does that make it completely incompatible no. You’re assuming. You cant say NO unless you try, right??
  22. Apr 3, 2023 at 8:32 AM
    #112
    Cdunner
    Cdunner New Member
    Ok bilstein engineer.
