2022 TRD Pro Towing Squat. -HELP Requested
Discussion in '3rd Gen Tundras (2022+)' started by Throttle73, Oct 2, 2022.
  1. Oct 5, 2022 at 1:19 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    There's too many people that see 1/2 ton trucks and 3/4 and 1 ton trucks as being from the same purpose. Over the last 10 years 1/2 tons have gone from being related to the HD trucks to being closer related to sedans. Think of how mid size SUV's were thought of 10-15 years ago, that's how 1/2 ton trucks should be thought of. Far too many people think 1/2 ton trucks are still work trucks, and unfortunately sales people don't help this.
    The research you mention would find this exact point, but far too many people look at a brochure and that's it. Then they blame the manufacturer when there's 1000's of posts or comments saying the brochure doesn't tell the entire story. HD trucks still have that 'tool' trim level, but 1/2 tons don't really anymore because manufacturers don't see the value in producing them.
  2. Oct 5, 2022 at 1:29 PM
    zonehenge
    zonehenge New Member
    Pete
    Western Mass
    2022 Solar Octane TRD Pro
    285 75 18's Wild Peak, PPF for front, Go Rhino RB20 slims, Truxedo Sentry CT, TVD decals
    Looks good, are you going to lunar rock the blue on the boat, that would look perfect.
  3. Oct 5, 2022 at 8:39 PM
    catalac
    catalac New Member
    Wow that’s nuts, that aluminum trailer would weigh about 3000lbs empty so either you have a lot of weight in the front or something is fishy post a couple pics with the front and rear ramp down with that squat.
  4. Oct 5, 2022 at 8:51 PM
    DennisEllis
    DennisEllis New Member
    Mr Ellis
    Should’ve gotten a 3/4 ton.
    Towing ain’t no job for these modern day El Caminos.
    belanger9 and Nightshade Tundra like this.
  5. Oct 5, 2022 at 9:13 PM
    Will816
    Will816 New Member
    Will
    Idaho
    2022 Limited iForce Max TRD Off Road
    This is far from the truth and can be disregarded.
    He just needs a WDH. A 3/4 ton would need one as well.
    Snomej and Scooter73 like this.
  6. Oct 5, 2022 at 9:54 PM
    Nightshade Tundra
    Nightshade Tundra New Member
    Alex
    2021 Ram 2500 Laramie
    That's a negative
    ColoradoTJ, belanger9 and KNABORES like this.
  7. Oct 6, 2022 at 8:12 AM
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    Haha nah not gonna LR the boat. Ill be getting a bigger boat once the market adjusts, I do like the America's Cup/Stars&Stripes Blue that this boat has though.
  8. Oct 6, 2022 at 9:10 AM
    zonehenge
    Pete
    Western Mass
    It is definitely a sharp looking boat! I just got my miles up to tow mine around.
  9. Oct 6, 2022 at 9:19 AM
    kilocharlie106
    TRD Pro in LR
    Thanks, I appreciate it. Towing with this vs 2nd Gen is different, less RPMs. I didnt put into tow+ but might try next time as its on the line of weight, depending on how much fuel/gear I have on.
  10. Oct 6, 2022 at 10:31 AM
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Trailering can be such a PITA to get the combo set up properly. So many variables, especially with a softer offroad rear suspension. Trying to maintain factory ride and capabilities while also trying to haul well is a chore.
    zonehenge and Nightshade Tundra like this.
  11. Oct 6, 2022 at 10:35 AM
    Nightshade Tundra
    Alex
    It can be a pain but luckily forums exist where we can spit ball ideas
    I know I got a lot of good insite on this forum when I first got my toy hauler, I had plenty towing experience in the past but was mostly with car haulers and dolly's
  12. Oct 6, 2022 at 11:06 AM
    Jaxyaks
    Jaxyaks New Member
    For a 7,000 lb trailer...not hardly...on mine I never even considered a WDH unless the trailer I was towing was getting close to 12K. The biggest problem with most of these 1/2 tons (especially the tundra) is that they run out of payload way before they run out of pulling capacity...
    That TRD Pro has soft springs so your gonna see sag with some surprisingly light weight. Thats one of the worst I have seen pics of yet though....
    Dont let them big 3 fan boys get a hold of that pic....the Meme's will be endless...lol:):)
  13. Oct 6, 2022 at 12:19 PM
    Dunes
    Dunes New Member
    JJ
    2023 Grey CrewCab 6.5 TUN 4x4
    I am planning to acquire a new 34FT airstream that is about 7500 Lbs. for my 4x4 SR5 TUN, which WDH is good option.. can someone suggest a good one. I dont have airbags on it not that they help for tow.
  14. Oct 6, 2022 at 4:29 PM
    belanger9
    Edmonton, AB
    A bunch
    7500 wet or dry? You planning to load it up to full GVWR of the trailer or try to keep it as close to dry weight as possible?
  15. Oct 6, 2022 at 6:46 PM
    catalac
    catalac New Member
    I’d get a bar set up like the curt round bar or trunnion. I’ve tried the Anderson chain one it doesn’t do much, bar ones seem better from my experience.
