2020 Tundra Keyless Entry/Remote Start Door Handle Swap Write-up
Discussion in 'General Tundra Discussion' started by Ckatz53, Dec 15, 2019.
  1. Feb 22, 2020 at 10:20 AM
    Spakylpm
    Spakylpm New Member
    2024 Tundra
    @Ckatz53 Yeah the wire it too tight to splice from just the handle side. I just completed so I have a couple of tips I did just let the door hang from the lead anchors just one lest step of removing and reattaching. I did razor off the silicone from the plastic and pealed down from the top exposing a small area to get my hand in. When done I just molded back the silicone to the plastic liner. Since I was inside the door panel I decided to add some hushmat as well. Thanks, Ckatz53 for all the pics and instructions it did make it easier to follow.
    Ckatz53[OP] likes this.
  2. Feb 22, 2020 at 2:19 PM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Nice job man. Yeah I really wish I had thrown some sound deadening material in there while I had it apart. I'll be back in there soon to do it hah.
  3. May 6, 2020 at 3:58 PM
    SuthrnTundra
    SuthrnTundra New Member
    Kyle
    2020 Cement Tundra Limited 4x4
    TRD Off-Road Grille TRD Off-Road LED Headlights
    Does anyone know if you can just take the limited handle apart so I can just paint the chrome part?
  4. Jun 9, 2020 at 6:02 AM
    KENNY
    KENNY New Member
    I was wanting to do the same. I took a handle off and started prying the chrome piece real quick and it seems to be just held into there with some 3m tape. Didn't go "all the way" as I only had a few minutes but I'll rip it off soon :thumbsup:
    Great write up by the way :cheers:
  5. Jun 11, 2020 at 6:50 PM
    SoCalTecHead
    SoCalTecHead New Member
    Tony
    Orange County California
    2020 Cement CM Limited
    Impressive documentation... Well done!
  6. Jun 11, 2020 at 9:09 PM
    Bigolbaddy
    Bigolbaddy New Member
    Ben
    Fort Worth
    2020 MGM 1794
    Can you confirm it’s just 3m tape holding it on there?
    KENNY[QUOTED] likes this.
  7. Jun 12, 2020 at 5:50 PM
    KENNY
    KENNY New Member
    Just went out and peeled it off. Those 2 little tabs arent connected to anything; I think more or less are guides. You just need to be careful as the chrome piece can lose it's shape if you bend it too much :thumbsup:
    Correction, that tab on the top does look snapped off, but its so small i don't see it doing much. The little tab in between those 2 posts was not connected to the handle even though it looks snapped off - probably from mass production or something..
  8. Jul 22, 2020 at 2:53 PM
    Qbert
    Qbert New Member
    You have the push button start correct? The part number roman gave me i brought to my dealer and they said it was glossy black but your's don't look to be.
  9. Jul 22, 2020 at 5:01 PM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    Yes. And the one's I got from Roman are matte.
  10. Jul 29, 2020 at 1:24 PM
    tundradude23
    tundradude23 New Member
    Nick
    Ventura county CA
    2020 tundra crew max
    Can anyone help me with this ?? This is drivers side door. Have an issue removing this anchor . It’s saying move towards door jam
    no clue what I’m doing wrong been messing with it for 15 mins now
  11. Jul 29, 2020 at 2:02 PM
    ttime4four
    ttime4four New Member
    West Linn, OR
    '20 Tundra Limited DC TRD Offroad
    https://youtu.be/-3_MQKgXhok
    Does this video help
  12. Jul 31, 2020 at 10:51 AM
    SuthrnTundra
    Kyle
    Wow! Good to know! Thank you for doing that! Do you have any pictures of it after you painted it?
  13. Jul 31, 2020 at 2:58 PM
    KENNY
    KENNY New Member
    It still looks the same :rofl:
    My plan was to wrap them with some vinyl I was going to use on some other stuff..
  14. Oct 11, 2020 at 4:20 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Thanks for this thread!
    I will add that I did not disconnect the tweeters because I couldn’t figure out how to remove the harness plug. Wasn’t a problem.
    Also, I did not cut the plastic liner but instead just peeled it back and then reattached it. The black silicone sealer is super sticky and goes right back like it was.
    TundraDDS and Ckatz53[OP] like this.
  15. Jan 16, 2021 at 4:19 PM
    TundraDDS
    TundraDDS New Member
    2020 White Tundra Limited 4x4
    Did you place the hushmat between the plastic interior door panel and the thin plastic liner?
  16. Jan 22, 2021 at 1:20 AM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    I just did this mod and referred to this DIY for guidance... super helpful and I was able to get all four done in about an hour start to finish.
