2021 Tundra popping noise driver side front wheel area
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mad Max, Apr 17, 2024.
  1. Apr 17, 2024 at 4:43 PM
    Mad Max
    Mad Max [OP] New Member
    Max
    2021 Tundra Limited
    Hello,
    I have a loud popping sound when turning left and applying brakes. I would guess the pads are moving in the caliber but all the hardware and springs are there. Only has 13K miles on it. Anyone else have a noise?
    Thanks
  2. Apr 18, 2024 at 6:47 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    ‘20 with about 45k, no noise like you describe.
  3. Apr 18, 2024 at 5:49 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    No poping noise here.
  4. Apr 18, 2024 at 8:08 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    you have trd skid plate?
    Terndrerrr, FISHN43 and joonbug like this.
  5. Apr 18, 2024 at 9:05 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Any recent alignment work?
  6. Apr 19, 2024 at 8:11 PM
    Pete2021
    Pete2021 New Member
    Pete
    2021 Tundra Sport
    I also have the popping sound I think its the spring, 2021 tundra and does it when I hit a small pump while turning in my 2020 tacoma,sound on mine is the coil spring slipping under load in its seat.
  7. Apr 19, 2024 at 9:42 PM
    WiscoWalleye
    WiscoWalleye New Member
    I think my pads are moving in the caliper because I have a slight click when applying the brakes especially if I reverse direction of the wheel. ie backing up the going forward and vise versa. I need to get in there more and look at it. I also have a spring sounding noise when applying the break sometimes usually if it’s a cold day. Not sure what this could be either.
  8. Apr 20, 2024 at 7:16 AM
    Pete2021
    Pete2021 New Member
    Pete
    2021 Tundra Sport
    a loose caliper bracket? caliper bolt? could also cause a click.
  9. Apr 20, 2024 at 8:53 AM
    WiscoWalleye
    Thanks! I’ll check this again. I think I checked it once but doesn’t hurt to look again. When I had the wheel off I’d rotated the hub forward and back and I would hear and feel the click. There was no visible movement but it felt like the pads were possibly shifting slightly.
  10. Apr 21, 2024 at 6:00 PM
    Mad Max
    Max
    2021 Tundra Limited
    Mine is the result of the outer disc brake pad sliding and hitting the caliper. Everything is in place, springs, pins etc. Funny we all don't have the noise. In the end it is not detrimental just a noise..... Be nice not to have noise but it is what it is.
    WiscoWalleye likes this.
