2022 Tundra TRD factory lift kit upgrade…. Any updates on when this will be available?
Discussion in '3rd Gen Tundras (2022+)' started by Sgakusa, Jul 23, 2022.
  1. Sep 22, 2022 at 9:55 AM
    #61
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
    Yeah, I did notice that and saw the template but it said engine cover. I guess you’re right because it is shaped like the plastic OEM plate that it came with.
    I agree with the conflicts section too.
  2. Sep 22, 2022 at 9:59 AM
    #62
    Dmon187
    Dmon187 New Member
    DFW
  3. Sep 22, 2022 at 10:40 AM
    #63
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Well this blows as I have the TRD skids also…guess I will need to wait to see how this gets figured out.
    I wonder…”Will other aftermarket skids have this issue?”
  4. Sep 22, 2022 at 11:00 AM
    #64
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Would longer endlinks work better than sway bar drop down brackets?
    If longer endlinks to the control arms works then you could leave the sway bar mounted in its stock location….in theory.
    I’m not sure if the endlinks need to stay at its stock length for suspension geometry/functionality. But I’m assuming it’ll work just fine.
  5. Sep 22, 2022 at 11:15 AM
    #65
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    It's hard to tell just by the pics: It looks like the sway is relocated forward and not just dropped.
    But, yes...you're 100% correct, if the location remains the same then longer sway bar links should work. It would be nice to see an aftermarket option (like JKS) that offers adjustable sway bar links with quick disconnects.
  6. Sep 22, 2022 at 12:54 PM
    #66
    Dmon187
    Dmon187 New Member
    DFW
    Where did you find this photo? I’m about to take it back up there
  7. Sep 22, 2022 at 1:03 PM
    #67
    Dmon187
    Dmon187 New Member
    DFW
    I just sent them the pictures and they told
    Me to bring it in the morning. I knew something was off. I appreciate it. It was their first install so that is probably it. Gotta love this forum.
    mmasse and ryanwgregg like this.
  8. Sep 22, 2022 at 1:13 PM
    #68
    KroppDuster
    Bilstein 5100s
    Kudos to you, sir. That's some hardnose investigative skills right there. I wish I was near my truck to confirm, but based on your photos I'd say you are 100% correct. My bad for just assuming the dealership installed this correctly. lol.
    ryanwgregg and Dmon187 like this.
  9. Sep 22, 2022 at 1:17 PM
    #69
    Dmon187
    Dmon187 New Member
    DFW
    74CD7046-BC10-41F3-BEAD-04353EBED580.jpg Definitely installed incorrectly
    Yaboy and ryanwgregg like this.
  10. Sep 22, 2022 at 2:15 PM
    #70
    KroppDuster
    Bilstein 5100s
    You know...I cannot wait to hear what the final resolution is. In looking at the new bracket from the instructions, it looks like this might actually be installed correctly. It drops the swap bar quite a bit.
    The red circle is the original sway bar mounting point (or very near it). The purple area is the new block that gets installed and drops the sway bar. It looks like on the SEMA build, the sway bar is in the factory location...for whatever reason. I know the SEMA build was still considered a prototype at that point.
    Dmon187 likes this.
  11. Sep 22, 2022 at 2:48 PM
    #71
    Dark
    Dark New Member
    Nope!
  12. Sep 22, 2022 at 4:04 PM
    #72
    Dmon187
    Dmon187 New Member
    DFW
    @Dark would you take a photo of the front end to see what your bar looks like?
    ryanwgregg likes this.
  13. Sep 22, 2022 at 5:01 PM
    #73
    KroppDuster
    Bilstein 5100s
    It might be installed upside down, but even if it was flipped....I don't there would be enough clearance to above the skid plate. But, again...I'm super curious how this turns out.
  14. Sep 22, 2022 at 5:28 PM
    #74
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    The angle of that Sway bar end link on the SEMA build.. Probably why they added the sway bar spacer afterwards for retail kits.
    Much better here. Looks like it installed correctly to me. Can you even take the TRD skid plate off without removing sway bar to do Oil changes? :rofl:
    ryanwgregg, Yaboy and Dmon187[QUOTED] like this.
  15. Sep 22, 2022 at 5:59 PM
    #75
    Dark
    Dark New Member
    Looks like yours! Gonna check with the dealer tomorrow!
