2022 Tundra Suplemental Transmission Cooler?
Discussion in '3rd Gen Tundras (2022+)' started by Bustedandrusted, Sep 16, 2022.
  1. May 20, 2024 at 6:28 PM
    #121
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    NOTE: pics are from the 13402 I initially installed which I removed and replaced with a 54K BTU unit 53482.
    The information for brackets is for the 53482. The width and depth of both are the same - the only difference is size is the height. Thus the top brackets are shorter. All connection points are the same. The Brackets are made from 1"x1"x.188 aluminum angle for corners, 1/8"x2" flat plate for legs. Bottom bracket(s) 2.5"x2.5", top bracket(s) 2"x 1-1/8". Uses 6.75' of transmission hose (kit came with 4'). Rubber isolators used between cooler/bracket attachment points. Clearance between cooler and condenser is approximately 1.5 inches. The cooler does not touch any surface(s) other than bracket connections. Diagrams posted further up in this thread will show you where to connect the system.
    SC_Mike, raylo, teab and 5 others like this.
  2. May 20, 2024 at 6:52 PM
    #122
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    :worthless:
    303Gen3[QUOTED] and ryanwgregg like this.
  3. May 21, 2024 at 12:55 PM
    #123
    303Gen3
    Golden Colorado
    teab, Black widow TRD and ryanwgregg like this.
  4. May 21, 2024 at 2:06 PM
    #124
    Black widow TRD
    Manuel
    :bowdown:
    I greatly appreciate you !! I know myself and several other members have been looking for a solution for an aux. cooler. I’m not comfortable with my daily temps that hit 220, but I’m running a JB4 Map 3 sometimes Map 6.
    How about how much additional Lubreguard did you have to use ?
    ryanwgregg likes this.
  5. May 21, 2024 at 2:59 PM
    #125
    303Gen3
    Golden Colorado
    the volume of the cooler was 10oz (Derale identifies the volume of their coolers) and the volume of the additional hose was a little less than 5 oz (.75 fluid oz per foot of 3/8 inch ID). Added 15 oz. Bought at NAPA rather than online.
  6. May 24, 2024 at 7:03 AM
    #126
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    My truck loaded up for off roading is heavy and on the trail climbing I’ve had my trans temp alert hit a couple times. I’ve found that running most trails in 2nd gear has solved the temp issue for now in my use case, but I’d be interested in a “how to” post with photos if you are up for it. Thanks for the info!
  7. Jun 7, 2024 at 6:05 PM
    #127
    303Gen3
    Golden Colorado
    Update#3:
    After a few weeks of general city driving (local streets 30 - 45 mph) with sitting at stop lights I have found the maximum transmission temp reached is 197 and the oil temp was 194. The transmission temp drops to 194 once moving. Pre install temps were 215ish. So I'd say the approach works - but a larger cooler would hopefully yield even cooler operating temps and will be my future investigations and possibly Fall season project.
    TacCoyote and teab like this.
  8. Jun 12, 2024 at 4:11 PM
    #128
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Just cruising.
    mayan and Bigphilski like this.
  9. Jun 13, 2024 at 5:02 AM
    #129
    dccrens
    dccrens New Member
    Leesburg, VA
    2024 Tundra I-Force Max Hybrid, Lunar Rockin!, 6.5 Bed
    2024 Limited, iForce Max hybrid, 6.5ft bed, TRD off-road package, TRD 20in wheels, TRD Grille, TRD skid plate, blacked-out badges, NYTOP Rear Recovery Points; Red, aFe Power Front Tow Hooks Red
    What app are you running to display?
    tesilential likes this.
  10. Jun 13, 2024 at 6:52 AM
    #130
    Bigphilski
    Bigphilski New Member
    24 Black limited TRD
    Yes, same here. Inquiring minds want to know.... @eddiefromcali
  11. Jun 13, 2024 at 7:13 AM
    #131
    eddiefromcali
    Eddie
    100% Stock
    Its the JB4 app via binize box. You need the JB4 tuner though
  12. Jun 13, 2024 at 7:33 AM
    #132
    303Gen3
    Golden Colorado
    Fully warmed up? Coolant temp was 194ish, or?
    Would like to see same for local city street (stop and go, sitting at stop lights) temps.
    Thanks for post, and the presentation app is amazing!
  13. Jun 13, 2024 at 7:38 AM
    #133
    eddiefromcali
    Eddie
    100% Stock
    This was after a 20 min 55-65mph drive in 92* ambient temps....fully warmed up. I got off the fwy and hit maybe 2-3 lights when I took the 201 pic. By the time I got home, I saw the 208...so it crept up a bit in city stop and go.
