2020 Tundra OEM Rear Pad part number question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Anthony605, Aug 27, 2023.
  1. Aug 27, 2023 at 5:44 AM
    Anthony605
    Anthony605 [OP] New Member
    Anthony
    2020 Limited Double Cab
    I am looking to buy OEM rear brake pads for my 2020 Limited. I did some online research and it looks like the part number for the pad set should be 04466-02340. Some sellers list the part number as 04466-AZ208. Is there a difference between the two part numbers? Are they interchangeable? I did some research and it looks like the actual pads have not changed from about 2007 to 2021.
  2. Aug 27, 2023 at 5:50 AM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    rodm1 likes this.
  3. Aug 27, 2023 at 5:56 AM
    Anthony605
    Anthony
    OK thanks. I did not realize that there was any difference between the pads. Do you know of the composition of the pad material is any different? I looked at the Akebono catalog and their part number has not changed at all.
  4. Aug 27, 2023 at 5:58 AM
    fyrfytr26
    Eastern PA
    2021 DC SR
    No, I don’t know anything about pad composition. The TCMC are the pads typically installed when you have brakes done at the dealer. Pad life is much shorter with those.
  5. Aug 27, 2023 at 6:46 AM
    Anthony605
    Anthony
    OK thanks. I will either go with OEM pads or Akebono.
  6. Aug 27, 2023 at 8:29 AM
    fyrfytr26
    Eastern PA
    2021 DC SR
    The 04466-02340 are the pads that were on your truck from the factory.
  7. Aug 27, 2023 at 11:14 AM
    Anthony605
    Anthony
    Thank you again for the information. Dealerships can be sneaky! That is why I do my own work....
    fyrfytr26 likes this.
  8. Aug 27, 2023 at 1:54 PM
    fyrfytr26
    Eastern PA
    2021 DC SR
    The one to thank is whoever posted that chart a while back. I knew it would come in handy, so I saved it.
  9. Aug 27, 2023 at 2:44 PM
    Anthony605
    Anthony
    Good Point! Thank you to whoever that was also!
  10. Apr 9, 2025 at 11:37 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Does anyone have the part numbers for the pads, shims, pins, etc for a 2016?