  16. Sep 22, 2022 at 6:05 PM
    #76
    Dmon187
    Dmon187 New Member
    DFW
    You can remove it it’s just a pain in the ass in sure. It’s pretty ridiculous if it is installed correctly honestly I’m gonna be pissed
  17. Sep 23, 2022 at 9:31 AM
    #77
    Dmon187
    Dmon187 New Member
    DFW
    I spoke to the Master tech that did the install and we had the truck on the lift. Went through the instructions and showed me how it was installed. It looks right per the installation. He said the photo from the press release was more of a prototype because it showed the sway bar in the same location as the stock bar. The instructions also mention to cut the OEM plastic skid plate. He’s going to modify the TRD one so it does not rub. Long story short it is not really compatible with the TRD skid plate.
    ryanwgregg and jgoliath like this.
  18. Sep 23, 2022 at 9:36 AM
    #78
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    I don’t think any skid plate is going to be compatible with the Trd lift/sway bar drop at the moment. Sway bar is going to drop lower than my RCI skid plate from what I see
    ryanwgregg and Dmon187[QUOTED] like this.
  19. Sep 23, 2022 at 10:07 AM
    #79
    jgoliath
    Maybe that’s why it’s “incompatible” with the pro. The pro comes with the skid plate lol.
  20. Sep 23, 2022 at 10:07 AM
    #80
    Dmon187
    Dmon187 New Member
    DFW
    Disappointing for sure
  21. Sep 23, 2022 at 10:15 AM
    #81
    KroppDuster
    Bilstein 5100s
    Yeah. It's a real bummer. Mainly because most of us thought (right or wrong) that Toyota Engineering would've really put more thought into this. Even though I'm going with an Icon build instead of this OE kit, I still still high hopes for this.
    Granted, I'm no engineer...but from my perspective the simple solution would've been to just include longer sway bar links instead of dropping the bar so far.
    Dmon187 and ryanwgregg like this.
  22. Sep 23, 2022 at 10:18 AM
    #82
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    I recall seeing a video of off-road shop putting a combo of TRD Lift with After Market and one of the things they called out as crap is the sway bar spacers. They tossed them aside and were going with or making their own. Can't seem to find this said video now. :(
  23. Sep 23, 2022 at 10:21 AM
    #83
    jgoliath
    It looks like the spacer drops it down to about parallel with where I put that white line. So right in line with the RCI skid for a ton of interference.
    the replacement sway bar ends that come with the kit also don’t look any longer than stock
    Dmon187 likes this.
  24. Sep 23, 2022 at 11:14 AM
    #84
    Dark
    Dark New Member
    Got mine in the shop as well. I'll let you know what they say!
    Dmon187[QUOTED] likes this.
  25. Sep 23, 2022 at 11:15 AM
    #85
    Dmon187
    Dmon187 New Member
    DFW
    Watch the. Say something completely different lol
  26. Sep 23, 2022 at 11:39 AM
    #86
    Dark
    Dark New Member
    Well I'm travelling next week so I'm going to drop it off Sunday. I'll get it back when I return Friday. They are actually going to flip it and see if it works. If it doesn't, I bought some 2.25in spacers that should be able to help with clearance.
  27. Sep 23, 2022 at 1:22 PM
    #87
    Sparky916
    Sparky916 New Member
    Blake
    22 Lunar Rock Limited TRD OF
    I have called every Toyota dealer in my area, 3 so far, to get a quote for instal, gave the part number, and the responses I’ve got is that they can’t order the kit or they don’t do that type of work… so frustrating.
  28. Sep 23, 2022 at 1:27 PM
    #88
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    A Toyota dealer service center that doesn’t install Toyota parts? :rofl:
  29. Sep 23, 2022 at 1:54 PM
    #89
    Sparky916
    Blake
    That’s what I said! Lmao I guess because it’s a suspension lift?? I got one more dealer looking into it, but pretty ridiculous.
  30. Sep 27, 2022 at 7:55 AM
    #90
    phdTundra
    phdTundra New Member
    2022 Tundra SR5
    Full Wrap, TRD Skid Plate, 34” wheels and Tires, wheel Flares, Running Boards,
    Did you get the kit yet?
