2022 Tundra 6CYL pouring white smoke from exhaust
Discussion in '3rd Gen Tundras (2022+)' started by GamecockEng, May 25, 2023.
  1. May 25, 2023 at 5:16 PM
    GamecockEng
    GamecockEng [OP] New Member
    2022 Tundra CrewMax Limited
    Took my '22 Tundra to the dealer today to get the 15k mile maintenance and on the way home after picking it up I noticed the engine was bogging down and then a huge white cloud behind my truck.
    No dash lights, no codes on the computer. Had it towed back the dealer. The service manager without looking at it thinks they overfilled the oil while topping it off and oil leaked into the cylinders. I dont agree, as that smoke would be much darker and the smoke would be smelly.
    Is there a chance my head gasket is blown? If it does end up being overfilled with oil, what else do I need to get them to check/change? Spark plugs? Change out the oil and filter?
  2. May 25, 2023 at 5:19 PM
    koditten
    Kirk
    Midland of the Mitten
    Check the level of the antifreeze in the rad.
    I'm betting they overfilled the oil.
    2nd gens take almost 8 quarts. I don't know what a 3rd gen takes, but I bet it's less and the tech got confused.
    GamecockEng[OP] likes this.
  3. May 25, 2023 at 5:22 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    There was a time when overfilling the oil would damage the catalytic converters.
    Not too sure if that is the case with these newer vehicles.
  4. May 25, 2023 at 5:32 PM
    koditten
    Kirk
    It will still affect the cats. As long as it's corrected and the truck is run hard, the oil will burn off.
  5. May 25, 2023 at 5:35 PM
    Tom976
    Tom976 New Member
    Tom
    So you left the truck there and they gave you a rental?
    Too much oil in a turbo motor is a very bad thing. Too much oil in the cylinders? Err no. Too much oil with a turbo, well the oil had no place to go.
    That can cause a leak on the turbine and compressor ends.
    Generally too much oil in a motor will start leaks. I had a Sonata v6 that the dealer way overfilled. I ran the motor for a bit and saw smoke from under the hood.
    Took the plastic over off and it looked like an oil "water park".
  6. May 25, 2023 at 5:37 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    We call that an Italian tuneup
    koditten[QUOTED] likes this.
  7. May 25, 2023 at 5:47 PM
    GamecockEng
    I only drove about 3 mi before I noticed the issue. I had the truck towed back and the dealer said they would get it looked at first thing in the morning.
    But yeah they gave me their loaner Tacoma for the night so I could get home and get to work in the morning while they work on it.
    I'm hoping it's not something major. I do like the truck but I'm definitely concerned since it's the first year of a new generation and a new engine. If it does end up being too much oil in the engine, should I get them to state that in writing that was what the problem was in case there's an issue down the road with the engine?
  8. May 25, 2023 at 5:56 PM
    koditten
    Kirk
    The extra oil does not " leak" into the cylinders.
    The oil is aerated from the constant beating by the connecting rods. The level was too high and the rod ends were beating the oil into a vapor as the rod ends spun thru the oil.
    The oil/air vapor is pulled back into the intake and burned along with the gasoline that is injected.
    All engines pull the extra crankcase gasses back into the intake and use them for combustion. In the case of too much oil in the sump, you will be burning these combustion gasses as well as the aerated engine oil.
    As long as you get that extra oil out fairly soon, the cats can burn off that extra oil residue. The key is soon.
    If you get a check engine light in the next 2 months, you might want to exercise that warrantee.
  9. May 25, 2023 at 8:09 PM
    xc_tc
    xc_tc New Member
    Yep, too much oil causes white smoke. Exactly what the post above need mentioned. You caught it way early so should be ok.
  10. May 25, 2023 at 9:52 PM
    Tom976
    Tom976 New Member
    Tom
    They are going to repair the engine as they best as they can and it'll be covered. I'd like the whole reason and resolve documented somehow. Doubt they'll do that.
    Maybe on the completed workorder?
    I'll squash the "you should get a new truck" thing that some will say. Not going to happen.
    (only way they'll take it back is if they get you into a "new truck for just a little more money" game)
    Such a lame mistake to do. Quality check on service performed should be priority one.
    Nobody likes to go back to the service area for the same problem or multiple times per week.
  11. May 26, 2023 at 3:29 AM
    raylo
    raylo not so new member
    Frederick, MD
    3rd gens take 7.7 qts.
  12. May 26, 2023 at 3:37 AM
    GamecockEng
    anything in particular I should insist on them checking to verify no problems with?
    I was thinking fouled spark plugs, oil leaking out anywhere else, catalytic converters, ect.
  13. May 26, 2023 at 4:47 AM
    whitecord1
    whitecord1 New Member
    22 tundra trd off road
    my bet the lube tech is pretty green and forgot to drain the oil and over filled it 7 liters of oil.
    koditten and GamecockEng[OP] like this.
  14. May 26, 2023 at 5:24 AM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    Not to derail but does anyone know why my frame is weeping oil? I don’t see a puddle when I park so not sure.IMG_2700.jpg
  15. May 26, 2023 at 6:03 AM
    GamecockEng
    The dealer did call this morning and confirmed that they believe the issue was them adding too much oil. They changed the oil and said everything is good now.
    Thank you everyone for your advice. Hopefully this is the end of the situation.
  16. May 26, 2023 at 6:03 AM
    xc_tc
    xc_tc New Member
    I would just monitor the vehicle until the next oil change. Overfilling the oil doesn’t necessarily lead to instant failure of those components.
  17. May 26, 2023 at 11:59 AM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    This....
    I have not looked under a gen 3 but I've seen situations in the past where the tech drained the transmission fluid and refilled the oil so it was a double whammy.
    Insist they check transmission fluid levels.
    Most engines can handle 1/2 to 1 quart overfill before it starts puking white smoke. This must have been significantly overfilled.
    Just another reason to do your own work, And whenever the dealer does anything you double and triple check before you pull out of the lot.
    When I had the free oil changes the tech would always get pissed because before I would drive it out of their fancy receiving bay I would pop the hood and check the oil.
    I told them that I don't trust dealers and it's always better safe than sorry.
  18. May 26, 2023 at 1:48 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Completely unrelated to what this thread was for. Start a new thread. Then get up underneath it and look for the source.
