2022 interior......horrible!
Discussion in '3rd Gen Tundras (2022+)' started by Tundra234, Jul 20, 2021.
  1. Jul 23, 2021 at 3:41 PM
    #121
    TTund16
    TTund16 New Member
    do the new turbo trucks burn oil per design? at least the old V8's don't burn none.
  2. Jul 23, 2021 at 3:52 PM
    #122
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    I don’t think anyone knows the answer to that question yet.
    Generally speaking turbo charged engines are more likely to consume oil than a naturally aspirated engine. Higher cylinder pressures mean that combustion gasses are more likely to make it past the piston rings and result in a bit of oil consumption.
    Then there’s the issue of piston ring to cylinder wall mating, I don’t know what kind of rings Toyota will be using, but some turbocharged engine makers utilize rings that really need to see some high cylinder pressures when new to be seated/mated properly. Diesel engine rebuilders have known this for awhile, and like to see big Diesel engines hooked up to a load and pulling hard almost immediately once in the truck to accomplish piston ring to cylinder wall mating.
    Darkness and TTund16 like this.
  3. Jul 23, 2021 at 3:59 PM
    #123
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I don't think it will, at lease 3 years 3600 miles
  4. Jul 24, 2021 at 2:19 PM
    #124
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Maybe Its a active Redline meaning its back lit an depending on what mode its in determines the redline for mapping and efficiency.
  5. Jul 24, 2021 at 2:26 PM
    #125
    Handbanana
    Handbanana New Member
    2018 TSS CM 4x4
    Trd sway front Trd sway rear Trd shift knob Nitto ridge grapplers OEM LED FOGS
    That’s sad ram has a 12 inch computer and we get this weak sauce.
    Westerntowboss and WILLINH like this.
  6. Jul 24, 2021 at 3:09 PM
    #126
    MoonRock2021
    MoonRock2021 New Member
    2021 TRD Pro Crewmax Lunar Rock 2021 4Runner Nightshade
    The big question is will it be Electric Lime Metallic like the 22 Taco?
    Darkness, TTund16 and JLS in WA like this.
  7. Jul 24, 2021 at 3:28 PM
    #127
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I really hope not.
    Wallygator, Boerseun, TTund16 and 4 others like this.
  8. Jul 24, 2021 at 3:47 PM
    #128
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    There’s a member in this thread that doesn’t own a Tundra anymore but still spends time on here to throw negativity around as much as he can. That to me is the definition of a loser that needs a few hobbies or a partner to get his life back on track. Just sad.
    Alright, thread derail over. Carry on..
  9. Jul 24, 2021 at 3:53 PM
    #129
    Handbanana
    2018 TSS CM 4x4
    Tag him lol
    Darkness, monaco730 and Ahab like this.
  10. Jul 24, 2021 at 3:57 PM
    #130
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    He’s to ignorant to keep his mouth shut so I’ll let him expose himself.
  11. Jul 26, 2021 at 4:21 PM
    #131
    Tundra'25
    Tundra'25 Well-Known Member
    Wincent
    Southern California
    I really hope that's not the interior of the new Tundra . . . It just doesn't
    I really hope that's not the interior of the new Tundra—it just doesn't look right. That type of interior belongs in a Camry . . . or a Ford . . .
    Aside from that, the picture of the TRD Pro dashboard interior view doesn't look bad at all. Also, notice how this interior barely matches up with the TRD Pro one (the speakers, the lines of the dash, etc.)
    2022 TRD Pro Dashboard Interior from Toyota:
    AZTundra[QUOTED] and jewsNbrews like this.
  12. Jul 26, 2021 at 10:54 PM
    #132
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I see that lethal, horrifically dangerous Driver's Side Grab Handle is back for 2022!:eek::D
    Tundra'25 likes this.
  13. Jul 26, 2021 at 11:36 PM
    #133
    Coal Dragger
    Kung Fu Dick
    The grab handle will kill us all.
    CMB likes this.
  14. Jul 27, 2021 at 8:11 AM
    #134
    mass-hole
    mass-hole New Member
    I just lol'd so hard. Even most of the Ford people make fun of the faux Raptor lights.
  15. Jul 27, 2021 at 8:20 AM
    #135
    mass-hole
    My GX screen has crapped the bed and I have lost 50% of my HVAC controls because of it.
