2022 Tundra Scale Weight
Discussion in '3rd Gen Tundras (2022+)' started by rideandfly, Jan 10, 2022.
  1. Mar 7, 2023 at 8:32 PM
    Robsteeler66
    Robsteeler66 New Member
    Robert
    2021 TRD Sport 4X4 SR5 Double cab
    Weird that Toyota put a rear axle with less capacity on their new truck. Beefed up the frame and then put a lesser axle on it.
  2. Mar 8, 2023 at 4:45 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Yeah, there is more payload but slightly lower rated axles.
    I tend to go by the axle ratings myself. My truck weighs 5930 lb stock unloaded, but it can carry 8150 lb (4000 lb FF/4150 lb RR) if perfectly distributed without overloading either axle.
    I’m not advocating for people to use their axle ratings instead of GVWR as a rule of thumb; I just appreciate the capability in the relatively seldom situations when I need to haul a heavy load.
  3. Mar 8, 2023 at 7:01 AM
    rideandfly
    rideandfly [OP] New Member
    Question for everyone, are Tundra axle capacities increased with increased GVW on higher trim level Tundras meaning lower trim level axle ratings are de-rated? My Tundra is a 2WD SR5.
    GVW Weight 6990 pounds
    Maximum front axle 4080 pounds
    Maximum rear axle 3860 pounds
    Load Capacity 1400 pounds
