2021 MGM CM Sport. Mods and Such
Discussion in '2.5 Gen Builds (2014-2021)' started by thetastelingers, Dec 28, 2020.
  1. Jan 20, 2021 at 6:50 AM
    thetastelingers
    thetastelingers [OP] Master Baiter
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    Thanks man. I've had that plate on a few cars over the years.
  2. Jan 22, 2021 at 10:05 AM
    Do58
    Do58 New Member
    Any word or resolution to your ac controls? Kinda curious about this.
    Thanks
    jonclark96 likes this.
  3. Jan 25, 2021 at 4:15 AM
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    With work and kids, it was hard to remember to call. Every time I would remember, it would be too late or on a weekend.
    Luckily, I saw via email that you had posted and immediately called. I had to leave a message with the service manager. He hasn't called back yet. Hoping he gets back to me today.
    My septic tank backed up yesterday, so I may have to go home and deal with that. That may give me some time OTW home to call again.
    I'll update with whatever I find out.
    I got an early birthday present Saturday from the wife.
    Leather steering wheel!!! Going from the wife's 4runner limited with the leather steering wheel back to my truck, I could tell a huge difference in the quality and feel of the cheap feeling SR5 steering wheel.
    FYI, The splines on the two steering wheels are NOT in the same place which clocks the wheel different, so an alignment to straighten the wheel is in order.
    Luckily, I paid for the lifetime alignment at Firestone.
    [​IMG]20210123_204944 by Robert Stewart, on Flickr
  4. Feb 2, 2021 at 5:00 AM
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    I dropped off my horizontal trim pieces with a friend to get some hydrographics done. Just something small to break up the bland interior a little bit.
    Haven't heard from the dealer about the manual controls. Guess I'll call them when I get a chance.
    Ordered some switches from OBA for the air compressor and train horn. The kids started going back to school this week, so I will actually get a Friday to myself again. It's been a long time.
  5. Feb 2, 2021 at 6:35 PM
    Where are you mounting your compressor and horns? I will probably go with the spare tire delete mount on mine. Hornblasters is local to me here in Tampa.
  6. Feb 3, 2021 at 4:14 AM
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    I have a 2 gallon tank that I've been running since 2008 and I have a 4 gallon tank that I'd like to use. My previous Tundra didn't have the 38 gallon tank, so placement was easy. I think I found a spot under the bed opposite the tank, but I need to slide them in there and see how much room is available. If I can get the 4 gallon in there, I'll go with it.
    Horns will go behind the front bumper like my last set up.
  7. Feb 8, 2021 at 5:27 AM
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    Well, I didn't get to work on the layout of the Train horn, because we had an issue with the Septic tank. I spent the whole morning Friday digging up the access door and finding a blockage between the cleanout and the septic tank.
    Maybe I'll have time this Friday...
    My switches came in for the air compressor and horn switch. The way I wire it up, the switch acts as the ground for the air valve. When activated, the steering wheel horn will honk the OEM horn and the train horn, but if I turn the switch off, only the OEM horn is activated.
    [​IMG]20210205_150503 by Robert Stewart, on Flickr
    Also, I called Toyota again and left a message AGAIN about the manual HVAC controls. No callback yet. Maybe I'll just make a trip over there and ask in person.
    There was some snow that came through Saturday night, so we went to the Cherohala Skyway to play in it yesterday.
    I took the Jeep. Figured I would share here.
    [​IMG]20210207_130310 by Robert Stewart, on Flickr
    [​IMG]20210207_130256 by Robert Stewart, on Flickr
    [​IMG]20210207_130300 by Robert Stewart, on Flickr
    [​IMG]20210207_130409 by Robert Stewart, on Flickr
    [​IMG]20210207_130505 by Robert Stewart, on Flickr
    [​IMG]20210207_142424 by Robert Stewart, on Flickr
  8. Feb 15, 2021 at 4:16 AM
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    I finally had some time Friday to start on the air compressor install.
    I'll be using this for the train horn as well as the air bags and air supply if needed.
    With the 38 Gallon fuel tank, there wasn't a lot of places to put a 2 gallon tank, much less the 4 gallon that I wanted to use. I found a place under the front of the bed that ended up being perfect. I will have to order a remote hookup for the air supply, so I won't have to get under the truck to hook it up. I'll most likely get 2. One for each side of the truck.
    It's hard to see where I mounted it, but the driveshaft will move up and down between the two.
    I got the tank and compressor mounted. The horns and valve install will have to be this Friday. I had to order air lines, because what I had was too short. Figured I would do it all at once.
    [​IMG]20210212_160259 by Robert Stewart, on Flickr
    Obligatory ESP storage bin under the back seat. This should have been factory...
    [​IMG]20210214_073520 by Robert Stewart, on Flickr
    [​IMG]20210214_075737 by Robert Stewart, on Flickr
  9. Feb 22, 2021 at 6:43 AM
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    Amazingly, I had some time this weekend to work on the truck.
    Got the horns installed Friday.
    [​IMG]20210221_182117 by Robert Stewart, on Flickr
    All the air lines and fittings arrived on Saturday.
    Got the electrical and air lines ran yesterday.
