2021 usb-c module
Discussion in 'Electrical' started by ScenicRoute, Mar 21, 2022.
  1. Mar 21, 2022 at 7:51 AM
    ScenicRoute
    ScenicRoute [OP] New Member
    2021 Tundra CM Nightshade
    Eibach stage 2, SmartCap, Ride Rite, Bora spacers, 35” rugged ridge tires.
    Is there a direct swap usb-c module that can be swapped for the factory usb under the dash? My other vehicles all came with usb c ports. Don’t want to use a cigarette lighter to usb c adapter and would rather just replace once of the 3 factory modules.
    Thanks!
    AggiePhil likes this.
  2. Mar 21, 2022 at 7:53 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Buy a USB to C adapter. I also purchased one for the rear cigarette lighter port.
  3. Mar 22, 2022 at 4:23 PM
    ScenicRoute
    was trying to find a replacement module if it exists…
  4. Oct 10, 2022 at 5:59 PM
    TTCsparky
    TTCsparky New Member
    Scott
    2020 White Tundra Plt
    85532-08040 will replace the dual USB A ports with 1 USB A and 1 USB C. I don't recall the output but it does have some of the USB-C higher output modes, it's certainly better than 2.1A@5V.
    DoublePro and Magilla_Gorilla like this.
  5. Feb 9, 2023 at 8:58 AM
    Undra_T
    Undra_T New Member
    Warren
    2018 1794 Edition CrewMax 4x4
    Elka/OME/SPC/Timbren suspension, Lighting by Baja Designs/SDHQ
    Sorry for reviving an old thread, but has anyone tried Part # 85532-08040 in a 2019 or older Tundra? Can anyone confirm if Part # 85532-08040 is direct replacement part for the usb/aux that came from factory? I’m guessing the plug is completely different but thought I’d ask anyways.
  6. Feb 9, 2023 at 10:47 AM
    TTCsparky
    Scott
  7. Feb 9, 2023 at 11:14 AM
    Undra_T
    Undra_T New Member
    Warren
  8. Feb 23, 2023 at 7:42 AM
    Kung
    KG, VA
    What I'm curious about is whether or not this can be done for the 'data' port in the 2020 Tundra.
  9. Feb 23, 2023 at 7:55 AM
    TTCsparky
    Scott
    I haven’t seen a Toyota that has a USB-C communications port yet. When there is one, someone will have to check to see if they made the module into a standard form.
  10. Feb 23, 2023 at 8:35 AM
    mayan
    mayan Texas BBQ and Beer
    Mayan
    DFW
    2023 SM Tundra Limited
    Do you have a pic I have some modules on ebay from the 3rd gen if you wanna retrofit them.
  11. Dec 12, 2023 at 1:42 PM
    FiveO Enduro
    FiveO Enduro New Member
    Buffalo, NY
    2020 Army Green Pro
    Sorry to bring this back.. again..
    I bought the “Toyota OEM 85532-0E110 Socket USB C Charger 20-22 Sienna, Tundra, Tacoma, Avalon” off eBay, to find out the plugs are mirrored. I ended up shaving the inside of the female plug with an exacto knife. The stock tundra harness plugged right in and functions as it should. Figured it was worth sharing if anyone wants “factory” usb-c. Unsure if the output is effected for not.
  12. Dec 12, 2023 at 2:21 PM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
  13. Dec 12, 2023 at 2:25 PM
    FiveO Enduro
    Buffalo, NY
    2020 Army Green Pro
