2020 Tundra 8' Head Unit Retro?
Discussion in 'Audio & Video' started by Shephard_Of_The_Tundra, Jul 25, 2019.
  1. May 3, 2020 at 1:36 PM
    abn_shrek
    abn_shrek New Member
    Jack
    2020 Tundra
    Well I could just get a 2020 unit out of a platinum, Pro or Limited. bound to be wrecked one's up for sale..
  2. May 3, 2020 at 1:38 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    And all of the wiring that goes with it
  3. May 3, 2020 at 1:47 PM
    abn_shrek
    Jack
    2020 Tundra
    2500.00 from toyota new is high as giraffe tail..
  4. May 3, 2020 at 1:52 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I bought a Kenwood this past week after some hemming and hawing. I will give it to @GravityGear about how an aftermarket unit does like just that.. aftermarket. I suppose if you’re driving clients around or something like that in your truck it might matter. But other than that, there is no, and I mean no, comparison between an aftermarket an oem setup in terms of features. Cleaner signal going to your amp, better sound processor, more features on the headunit, connects directly to a dash cam for viewing in your HU, easily able to see front and rear cameras without having to drill holes for a frac harness or put a switch in your dash, can hook up rcas/hdmi plug so you can use a fire stick and watch football while your buddy drives.. the list goes on and on.
  5. May 3, 2020 at 5:32 PM
    3rdGenTundraDC
    3rdGenTundraDC New Member
    MGM
    Central Florida
    14 Tundra DC
    305/50/20 Nitto Terra Grappler G2 Stock, stock, stock.
    You're giving away your age brother. Lol "what's a CD?" See deezNuts younging
  6. May 4, 2020 at 6:46 PM
    pillpusher84
    pillpusher84 New Member
    2024 Silverado High Country
    Just retrofitted a 2020 Tundra 8" Navi unit (non-JBL) into my 2019 Tundra Limited (non-JBL). It required making a complete conversion harness as all conenctions (except for GPS, SXM and FM Antenna) are different. Took a bit to get all parts, and wiring pigtails with pins are super expensive ($14 each x 10 pins needed) for the black Navi ECU connector, but all is done and working perfectly. Love the fact that I finally have a larger screen and Apple CarPlay.
    sgtfluffy16 and Y0TA PR0 like this.
  7. May 5, 2020 at 3:30 PM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    would you mind posting info/source for the connectors/pins? Thanks!
  8. May 5, 2020 at 5:04 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Are you telling me I can take a fixed screen unit like the DNX 696S, and mount it in the double din slot angled?
  9. May 5, 2020 at 5:24 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I think the Kenwood with the cd/dvd slot allow you to change the tilt of the display. I purchased one this past week 1) because sometimes it’s nice to listen to my old cds and 2) I want to be able to adjust my screen angle for glare purposes.
    wolfeman007 likes this.
  10. May 5, 2020 at 6:25 PM
    pillpusher84
    Navi Unit: https://www.ebay.com/itm/293336662235
    Harness: you can now purchase from same seller. we worked together to get the conversion harness sorted out
    I suggest making a "best offer" on ebay. you will likely save some coin that way ... i did :)
  11. May 5, 2020 at 8:42 PM
    TRDPRONORCAL
    TRDPRONORCAL New Member
    Did you have to cut or unpin any wires?
  12. May 5, 2020 at 10:38 PM
    Nightstalker82
    Nightstalker82 New Member
    SAN ANTONIO
    2019 MGM Tundra TSS SR5 4x4
    Call it what you want, but this Kenwood looks 10 times better than what came stock in my 2019. Resistive, dull and weak..now that's out of high school.
    darkknight2014 likes this.
  13. May 6, 2020 at 3:43 AM
    pillpusher84
    No, of course not. We made a conversion harness. I would never cut into factory wiring. This also allows me to put the 2019 unit back into the vehicle should I need to for any reason for warranty / dealer service.
  14. May 28, 2020 at 10:52 AM
    jfisher256
    jfisher256 New Member
    Huntsville, AL
    2019 Super White Tundra TRD Pro
    Did he have a separate listing for the harness on eBay? I don't see anything listed. Or did you message him directly to coordinate the conversion harness?
  15. May 28, 2020 at 10:58 AM
    pillpusher84
    Contact the seller and ask him to send you a special listing for the harness. You can basically do this yourself with all the information I posted in the other thread about this topic. The only thing I can’t source is the USB harness for the 2020 radio. I found everything else as I listed in the other thread.