    Once thing I'll add is pay attention to the little white push clips that hold the door panel to the door.
    When I pulled the panel a few of them stayed in the door. I had to pop them out with a small flathead and put them back into the panel before reinstalling. I didn't notice until trying to put the first panel back on and it just didn't feel right or line up perfectly. Turned out the push clips were not allowing it to pop back in correctly. Otherwise, pretty simple job since our trucks come apart and go back together like legos for the most part.
  17. Feb 12, 2021 at 12:31 PM
    3xYOTA
    3xYOTA Taco/Rav/Tundra
    Far West Texas
    2020 Tundra 1794
    Great write up!!! I tried to figure out how to disconnect the wiring for 30 min before google led me to this post and man it saved my butt. Thanks for the detailed pics and write up.
    Ckatz53[OP] and RainMan_PNW like this.
  18. Feb 12, 2021 at 1:09 PM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    Yeah man. Some of the input others have put in make it a bit easier. I was just winging it when I did it lol. It's a great forum for stuff like this!
  19. Feb 21, 2021 at 1:02 PM
    #49
    Bluesttape
    Bluesttape New Member
    Jesse
    2021 Grey Platinum
  20. Mar 15, 2021 at 2:17 PM
    #50
    Noob2595
    Noob2595 New Member
    2021 Tundra Platinum - Nightshade?
    This was an amazing write up! I just did this, didn’t break a single plastic tab, and completed the install in about an hour. Thank you sooo much for taking the time to do this!
  21. Mar 25, 2021 at 9:11 AM
    #51
    Tundra_Curt
    Tundra_Curt New Member
    Curt
    2021 Tundra Limited CrewMax
    Just getting started...
    Is is possible to pull the chrome trim off for paint without removing the door handle from the truck?
  22. Mar 25, 2021 at 9:35 AM
    #52
    throughitalldude
    throughitalldude New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    Im still confused if I was to do the handle upgrade on my 17 platinum how would it detect my key fob and unlock the doors just at the touch of the handle? Isnt there something else needing to be added that would trigger the door to unlock.
  23. Mar 26, 2021 at 4:49 PM
    #53
    Bluesttape
    Jesse
    2021 Grey Platinum
    If you don’t already have smart lock you would need more than just the handles. I’m not sure what, but I know more than just the handles.
  24. Mar 28, 2021 at 3:35 PM
    #54
    1794TX
    Steven
    N.TX
    '20 1794
    Thanks for this. Finished the job in under an hour, with zero trouble.
  25. Apr 21, 2021 at 6:49 PM
    #55
    KENNY
    KENNY New Member
    Hey sorry. You could yeah, it isn't connected to anything other than the handle, but that tape is super strong. I got a crinkle in the one chrome piece i took off, just ended up 3m taping it back on for now...
  26. Apr 24, 2021 at 1:07 PM
    #56
    Gfgneo
    Gfgneo New Member
    California
    2021 tundra platinum
    How did you get the door sensor to slide over?(inside the passanger side door) Mine will not budge to slide over
  27. Apr 24, 2021 at 5:35 PM
    #57
    Jevan
    Jevan New Member
    2021 Silver Limited TRD
    Anyone tried to pull the inside sensor out of smart handle and put in a non smart handle? Was looking at dechroming limited handles and replacing with textured black.
  28. Apr 24, 2021 at 6:44 PM
    #58
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    Just have to use some force. It'll pop out.
  29. Apr 25, 2021 at 2:30 PM
    #59
    Gfgneo
    Gfgneo New Member
    California
    I gave up on that instead i just popped the top anchor off. Was much easier and faster
  30. Apr 25, 2021 at 7:10 PM
    #60
    SteelRedOne
    SteelRedOne New Member
    2020 Cavalry Blue Tundra
    This write up inspired me months ago, and I finally got around to it this weekend. Took about 2 hours total, as I added some Kilmat to the doors while I had the door panels off. A couple of things for others thinking about doing this:
    1) Getting the wire off the anchor - This stumped me for a while as I really didn't want to apply much force and its awkward to pull the wire harness out of the anchor. What worked for me was to grab a set of channellocks to pull the wire harness. One good pull in it slid right off.
    2) The kilmat (or whatever sound deadening mat you choose) might be the best part of this update. It's not dramatically quieter, but the stereo sounds so much better. I have the JBL system, and previously I would ride around with the volume at ~30. On my test ride, I turned the volume down to 20, and the sound was clear with good bass.
    One of my favorite mods so far. Thanks @Ckatz53
    diablodalton and Ckatz53[OP] like this.
