2021 Sequoia TRD Pro-Here comes the Mods!
Discussion in 'Sequoia Builds' started by Octave, Nov 16, 2021.
  1. Jan 12, 2022 at 5:21 AM
    #91
    DrillBitz
    DrillBitz New Member
    2021 TRD Pro’s - Tundra & Sequoia
  2. Jan 12, 2022 at 7:53 AM
    #92
    Octave
    Octave [OP] New Member
    2021 Sequoia TRD Pro (Super White)
    ALL incandescent lights to LED Added LED footwell lights TRD CAI TRD Catback exhaust Side de-badging Westcott Designs Lift Kit Front TRD sway bar Rear TRD sway bar TRD cup holder coasters TRD seatbelt pads Lots more mods to come!!!
    I don’t have a pic. Westcott has a ton of YouTube vids on the lift kit and the process.
    you can also call them with all your questions. They are extremely helpful!
  3. Jan 12, 2022 at 8:08 AM
    #93
    hoof hearted
    hoof hearted New Member
    2018 Sequoia Limited 4WD
    Are these different than what come with the Pro? I thought it already came with TRD Fox Shocks from the factory.
  4. Jan 12, 2022 at 8:14 AM
    #94
    Octave
    Yes it comes stock with the fox setup.
    The Westcott is designed to work properly with the fox setup. I’ve had zero issues with it installed.
    S. Equoia likes this.
  5. Jan 15, 2022 at 3:30 PM
    #95
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    @Octave would you mind when you have a moment listing the parts you used when installing the Kenwood? Harnesses, adapters etc...? Just trying to hit you up while its fresh in your mind, and this system is bound to be different than my Tundra was...since it's JBL. Appreciate it!
  6. Jan 15, 2022 at 5:46 PM
    #96
    Octave
    bulldog93, WalFam and boostedtrdpro like this.
  7. Jan 15, 2022 at 5:51 PM
    #97
    Octave
    You can also use the iDatalink Maestro RR2 instead of the RR.
    the only difference is it gives you 4 auxiliary 12v outputs that you can toggle on and off from the head unit (depending on which one you get) to run anything you want like lighting, winch, ejection seat :rofl:
    be sure to use relays (just to be safe) if you go that route with the RR2/outputs…..
    boostedtrdpro likes this.
  8. Jan 15, 2022 at 6:43 PM
    #98
    boostedtrdpro
    Jeremy
    So you didn’t need or don’t use the SiriusXM tuner? Also assuming you went with the matte black dash kit? They all say on Amazon the 99-8220 doesn’t fit the sequoia :rofl:
  9. Jan 15, 2022 at 6:44 PM
    #99
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Very nice ride and build! :muscleflexing:
  10. Jan 15, 2022 at 6:45 PM
    #100
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Cool! I like.
  11. Jan 15, 2022 at 7:07 PM
    #101
    Octave
    Thanks Blanco!!
    Boosted - Amazon is absolutely wrong in this instance. I saw and was concerned about the very same thing, and decided to just go for it and try it out.
    :fingerscrossed:
    It fit perfectly with no modifications at all!!
    Also yes mine was matte black and it matches very nicely.
    I hate the audio quality of Sirius/XM, so no I did not add on that harness. If you want or need to the part number is:
    - iDatalink ACC-SAT-TO2
    DO NOT use the stock Toyota GPS antenna with the Kenwood unit. It requires a special proprietary antenna (included in the box) to work with the Apple CarPlay and Android Auto wireless features (learned from Kenwood rep). Not sure about other manufacturers…….
    Also one more thing….I did not use the flexible black metal plate under the Kenwood GPS antenna. I stuck it to the very top center of the windshield (in the black dotted area) just left of the rear view mirror mounting arm and it works great!
    I also mounted the Kenwood microphone to the left of the GPS antenna and people say my phone call audio on their end is ultra clear…….do not mount it next to the window or you will get road/wind noise when the window is down.
    boostedtrdpro and Y0TA PR0 like this.
  12. Jan 15, 2022 at 7:09 PM
    #102
    Octave
    plain black and boring……:notsure:
  13. Jan 15, 2022 at 7:14 PM
    #103
    Octave
    Hey has anyone tried “Beast Mode” on their Sequoia yet??
    It is awesome!!!
    If you don’t know what it is or how to activate it, look on YouTube!
    decoecho2323 and boostedtrdpro like this.
  14. Jan 15, 2022 at 7:16 PM
    #104
    boostedtrdpro
    Jeremy
    So weird, I used the stock Toyota GPS/SAT antenna in my Tundra and my CarPlay works just fine. From my limited understanding, this will afford you (with the separate tuner SXV300 and the ACC-SAT-TO2) access to SiriusXM without a cell signal so you don’t have to use the app, while retaining the factory GPS/SAT antenna. I thought the CarPlay and AA was based on your phones GPS anyhow…this may be different with the DNR1007XR model with built in Garmin.