  16. May 30, 2020 at 12:37 AM
    8675309yine
    8675309yine New Member
    Matthew
    2020 Tundra Crewmax SR5 Texas Edition, silver sky metallic
    If you are interested in selling your old head unit and depending on price, I would possibly be interested. I was letting my son help me install an amp into my 2020, and he crossed some wires and smoked my head unit this morning...
  17. May 30, 2020 at 2:03 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    I just finished installing a Kenwood aftermarket into my 2018 and thus, I have a JBL w/nav OEM head unit that I can sell you if pillpusher will not or can not. Just let me know!
    Preacher
  18. May 30, 2020 at 8:56 AM
    8675309yine
    Matthew
    Thank You, I very much appreciate that! but my truck is non-JBL, and 2020 is wired differently.
  19. May 31, 2020 at 5:01 AM
    #49
    RPKEAN
    RPKEAN New Member
    Ryan
    Subbed...
  20. Aug 5, 2020 at 6:13 AM
    #50
    Flipmode
    Flipmode New Member
    Phil
    Dayton, Texas
    2020 Tundra TRD Pro
    Cold air intake, LED upgraded lights, 295/70/18 Toyo Open Country M/T.
    I am trying to replace mine now. Still really sucks. But having a hard time with a plug and play harness to fit. It’s definitely different. Anyone have any updates since this post?
  21. Aug 20, 2020 at 8:45 PM
    #51
    tAcomaPueblo
    tAcomaPueblo New Member
    Tampa Bay
    2014 SR5 TRD OR CM 4x4
    Any luck?
    I feel like if someone wants to make good money I’d pay for a harness conversion. I keep hoping a 2020 tundra will wind up in the junk yard here so I can snag head unit and wires, but so far no go, and any time a tundra shows up it’s taken right away.
  22. Aug 22, 2020 at 7:20 PM
    #52
    theguapfather
    theguapfather New Member
    erick
    2019 tundra
    custom leather seats , custom wrap , custom led lights interior and exterior
    hey any update were you able to make it work i have a 2019 tundra and i have an offers on a good priced 2020 screen and was thinking of buying and installing but seems that its not plug and play
  23. Mar 23, 2021 at 6:09 PM
    #53
    pillpusher84
    sold my tundra ... so up for sale is my 2020 navi unit with pre-2020 conversion harness for a plug-and-play setup ... posted to the for-sale thread/forum
    ryanwgregg likes this.
  24. Jun 4, 2021 at 9:08 AM
    #54
    heidson
    heidson New Member
    2017 White Tundra Limited 4x4
    Bilstein 5100's all around
    For anyone wondering. I successfully installed a 2020 no-nav unit in my 2017 Limited with a conversion harness I ordered from autoharnesshouse.com. All functions as it should. Much better experience having OEM integrated Carplay.
  25. Jun 4, 2021 at 10:20 AM
    #55
    Why would anyone want the 2020 head unit.....it is absolutely horrible.
  26. Jun 4, 2021 at 11:13 AM
    #56
    heidson
    heidson New Member
    I’m not sure I follow. I would describe the one I previously had as horrible. I now have kept OEM look while gaining a larger display with CarPlay. Works a treat for me
    jsquared22 likes this.
  27. Jun 4, 2021 at 11:47 AM
    #57
    jsquared22
    jsquared22 _________________
    2018 White Tundra Platinum
    Would you share the harness part # and price (or URL) please?
  28. Jun 4, 2021 at 12:21 PM
    #58
    timsp8
    NY
    2nd this. I went to their website and don’t see anything under Toyota that says it’s the right one.
    https://autoharnesshouse.com/T1.html
  29. Jun 4, 2021 at 12:27 PM
    #59
    heidson
    heidson New Member
    I sent them an email (inquiry@autoharnesshouse.com) and got a reply from Brian Doll. I gave him my existing unit details, JVC or non, nav or non, year and trim. Then gave him the same info for the unit I planned to purchase for him to confirm he could make it work. Sounds like the closer you can match to your existing unit, the better. Price was $175 including shipping. This gave me full functionality (except factory nav since I did not purchase a nav unit) including using the existing USB port for Carplay connection. I sourced the head unit on eBay for $300.
    #59
    ryanwgregg and jsquared22 like this.
  30. Jun 14, 2021 at 5:28 AM
    #60
    OGDark Knight
    OGDark Knight New Member
    Jeff
    2019 Platinum, 14 4Runner Trail, 95 Land Cruiser 80
    Trans cooler. Pioneer 8600. TRD Pro suspension.
    May be interested. Is it jbl?