    My 2014 F150 has 10000 more miles and works just fine. Even if it did crap the bed the only thing I lose is my heated seats, everything else has manual buttons.
    So its not just Ram, Chevy and Ford.
  16. Jul 27, 2021 at 8:29 AM
    #136
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
  17. Jul 27, 2021 at 8:32 AM
    #137
    mass-hole
    The only V8's that are making big numbers with a blower, without throwing a ton of ancillary parts and money at them, are the 5.0's, and only because they can rev to the moon. They will spin them to 8k.
    2018+ Ecoboosts are making 450+ RWHP tune only. With E85 people are scratching 600 rwhp on stock turbos. There have been a few in the high 600's with some turbo upgrades and other bolt ons unsing 93 octane on the stock long block for the cost of a supercharger.
    But the V8's sound good at least.
  18. Jul 27, 2021 at 8:41 AM
    #138
    Ahab
    Ahab New Member
    Ahab
    2021 Tundra SR5
    This is my problem with these new controls. I do not want all of these things that break easily, I want good, long lasting, controls. I do not want to worry about replacing a touch screen because I use the same 4 places on it for 20 years.
    snivilous and JLS in WA like this.
  19. Jul 27, 2021 at 1:49 PM
    #139
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
  20. Jul 27, 2021 at 1:52 PM
    #140
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    I agree, see I want to lift it so I hope they offer a good package minus the seats and the bed stamp... I don't want to be that guy to buy a TRD PRO and lift it which removes everything it was designed for lol
  21. Jul 27, 2021 at 3:00 PM
    #141
    mass-hole
    Idk but my 2011 Lexus GX soccer mom suv has MTS and Crawl so i would hope they do something. Also, how about a diff locker or actual LSD? What truck doesnt have an option for a rear locker or even front lockers/lsd's at this point.
    ZappBrannigan likes this.
  22. Jul 27, 2021 at 3:52 PM
    #142
    Coal Dragger
    Kung Fu Dick
    Your GX is a Land Cruiser Prado literally everywhere else it’s sold in the world outside North America. So it does have some real capabilities under that party dress it’s wearing.
    ryanwgregg likes this.
  23. Jul 27, 2021 at 3:56 PM
    #143
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Should be just like the Tacoma, they have it in TRD off-road, it’s a waste to put it on a TRD sport
  24. Jul 27, 2021 at 6:52 PM
    #144
    NueveTundra
    Planet Earth
    ;) Hopefully there will be JL C5 or C7 upgrade an not the crappy JBL stuff , I want real things :rofl:
  25. Jul 27, 2021 at 8:43 PM
    #145
    Cg13055
    Cg13055 @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    If i am gonna be honest, I've hard people complain for 5 years about an outdated interior, now I will hear complaints for a couple years about an ugly interior, not much of a trade off lol, I personally don't care if it works it works
  26. Jul 27, 2021 at 8:44 PM
    #146
    Cg13055
    South Florida
    That's definitely a toyota, can see the logo shape on the tape
  27. Jul 27, 2021 at 8:50 PM
    #147
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Toyota always put buttons in the wrong place, auto industry should put a building standards on buttons location
    Breathing Borla and Cg13055 like this.
  28. Jul 28, 2021 at 7:17 AM
    #148
    Westerntowboss
    Westerntowboss New Member
    Seriously what is up with those air vents?
    Darkness likes this.
  29. Jul 28, 2021 at 8:52 AM
    #149
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    For real, fuck your big ass screens all you guys want :rofl: I want a knob or a slider, screens always look like complete shit in every vehicle I've seen, they're a pain in the ass to use, there is no efficiency with them, if your door handle is slightly wet when you get in you now can't control anything, the list goes on as to why they're a pain in the ass. I want to be able to roll around in the mud and get in the truck and turn the heat on and adjust the radio with two motions and nothing more :D
  30. Jul 28, 2021 at 8:57 AM
    #150
    Nightshade Tundra
    Nightshade Tundra New Member
    Alex
    2021 Ram 2500 Laramie
    You do realize that the Ram's do have buttons and knobs to go along with the "big ass" screens right?
    Westerntowboss likes this.