    One of the switches that I received from OBA did not fit the hole.
    I'll send a picture to them and see what they say about it.
    Also, there was another hiccup. I have fitted air line fittings at each side of the truck for airing up tires, but the push fittings I ordered from Amazon all were leaking. I'll have to order some better quality fittings and go from there. I blocked off that port.
    The horn is operational!
    Sorry there aren't more photos. I'll take more pictures when everything is final.
    I washed the truck Saturday, but didn't drive it yesterday. Today it's raining... ugh...
  10. Feb 22, 2021 at 8:00 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Nice climbing wall.
    Tundra ain't bad either.
    :p
  11. Feb 22, 2021 at 8:37 AM
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    Thanks man! Hoping to take that climbing wall all the way to the ceiling in the future.
  12. Feb 27, 2021 at 8:47 AM
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    I just completed moving the radio USB from under the HVAC controls to inside the center console. Didn't really take any pictures, but if you want to do this, Go to Casey's build thread Here
    I purchased all the things he did and everything worked perfectly.
  13. Feb 27, 2021 at 12:46 PM
    Do58
    Do58 New Member
    Did you get your ac working the way you wanted? Maybe I missed the info on the swap
  14. Feb 27, 2021 at 1:50 PM
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    I did not. Kinda in limbo at the moment. Keep calling the Toyota dealership, but they never call me back.
    I'll end up going over there one day and cornering them about it.
    Sorry about that for those that are waiting to hear if it can be done. Sometimes I procrastinate about certain things.
  15. Feb 27, 2021 at 2:17 PM
    Do58
    Do58 New Member
    No worries... thanks for the quick response. I know once it’s figured out, you’ll post. Great build/thread by the way
  16. Mar 23, 2021 at 5:20 AM
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    I can't leave well enough alone. I have a friend that does hydro-graphics and I end up getting a little something done to every one of my cars just to break up the plain look.
    I had him do the mid trim in the dash.
    It's almost too glossy! LOL
    [​IMG]20210323_080819 by Robert Stewart, on Flickr
    [​IMG]20210323_080829 by Robert Stewart, on Flickr
    68 RS/SS likes this.
  17. Mar 23, 2021 at 5:22 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Man that came out nice!
  18. Mar 23, 2021 at 5:27 AM
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    Thanks!
    Previously I've got carbon and they've all turned out nice, but carbon look on a truck just wouldn't look right and I wanted to switch it up a little.
  19. Mar 23, 2021 at 2:04 PM
    #49
    Do58
    Do58 New Member
    Looks great but for me.... too glossy. That being said, I’m not there nor my truck. I’m afraid of the glare here in the bright/sunny hot ass state of Tx.
    Not throwing shade by any means...the graphics look awesome
    thetastelingers[OP] likes this.
  20. Mar 24, 2021 at 4:04 AM
    #50
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    Yeah. It's a bit glossy. He asked if I wanted matte, but I was afraid some of the detail would get lost in the matte. Didn't think some of the detail would get lost in the gloss. HAHA!
  21. Mar 24, 2021 at 8:02 AM
    #51
    Sacul
    Sacul New Member
    2024 Tundra Limited TRD
    Nothing yet
    Nice! I just ordered the chrome delete kit for interior this morning. Probably going to get rid of all the silver around the radio too if I can find something. I hear there are some radio upgrades that give you wireless (Bluetooth) CarPlay too so didn’t get the radio nob replacements.
  22. Mar 24, 2021 at 8:10 AM
    #52
    Sacul
    Sacul New Member
    Nothing yet
    Did you have someone do that storage bin for you or did you do it yourself? I’ve seen others do the same. Was wondering if you have exact dimensions on how to build?
  23. Mar 24, 2021 at 8:43 AM
    #53
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    The storage bin is ordered from HERE When you get it, the template is on the outside of the box it comes in. You just trim the box, then lay it over your floor foam and cut. (I cut the foam with a drywall saw after cutting the carpet with a razor)
    Sacul[QUOTED] likes this.
  24. Mar 24, 2021 at 9:18 AM
    #54
    Sacul
    Sacul New Member
    Nothing yet
    That’s great! Thanks for the link!
  25. Apr 1, 2021 at 7:51 AM
    #55
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    Posted this in the daily thread. Figured I would post it here for timeline.
    Found a set of the bed rails shipped for $166. Figured I wasn't going to find them any cheaper, so I ordered them.
  26. Apr 1, 2021 at 11:46 AM
    #56
    Do58
    Do58 New Member
    Was this from a dealership or 3rd party?
  27. Apr 1, 2021 at 1:21 PM
    #57
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    Click HERE Type in FREESHIP in their coupon code space. $166.75 shipped.
    Hope that helps.
    Do58[QUOTED] likes this.
  28. Jun 14, 2021 at 7:22 AM
    #58
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    Finally found an AVS rear glass ventshade. I had one of these on my 2013.
    It allows me to roll down the rear glass a little on these hot days and not worry about a rain shower.
    Don't much care for the side window ventshades, so this does the trick well.
    As you can see, it doesn't fit perfect, but i'm ok with that.
    [​IMG]20210613_140446 by Robert Stewart, on Flickr