  16. Oct 6, 2022 at 10:25 PM
    Dunes
    Dunes New Member
    JJ
    Thanks . Went to 'We are Airstream' here in Ariz and got some ideas and any other considerations for towing. so far 25FT, 27FT or 34FT are in mind.
  17. Oct 7, 2022 at 6:05 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    34 is too big for a halfton.
  18. Oct 7, 2022 at 6:36 AM
    Nightshade Tundra
    Alex
    Stay away from the 34ft'r unless your planning on buying another truck
  19. Oct 7, 2022 at 2:30 PM
    #49
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    My trailer has a GVWR of 7600lbs (that's a 5400lb dry trailer). I think I'm right about at the limit of what I would tow with this truck. The tongue weight is 1000lbs when loaded. Depending on what truck you get, after you put two people in it hooked up you will be right at payload capacity. I think the 34' you're talking about would be WAY to much trailer.
    I will say, my Tundra tows as good (probably better with the lower end torque and 10spd trans) as my '19 Ram 1500.
  20. Oct 7, 2022 at 4:07 PM
    #50
    Front_Range_Pro
    Front_Range_Pro EEF Brand Ambassador
    Vail, Colorado
    2022 Lunar Rock TRD Pro
    TRD lift kit won’t work on a Pro. Maybe try some sumo springs?
    I also have a Pro but I think we are screwed until someone comes out with beefier spring options. Robinson sells 2” lift springs but they are basically Land Cruiser 80/100 springs. I’m not sure about the weight capacity increase (if any).
    Also, not sure if you have the OEM suspension or put in a collar lift kit. But if you did the latter, it will accentuate the sag.
  21. Oct 7, 2022 at 5:06 PM
    #51
    Ejp1234
    Ejp1234 New Member
    2021 TRD Pro DC Lunar Rock
    Its a pro with fox suspension… its soft, on purpose. You bought the wrong truck lol, you paid a bunch for a suspension thats working against your wants.
    go blast across a couple speed humps at 45-50mph and rescind your regret, but its still not going to tow that trailer lol.
  22. Oct 7, 2022 at 5:12 PM
    #52
    Roctane84
    Roctane84 Tread On Them
    Louisiana
    ‘22 TRD Pro Solar Octane (SOLD)
    1000lbs on the tongue is too much. You need to load it different. Is it a 2-5/16 ball or a 2”? If its a 2” then its definitely too much tongue, and if its 2-5/16” it still may be.
    A lot of ball mounts arent rated for much more than 750lbs max unless you move up to a 3” tube like youd find on a heavy duty truck.
    Best advice is a WDH and bags, but first work on reloading.
    Breathing Borla likes this.
  23. Oct 7, 2022 at 7:20 PM
    #53
    belanger9
    Edmonton, AB
    A bunch
    Tundra has a class IV hitch - those are rated for 14000 lbs of towing, 1400 lbs of tongue weight. It should be a 2 5/16 ball for sure at that weight
  24. Oct 7, 2022 at 7:43 PM
    #54
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I think the 2nd Gen ball mount itself is rated for 10k lbs.
    GODZILLA likes this.
  25. Oct 7, 2022 at 9:28 PM
    #55
    Roctane84
    Louisiana
    regardless, a 7500lb trailer shouldnt have 1000lb on the tongue. and most of the drop hitch setups in 2” and even 2-5/16 max out at 750lb or 1000lb, unless theyre forged, and then maybe you see a 1500lb max
  26. Oct 8, 2022 at 4:20 AM
    #56
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Tongue weight should be between 10 and 15%, which is 750-1125 lbs.
    GODZILLA, X42069, JLS in WA and 2 others like this.
  27. Oct 16, 2022 at 4:48 AM
    #57
    Throttle73
    Throttle73 [OP] New Member
    Jamie
    Ontario, Canada
    2022 Tundra TRD Pro (Red on Black)
    None
    I’m carrying a 2020 Polaris General 1000 and some off-road gear
  28. Oct 16, 2022 at 6:11 AM
    #58
    TrimTab
    TrimTab Old man with a beard
    Trim
    so what is the optimal max GVWR and/or Dry weight the Tundra would handle?
    is a Dry weight of 5500lbs and a GVWR of 7500 to much for a Tundra?
  29. Oct 16, 2022 at 6:39 AM
    #59
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    You need a WDH and set it i up properly to level the trailer and truck. Kind of looks like the ball is too high in your picture.
    This thread makes my head hurt.
  30. Oct 16, 2022 at 6:43 AM
    #60
    X42069
    X42069 New Member
    M
    Southwestern Ontario Canada
    23 SR5 CrewMax TRD Off Road 6.5ft box
    This will be my first truck and I plan to get a camp trailer. I speak only from the research I have been doing and not from experience but I think that would be getting to the high end of what I would be comfortable with. Mind you there is much more to consider than just the weight of the trailer. Someone else will likely have better info for you lol
