2021 Stock 4WD CrewMax Tire Upgrade/ 17” wheels
Discussion in 'Wheels & Tires' started by sbhc138, Aug 15, 2022.
  1. Aug 15, 2022 at 8:48 PM
    sbhc138
    sbhc138 [OP] New Member
    Looking to go with a wheel upgrade on my stock 2021 4WD CrewMax Tundra as well as add All Terrain tires. I like the look of a little more sidewall so want to go 17” wheels. Any suggestion for tire size? Stock is 255/70/18, I was thinking 275/70/17 would be closest. Appreciate any feedback. Pictures welcomed if you have a similar setup
    IsaiahCanada likes this.
  2. Aug 15, 2022 at 9:19 PM
  3. Aug 16, 2022 at 3:43 AM
    PermaFrostTRD
    Northern NY
    Are you looking to increase the tire size to “fill out the wheel well” some? Or keep it approximately stock?
    305/70r17 is a 33.6x12” tire and has some good AT options. Guys fit 275/70r18 all the time without suspension mods and that’s pretty close (33.2x10.8”). The wider tire of the 305 might require some trimming and/or fender liner mods.
    play around with this calculator and see what you want to do:
    https://www.tacomaworld.com/tirecalc?tires=275-70r18-305-70r17
  4. Aug 16, 2022 at 5:12 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Covered meany times, not many wheel choices for us in 17. Most seem to go with Icon or Method. The main issue with 17s is the offsets are usually around the 0 range. I think Icon makes the "ideal" set for us in the 25mm zone.
  5. Aug 16, 2022 at 5:21 AM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
