2021 Tacoma Dash Knockout Removal
Discussion in 'Other Toyota Vehicles' started by glbird99, Dec 30, 2020.
  1. Dec 30, 2020 at 10:16 PM
    glbird99
    glbird99 [OP] New Member
    Gary
    2021 Tacoma
    I just purchased a 2021 Tacoma. I want to install an electric deer whistle. I found a website that sells switches that fit in the knockout plugs in the dash. I need to know the best way to remove the knockout plug on the left side of the dash. Some youtube videos show how to remove that part of the dash in older models but nothing gives me any help for the 2021 model. Any help will be greatly appreciated.
    YardBird likes this.
  2. Dec 31, 2020 at 6:04 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  3. Dec 31, 2020 at 6:36 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    spitballing....but a dremel tool would make quick work cutting out plastic for a switch. Not sure if a Tacoma had any changes to the dash vs 2020, 2019, etc. Suggest you check some of the tacoma forums.
  4. Dec 31, 2020 at 6:47 AM
    timsp8
    NY
    A box cutter will work but you have to be careful not to slip and cut more than you intend.
  5. Dec 31, 2020 at 6:52 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Can we see a photo of the panel @glbird99?
    GODZILLA likes this.
  6. Dec 31, 2020 at 9:41 AM
    glbird99
    Gary
    2021 Tacoma
    Let's see if I figured out how to post the picture I took of the dash. I can get my arm up in there behind the knockouts but I can't feel any release tabs. It looks like that cover around those buttons and the knockouts can be removed. I just don't want to risk damaging anything.
    Squatting Pigeon likes this.
  7. Dec 31, 2020 at 9:42 AM
    Squatting Pigeon
    Holden
    North Texas
    Those will pop out without any cutting. There are two release tabs, top and bottom that will let the blank come out.
    I would take that whole panel out so you can get behind and remove the blanks easier.
  8. Dec 31, 2020 at 9:43 AM
    Kanobi13
    Kanobi13 New Member
    This or a chainsaw should do the trick
  9. Dec 31, 2020 at 9:46 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    this fixes most problems, I have learned over time.....
  10. Dec 31, 2020 at 9:49 AM
    Squatting Pigeon
    Holden
    North Texas
    That and/or a sledge will take care of 99% of any vehicular problems.
  11. Dec 31, 2020 at 10:07 AM
    glbird99
    Gary
    2021 Tacoma
    Do you mean just that small panel around those switches on the left side or the whole panel like I have seen on some you tube videos? If you mean just that small panel, what is the best way to go about it without damaging anything? Are there release tabs on that panel? I appreciate your reply.
  12. Dec 31, 2020 at 10:09 AM
    Squatting Pigeon
    Holden
    North Texas
    This link will show you how to remove the whole switch panel there. It looks like it is all pressure clips:
    https://cdn.shopify.com/s/files/1/2...-78d2-437b-b1af-8bcdd541d0b9.pdf?v=1599611057
