2021 TPMS Help
Discussion in 'Wheels & Tires' started by Bergy24, Jun 7, 2022.
  1. Jun 7, 2022 at 3:44 AM
    Bergy24
    Bergy24 [OP] New Member
    2021 Cement Crewmax Limited TRD 4X4
    I have a 2021 Limited with push start.
    My OEM Valve stems/tpms look like normal rubber valve stems from the outside.
    I just bought some PRO BBS Wheels and I believe they came off a 2019. These valve stems/TPMS also look like normal rubber valve stems from the outside.
    I plan to keep both sets of wheels and tires for now and would like TPMS operational in both sets if possible.
    From all the reading I have done it appears the 20 and 21's have a different Frequency and will not allow the 2019 sensors to work.
    I have done a lot of reading on here and it seems there is a lot of confusion.
    I found that there are 2 different part numbers but not sure what I need
    42607-06030 Labeled "PMV-C015" on the sensor
    42607-0C091
    From what I can tell, the 42607-06030 is for the push to start but not 100% positive
    Can anyone confirm what number I need to use?
    Will I be able to use this method to register and recalibrate the new sensors?
    If I go the aftermarket route, are the Autel Sensors and tool my best option and again, which one exactly do I need?
    Thanks for all the help with this.
  2. Jun 7, 2022 at 11:31 AM
    Bergy24
    I know one of my options is to use a universal sensor and have it cloned.
    I am assuming if I do this, I will be able to swap wheels/tires when ever I want without reprogramming every time, correct?
    I called a couple local shops in my area and the going price is about $69 per (universal) sensor installed and cloned.
    Since the tires are already mounted to the wheels, I am assuming they can just brake one side and replace the sensor and balancing will not be needed, Correct?
    Will this be my best option or just I go OEM?
    If I go OEM, will I be able to swap wheel/tires whenever I Want without programing every time?
  3. Jun 7, 2022 at 11:37 AM
    I would go OEM. Alot of people have had issues with aftermarket sensors on the 20 and 21. @Roman can get you the correct part number.
  4. Jun 7, 2022 at 11:40 AM
    Bergy24
    But will I be able to swap wheels/tires at anytime I want without hassle?
    Not sure how often I will swap them out but would be nice to be able to do so without registering and relearning every time.
    I am half tempted to swap my existing sensors over to the PRO wheels and deal with the new sensors if I ever do want to swap the wheels/tires.
  5. Jun 7, 2022 at 11:47 AM
    I'm not positive but there are guys here that swap winter with summer sets with 2 sets of sensors IIRC.
  6. Jun 7, 2022 at 12:43 PM
    Bergy24
    Update:
    Per the dealer the oem tpms sensors on my truck from factory are 42607-02050
    This does seem correct since they have the rubber snap in stems.
  7. Jun 7, 2022 at 2:19 PM
    Bergy24
    My dealer wants $75 each for the sensors and $200 to install and program them.
    That’s $500 plus tax.
    If I buy the oem sensors, can I use the method I attached above to program them myself?
