2022 Tundra SR5 Android Auto problems
Discussion in '3rd Gen Tundras (2022+)' started by 19876578, Jan 5, 2022.
  1. Jan 5, 2022 at 8:52 AM
    19876578 [OP] New Member
    Hi All
    Sorry if this has been posted somewhere, I had a look but couldn't find anything.
    I just picked up my 2022 SR5 and am constantly having problems with my bluetooth connecting and android auto.
    I am pretty sure I set up the bluetooth correctly so don't think that is the issue.
    The problems I am having are:
    1) half the time my phone will not connect to bluetooth so I have to manually go into settings, bluetooth and then click on my phone to connect it. Once I do this, there are no issues, just seems ridiculous to have to manually connect each time.
    2) It seems that if I connect to android auto (which I usually again have to go to settings, bluetooth, then click on 'connect for android auto') If I remove my phone from the cable, my phone will now also be disconnected from bluetooth, so I have to then manually go and select it from the settings menu again. Or sometimes I will plug in my phone while already driving, and it will not connect to android auto, I will have to do it manually. I have always had F150s and never had an issue bouncing from android to bluetooth and vice versa, and can't imagine that this is how Toyota intended for it to work.
    3) When i turn the truck on it says it can't find my profile, or something along those lines. 50% of the time it then finds it shortly after and the other 50% of the time it doesn't and I have to go in and find it myself to connect it (I am not sure what the profile even does, or why it doesn't connect)
    I have tried deleting my phone from bluetooth and reinstalling it, and also switched cables that I use to connect to android auto to ensure it wasn't just a cable issue, but the issues still happen.
    Anyone with any similar issues or fixes would be greatly appreciated.
    Thank you,
  2. Jan 5, 2022 at 8:55 AM
    nuclear
    nuclear New Member
    Seems to be a common problem, hopefully an OTA update will fix it soon.
  3. Jan 5, 2022 at 9:27 AM
    Got it, thank you for your quick response.
  4. Jan 5, 2022 at 10:26 AM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    First thing you need to do is link a primary key fob to your account. That will allow it to automatically log in when you start the truck with that key fob on board.
  5. Jan 5, 2022 at 10:41 AM
    Great thank you. How do I do that? Everything I am finding online is about their remote connect app which I have (I don't use it but it's all set up)
    Thank you,
  6. Jan 5, 2022 at 11:07 AM
    Toyota1234
    Jack
    Once your log onto your profile. You just go into your settings and there is a “link kee fob” button or something. Make sure you only have one key fob in the truck.
  7. Jan 5, 2022 at 11:09 AM
    Awesome. Thank you
  8. Jan 5, 2022 at 1:17 PM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Supposedly there is an OTA Update releasing in Feb that will solve many common issues with the head unit software.
  9. Feb 20, 2022 at 4:15 PM
    Versus78
    Versus78 New Member
    I am also having issues with wireless Android Auto that doesn't seem to connect to my phone. I find that when I use the remote start it happens more. It that might be a coincidence.
    I am using a Pixel 4 phone. Hopefully an OTA update will sort this ..