  15. Jan 15, 2022 at 7:22 PM
    #105
    Octave
    So the requirement has changed a few times for the GPS/phone/CarPlay specifications over the last few years. You may have gotten lucky with a combo that worked with that year and spec of your head unit (The spec has changed back and forth from just the phone’s GPS, to the phone and the head unit’s GPS requirements). The current spec with Kenwood (and maybe others too) is phone and HU GPS…..
    BTW the new HU has a “new” GPS antenna (identified with a white label at the connector end) that is special to THAT HU and you cannot use an old GPS antenna from an older Kenwood HU….you must replace it with the new antenna for it to work properly.
    You are correct in that the separate SXV300 module is WAY better and does let you use the Sirius/XM on the head unit without a cell signal.
  16. Jan 15, 2022 at 7:32 PM
    #106
    Octave
    More HP, awesome sound, and fantastic aesthetic!!
  17. Jan 15, 2022 at 7:33 PM
    #107
    boostedtrdpro
    Jeremy
    Red, of course…haha. And the cleanable filter, along with the air box inlet.
    5N0W808[QUOTED] likes this.
  18. Jan 15, 2022 at 7:34 PM
    #108
    Octave
    Oh yah those things too! :thumbsup:
  19. Jan 15, 2022 at 7:37 PM
    #109
    Octave
    Inlet is bigger and totally different. Also filter is much less restrictive.
  20. Jan 15, 2022 at 7:40 PM
    #110
    Octave
  21. Jan 15, 2022 at 7:43 PM
    #111
    Octave
    I also removed the “bug screen” on the inside top of the filter box to allow for better inlet flow to the filter.
  22. Jan 15, 2022 at 7:46 PM
    #112
    Octave
    I also have noticed better pedal/throttle response.
  23. Jan 23, 2022 at 12:38 PM
    #113
    Octave
    SMD voltage gauge flush mounted.
    Had to move a few switches (center diff lock and tow/haul) to the center of the dash and then custom mold the gauge housing into the stock panel…
  24. Jan 30, 2022 at 7:24 PM
    #114
    boostedtrdpro
    Jeremy
    Jonesing for the weekly update. I’m about to pull the trigger on the Westcott kit. I take it the smart thing to do is get the airbags and install it all at the same time?
  25. Jan 30, 2022 at 7:46 PM
    #115
    Octave
    Yes it is much easier to install the bags when you are working on the suspension springs.
    No modding this week on the sequoia. I have been working on a large stereo install on a clients vehicle……667EAD32-B063-4835-BB7B-D6E3C44A7C57.jpg
    omgboost and boostedtrdpro like this.
  26. Feb 6, 2022 at 10:39 AM
    #116
    boostedtrdpro
    Jeremy
    Any pointers on removing the stock head unit? All the YouTube videos I’m finding seem to be first gens. Just curious about sequence of panels to remove to get the head unit out without breaking clips :D
  27. Feb 6, 2022 at 10:41 AM
    #117
    Octave
    PM me for details…….
  28. Feb 7, 2022 at 6:05 AM
    #118
    Adamdsgn
    Adamdsgn New Member
    2018 Toyota Sequoia
    There's a sequence of about 6-8 panels you have to remove. Process is pretty straight forward tho. Here is a video I found for a 2nd Gen.
    https://www.youtube.com/watch?v=SCDuNa3boxI
    WalFam and boostedtrdpro[QUOTED] like this.
  29. Feb 9, 2022 at 7:46 PM
    #119
    Octave
    Switched cupholder LED to blue and added blue mood lights to footwells……
    Wired the footwell lights to the cupholder light. All work with the OEM headlight switch on the blinker arm.
    Not as bright in person. Pretty dim actually……
    3D32C3A4-0409-4E38-83B7-9A62D70717CF.jpg E38B722F-E734-4C0F-8E8D-AAE3B52C1D70.jpg ADF8EFA8-9223-4B37-8294-D119D73340C3.jpg CEA659B8-EEF1-400C-8B2A-979831791DCD.jpg 90431D50-88D9-4107-9699-CC24AAE08896.jpg
  30. Feb 22, 2022 at 11:03 AM
    #120
    Diablonyc2
    Diablonyc2 New Member
    In regards to your Kenwood set-up -- Mine is almost identical (same DMX-1057). I am having an issue pushing the software update to the head unit. I got the USB adapter so I could continue using the stock USB slot on the dash and was able to push through a software update last year, but the most recent one is not working. The unit is not recognizing the USB drives -- but it will power the device that is connected (such as a phone). I do not want to take apart the dashboard to try connecting directly to the HU -- has anyone else had similar issues?
    ALSO -- is everyone having issues with the portal app? I cannot connect my phone to upload new photo wallpapers -- this used to be seamless and easy to do -- now the app just crashes.
