2022 Tundra Binds During Sharp Turn with 4x4H Engaged
Discussion in '3rd Gen Tundras (2022+)' started by kylea311, Nov 17, 2022.
  1. Nov 18, 2022 at 9:27 PM
    #61
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Locked and loaded baby…what brand of oil should I use for full time 4wd driving. You know, in case I hit black ice?
  2. Nov 18, 2022 at 9:29 PM
    #62
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Yep, GM has a great system for winter driving. I found out and remembered how my old 2002 Tacoma was with the oldish school 4WD last night with my 22 Tundra. Just need to make adjustments and it’s fine. My ‘15 Canyon spoiled me for snowy driving.
    However, the Tundra did great in the snow and once I got back into shifting mode it was fine.
    It would be great if they would put the LC system on these trucks.
    Tripleconpanna likes this.
  3. Nov 19, 2022 at 2:18 AM
    #63
    You need special black ice oil. Hard to find though......
  4. Nov 19, 2022 at 4:27 AM
    #64
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I use Singer 3 in 1 oil in the little tin can.
    JLS in WA and Black Wolf like this.
  5. Nov 19, 2022 at 4:28 AM
    #65
    That tin can is kuul.....
  6. Nov 19, 2022 at 5:34 AM
    #66
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Every Toyota 4x4 I’ve owned is like this. Back in 2003 I sold my 97 4Runner when I moved to Japan. This young kid came over and wanted to “test drive” it. He was a serviceman so I trusted him to take it for a spin. He brought it back 20 min later stating “your 4WD broke” and then he took off. Forget what part he damaged that I had to replace. Lesson learned always ride with them.
  7. Nov 19, 2022 at 6:10 AM
    #67
    CTundraForMe
    CTundraForMe New Member
    I had to read up on 4x4 vs AWD vs 2WD when I got my first Tundra. It's not intuitive.
    But it works just fine if you know what you're doing.
    I always hoped the tires would give first in a true bind in 4x4 mode.
    At least you noticed it was binding!
    I can tell right away by the way it drives when my wife leaves it in 4H. She is still oblivious that she forgot to take it off when out driving by the creek with the kids.
    Fortunately it's all dirt roads from there to here, but still.
  8. Nov 19, 2022 at 6:21 AM
    #68
    rss29
    rss29 New Member
    22 WCP DC LTD
    I have given up on trying to explain part time vs full time, driveline binding, and the function of differentials. I failed similarly when trying to answer the question "why would you want to shift your own gears?". Luckily her SUV is AWD and the truck is too big to drive.
  9. Nov 19, 2022 at 6:32 AM
    #69
    JLS in WA
    Groovy. 10k or 5k mile intervals?
  10. Nov 19, 2022 at 8:11 AM
    #70
    Wallygator
    I prefer how Toyota does it. Don't need "auto4wd" or any other bs quadratrac shenanigans. Old school 4wd/4lo, user operated is my preference. Hell I wish the Tundra was lever operated like my 4Runner Trail was. YMMV
  11. Nov 19, 2022 at 10:43 AM
    #71
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Well, not exactly that as CoalDragger explained above. I've seen a lot of confusion about the subject in various forums. Difficult to explain the differences in one paragraph. I'll put it this way - I like to be efficient in my morning routine, so I shave with the rechargeable razor as I commute. In snow with ANY system that does not require swapping back and forth from 2WD to 4HI I drive with one hand on the wheel and shave with the other hand.
    There's a lot to like about manual front hubs and manual Tcase. Simple, versatile, reliable, no electronic actuators. The '97 Taco 2.7l 4WD was a gamer. Having said that, I think Yota should implement the 2G Sequoia multimode Tcase into the 3G's.
    Wallygator[QUOTED] likes this.
  12. Nov 19, 2022 at 10:50 AM
    #72
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Do you live in a regular snowfall area?
  13. Nov 19, 2022 at 10:57 AM
    #73
    JLS in WA
    I do and it suits me just fine.
    Wallygator likes this.
  14. Nov 19, 2022 at 11:21 AM
    #74
    kylea311
    kylea311 [OP] New Member
    Dazz
    too damn cold where you can walk on water :-)
    2022 Tundra Platinum 4x4
    I checked the it out, but backseat is small and tech is so inferior to the Tundra's... I just wish Toyota would have used auto transfer case then you won't have to worry about turns, etc,
    BTBAKER[QUOTED] likes this.
  15. Nov 19, 2022 at 12:15 PM
    #75
    Wallygator
    Yes. An regularly use 4x4 at least monthly
  16. Nov 19, 2022 at 12:50 PM
    #76
    Coal Dragger
    Kung Fu Dick
    Have you ever driven a truck or SUV with a Torsen equipped transfer case? I have and the Torsen full time 4 wheel drive system is superior in every way to the antique 4X4 system that we’re still using on the Tundra.
    I suppose you must also like low power engines, rotary dial phones, cotton socks, light beer, well whiskey, and Spam instead of other clearly superior alternatives.
    An old school selectable 4 wheel drive isn’t more durable, nor is it any more functional than a Torsen transfer case with high and low ranges with a locking feature.
  17. Nov 19, 2022 at 1:00 PM
    #77
    Wallygator
    Yes all those things are better. I had a Torsen once. My doc made me wear tighty whiteys for a month and a half. YMMV.
    JLS in WA and Tripleconpanna like this.
  18. Nov 19, 2022 at 1:07 PM
    #78
    Coal Dragger
    Kung Fu Dick
    I could forgive most of those things, but preferring light beer is just not acceptable.
  19. Nov 19, 2022 at 1:24 PM
    #79
    wiretwister
    wiretwister Sorta new guy
    NJ
    '22 SR5 CM
    holy guacamole. the level of cluelessness in this thread it mind-numbing.
  20. Nov 19, 2022 at 2:16 PM
    #80
    mmasse
    mmasse Digital Forensics Cowboy
    Idaho
    2022 Magnetic Grey Tundra
  21. Nov 19, 2022 at 2:31 PM
    #81
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    To be fair, it started with the thread title…
    mmasse likes this.
  22. Nov 19, 2022 at 2:35 PM
    #82
    wiretwister
    NJ
    '22 SR5 CM
    100%
  23. Nov 19, 2022 at 3:36 PM
    #83
    Wallygator