    1.75" lift, 275/60-20s stockish weight on oem wheels. I never saw these temps in my 05 Silverado with an in line Tru cool 40k...even in higher ambient temps (110-115*)
    App is the JB4 app from BMS.
  14. Jun 13, 2024 at 9:56 AM
    #134
    Black widow TRD
    Manuel
    Mine will hit 225, ambient temp 95. Map3 to 5, I get those temps.
  15. Jun 13, 2024 at 12:24 PM
    #135
    303Gen3
    Golden Colorado
    yep those temps would make you cringe. I'm 99% certain I am going to sell my Derale 13402 (likely talk my son-in-law into letting me put it on this Tacoma as a secondary to his oem tow cooler) and try the Hayden 679. I think the Hayden has better air flow for cooling purposes than the Derale. Highway temps for me - driving 65mph with no stop and go were sub 190 with the Derale in the Tundra. I have the Hayden running in series to my OEM Tow Cooler in my Gen3 Super Charged Tacoma and it never goes over 190 even towing over mountain passes.
  16. Jun 14, 2024 at 6:44 AM
    #136
    Dozer466
    Dozer466 New Member
    2022 Tundra TRD Pro
    Westcott 3/1, 37" Toyo's, Smartcap
    Is it recommended to use the Lubegard platinum and Toyota trans fluid when installing the cooler or just Toyota trans fluid? My trans temps run hot with normal driving and have seen up to 223. This was from yesterday, 10 mile drive at 65-70. Truck was already warm before leaving.
    mayan likes this.
  17. Jun 14, 2024 at 12:05 PM
    #137
    303Gen3
    Golden Colorado
    see post #109. I have used LG in the past in my Tacoma and asked them specifically about its' use in the Gen3 Tundra 10 spd transmission. Noted post has their official reply.
  18. Jun 15, 2024 at 5:49 AM
    #138
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Since these transmissions use WS aft. I had success using Amsoil SS blue cap ATF in my 2015 Tacoma. I wonder how it would work on the 10 speed.
  19. Jun 15, 2024 at 6:21 PM
    #139
    303Gen3
    Golden Colorado
    Another highway driving trip to reflect on after install. An hour and a half total - 65 to 70 mph. Water temp 185-190, oil temp 194, trans temp 188 max. Ambient air temp 92.
    Definitely cooler than oem delivery set-up.
  20. Jun 15, 2024 at 6:22 PM
    #140
    eddiefromcali
    Eddie
    100% Stock
    I'm seeing 218 in similar conditions and speeds
  21. Jun 15, 2024 at 6:24 PM
    #141
    303Gen3
    Golden Colorado
  22. Jun 15, 2024 at 6:26 PM
    #142
    303Gen3
    Golden Colorado
    If you were local and wanted to do the install I'd be there to assist. Definitely it helps.
  23. Jun 15, 2024 at 6:31 PM
    #143
    Black widow TRD
    Manuel
    My ambient temp is 102, transmission temp 226.
  24. Jun 15, 2024 at 6:31 PM
    #144
    Black widow TRD
    Manuel
    What Map are you on ?
  25. Jun 15, 2024 at 6:33 PM
    #145
    303Gen3
    Golden Colorado
    Ugh. That is too hot. Just got back from Houston - 90% humidity and 92 degrees. Fauck it was hot!
    I'm at 5800 ft and 15% humidity. Took me a week
    to recover.
  26. Jun 15, 2024 at 6:43 PM
    #146
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
  27. Jun 15, 2024 at 7:02 PM
    #147
    303Gen3
    Golden Colorado
    I mean add the external cooler and use your identifed product for the cooler and extra hose volume. Don't wait for the warranty to expire- your transmission will be toast by then!
    MaxPayne3 and ARB1977[QUOTED] like this.
  28. Jun 15, 2024 at 7:04 PM
    #148
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    How did you hook up your cooler lines?
  29. Jun 15, 2024 at 7:10 PM
    #149
    303Gen3
    Golden Colorado
    I posted details, pics, and parts a page or two back. Just use the "back arrow" on my posts. DM if you have questions on where to intersect the oem system although it is in a diagram further back in the thread.
    Tundrastruck91 likes this.
  30. Jun 15, 2024 at 7:25 PM
    #150
    eddiefromcali
    Eddie
    100% Stock
    Seeing those temps stock through map 3
