2021 Headlights
Discussion in 'Lighting' started by Perk7, Feb 2, 2021.
  1. Feb 2, 2021 at 8:41 AM
    Perk7
    Perk7 [OP] New Member
    A.P.
    2021 Black Tundra XP
    Hey guys I'm curious I want to switch out my low beams . Has anyone done this and did you remove the grille?? What bulbs do you recommend?? Got pic? Thanks
  2. Feb 2, 2021 at 8:44 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Yes, you have to remove the entire grille, surround and a few panel pieces under the headlights.
    Perk7[OP] likes this.
  3. Feb 2, 2021 at 8:46 AM
    Perk7
    A.P.
    Ok thanks... what would you describe as the degree of difficulty? I'm rather handy tools but not to technical lol.
  4. Feb 2, 2021 at 8:48 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Lots of YouTube videos on it.
    It is fairly easy to do, but you have to go slow and be cautious as the Grille Surround tabs can be easily broken.
    Safar85 likes this.
  5. Feb 2, 2021 at 9:07 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    You don't remove the grille surround. I think you are referring to the tabs on the grille. I have had mine off several times. Just work slow and start from passenger side. There are posts on removing the grille. Be careful on panel pieces. They have little clips on the bottom back side.
  6. Feb 2, 2021 at 9:08 AM
    18" TRD Off Road Wheels
    Be careful with all the plastic bits. ESPECIALLY in cold weather. It makes it brittle.
    Perk7[OP] and BravoDeltaRomeo like this.
  7. Feb 2, 2021 at 9:11 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, I wait for a warm day and park with grille facing the sun.
  8. Feb 2, 2021 at 9:11 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    You don't have to remove the Grille Surround from the Grille, but the tabs are still delicate.
    Yeah, my wording was off. The insert does not need to be removed from the surround, but the entire unit does need to be removed as a whole from what I know.
    I've done mine a few times too, it's fairly easy once you figure out where to stick your hand down behind it and release the tab pressure on the lower tabs by hand first. No loud snaps or need to yank anything when you release the pressure on those ones. A lot less scary.
    They don't make it easy on us. Below is the video I used to guide me through our 2019 Swap.
    https://www.youtube.com/watch?v=s1YH9gYPloo
  9. Feb 2, 2021 at 9:14 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, don't pull on the surround. Curious why the OP wants to change bulbs. Are all 2021 models LEDs?
  10. Feb 2, 2021 at 9:18 AM
    No, not all '21s are LED.
  11. Feb 2, 2021 at 3:53 PM
    Perk7
    A.P.
    no on the XP you would think they would have put LED headlights but no thank you guys yes I have researched it and seen several methods on line I was just curious what you guys thought was the easiest I like the YouTube video BravoDeltaRomeo shared.
    Thanks again eb I'll definitely wait for a warm day
  12. Feb 2, 2021 at 4:17 PM
    Get the TRD PRO headlights and some Rigid fog lights or Baja Designs fog lights
    Perk7[QUOTED][OP] likes this.
  13. Feb 4, 2021 at 4:48 PM
    Perk7
    A.P.
    Hey good looking out. I'll give it a look see!!
