2022 Ratio Worksheet
Discussion in '3rd Gen Tundras (2022+)' started by stevj, Oct 31, 2021.
  1. Oct 31, 2021 at 7:34 PM
    stevj
    stevj [OP] New Member
    On a clear day, I can see Seattle from my house.
    Current RAM 1500 owner waiting for the new Tundra "hybrid."
    I was digging around old files and found this Excel file I made for some research on an old Dodge Dakota I used to own.
    I just came upon a TUNDRA Product Information someone posted, and decided to modify the file for the 2022 TUNDRA and its 10-speed transmission.
    "And don't you want to know how it works!"
    In the top section, input tire size, speed and axle ratio and you get wheel diameter, tire RPM and Driveshaft RPM at 60 MPH.
    In the bottom section you'll find a table that computes engine RPM based on vehicle speed, transmission gear and rear ratio.
    7th gear is direct drive in this 10-speed.
    All this seems kinda pointless, but is actually useful if:
    You're undecided or want to know which transmission gear to use to keep your engine RPMs in a certain range at a given speed.
    Or want to know what affect tire size will have on engine RPMs at a certain vehicle speed.
    I tried to keep it simple. I also included all available OEM tire sizes by trim level in a small table off to the side, just for reference purposes.
    All the gray-background numbers are INPUTS. Change them and the blue numbers will update.
    The green-background numbers are the OUTPUTS of the Tire Size, Speed and Axle Ratio, but they also feed the table at the bottom so engine RPM can be computed.
    In the table, the blue numbers are OUTPUTS of all those other numbers about the sheet, and transmission gear ratio and vehicle speed.
    This is an XLS file, so those of you that prefer earlier, non-ribbon versions of Excel like I do (this was done in Excel 2003) can use it.
    If you've ever wondered about such things or are just curious how these things interact, have a copy and play.
    I double-checked the math, but if there's an error, I'm sure one of you fine folks will find it.
    Enjoy,
    Here's a picture of the Spreadsheet open and set to 265/60R20, OEM tire size for TRD Sport,TRD OFF-Road,Limited,Platinum,1794, based on the Product Information PDF.
  2. Oct 31, 2021 at 9:08 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Thank you! Looking forward to playing with this with different sized tires to find the sweet spot!
    BikiniRubi likes this.
  3. Oct 31, 2021 at 9:24 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Nice job, Steve! Great to have you on this forum!
  4. Nov 1, 2021 at 7:49 AM
    nodak67
    nodak67 New Member
    JR
  5. Nov 2, 2021 at 2:46 PM
    stevj
    It's a resource, made available for those who find utility in it.
    There are always alternatives.
