No rubbing issues with 275/65/20 on TRD Sport
Discussion in 'Wheels & Tires' started by Northern Toyota, Oct 11, 2019.
  1. Nov 5, 2019 at 4:58 PM
    Northern Toyota
    Northern Toyota [OP] New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    I'll have to check mine, I haven't been driving it lately as I use my Tacoma for work and that's been taking a lot of my time lately. No rub marks on my swaybar though, but can't say I've been hard lock yet for certain
  2. Nov 6, 2019 at 10:15 AM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    A 1 inch spacer will probably fix that.
  3. Dec 2, 2019 at 6:49 PM
    favStaR
    favStaR New Member
    2020 Tundra TRD Sport Premium
    Nice truck, I have the exact same one (2020) and would like to get the same tires. Any idea what the factory rim offset is? I was hoping to get blacked out rims but if the offset is different from factory it may introduce rubbing?
  4. Dec 3, 2019 at 5:21 AM
    favStaR
    favStaR New Member
    I’m thinking of maybe going with the 275/60R20 still 1” bigger than stock and should be absolutely no risk of rubbing.
  5. Dec 3, 2019 at 1:58 PM
    Northern Toyota
    Tires and bilstein
    Thanks
    I honesty don't know the factory wheel specs.
  6. Dec 3, 2019 at 1:59 PM
    Northern Toyota
    Tires and bilstein
    I haven't rubbed yet with mine, about 2 months now of various types of driving.
  7. Dec 3, 2019 at 2:26 PM
    AdventureAddict
    AdventureAddict New Member
    Josh
    19 Cement Limited TRD off road
    Looks good! Love my 275/70/18 KO2s!
  8. Aug 25, 2021 at 8:53 AM
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    The tire size look great on your truck. I'm taking delivery of a twin Sport Premium next month and will probably do the same. With the larger LT E range did you see much difference in L/per100K?
  9. Aug 25, 2021 at 4:57 PM
    Brettstation37
    Brettstation37 New Member
    Brett
    Catskills NY
    2020 Tundra CrewMax TRD Sport
    Been on that size tire with my 2020 sport and hasn’t rubbed at all
  10. Aug 26, 2021 at 4:00 AM
    Northern Toyota
    Tires and bilstein
    i honestly can’t say as I drove a few km to the tire shop the day I bought it and had the stock donuts changed. When I factor in 8% larger diameter (I think from memory) my l/100km is decent on the highway. In the 13’s
  11. Aug 26, 2021 at 4:27 AM
    Camprunner
    Camprunner New Member
    2018 trd sport
    None
    I have this size in k02’s
    Speedo is exact now. D rated LT’s. No tub at any time. So much better than stock, however a bit rough on sharp edged road imperfections. I run 45ish cold.
  12. Aug 26, 2021 at 6:10 AM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    I love rubs. Lol
    Blang805 likes this.
  13. Aug 26, 2021 at 9:46 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes that's a common modification done at the dealership so the tires dont rub on full lock. I've trimmed lots of them.
  14. Aug 26, 2021 at 12:25 PM
    BCTRD
    BCTRD New Member
    B.C.
    Not bad considering.
    Have a set of Toyo Open Countries in 285/60R-20's I could try from the last truck (F150) although they're likely too wide for the stock wheels.
    Either way your picture image and with size reference makes it easier to pull the trigger on a replacement tire when mine rolls in so thanks.
    Now to decide on whether or not to buy a set for winter as I came across new Tundra Pro take off's on consignment for $2300...
  15. Aug 26, 2021 at 2:45 PM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    The factory offset(for the 20" sport rims) is +65 I believe. It's pretty far out compared to most. I got a set of SCS wheels with a lower offset and used the stock tires. Offset can be bigger factor than tire width sometimes.
    BCTRD likes this.
  16. Aug 29, 2021 at 6:42 AM
    Northern Toyota
    Tires and bilstein
    For 2020 I’m pretty sure they don’t come with the wings on the skid plate. My dealer wouldn’t even install the oversized tires. I can guarantee you they wouldn’t cut my skid plate.
  17. Aug 29, 2021 at 6:44 AM
    Northern Toyota
    Tires and bilstein
    im pretty sure there’s a guy on here running 285/65/20 or 60 series on stock 20” wheels.
    The trd pro wheels and tires for $2300 Canadian is a decent deal and 18” would ride better than 20” I think.
  18. Aug 30, 2021 at 5:51 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I have a 2020. The stock front skid plate looks exactly like every other skid plate from 2007.
  19. Aug 30, 2021 at 5:53 AM
    #49
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I went from 18" to 20" and no noticeable difference in ride quality.
  20. Aug 30, 2021 at 12:22 PM
    #50
    BCTRD
    BCTRD New Member
    B.C.
    Thanks for the feedback.
    I'll dig around on here and see if the 285/60's will work although I just checked the largest tire size thread and it appears I'd need a 3" lift.
    Although the 285's looked great I can't honestly say they were any better than a 275 other than being a heavy LT tire and sucking more fuel.
    I had a second set of wheels that were 18" and fitted with Micheline true winter LTX AT2 tires and which definitely rode better although we're talking softer rubber, taller sidewall and narrower tire which isn't a fair comparison. It wasn't as planted at high speed or in corners/on ramps which wasn't the intention and the result of a true winter vs hybrid lower profile 20".
    Great tire overall and I'd run the LTX again for winter in a heartbeat.
  21. Aug 30, 2021 at 5:38 PM
    #51
    Northern Toyota
    Tires and bilstein
    must be an sx model thing than, because my 2020 has the skid plate without wings. I can guarantee it wasn’t touched by the dealer. I believe there is a thread on here about the updated 2020 skid plate.
  22. Aug 30, 2021 at 5:39 PM
    #52
    Northern Toyota
    Tires and bilstein
    a lot of variables here, but everything else the same, a 18” wheel has more sidewall and provides more cushion over rough/irregular terrain.
  23. Aug 31, 2021 at 10:11 AM
    #53
    BCTRD
    BCTRD New Member
    B.C.
    Quick derail here...did your door emblems come blacked out or did you use Plasti dip. Looks decent:thumbsup:
  24. Aug 31, 2021 at 1:54 PM
    #54
    normagene
    normagene New Member
    Normagene
    New England
    2021 Cement DC Limited Texas Edition
    Texas Edition
    I’m thinking of getting the BFG KO2s 275/65/18s but I’m not sure if they will fit correctly. I don’t want to buy them and then have an issue.
    Stock tires are: 275/65R/18
    Does anyone know for sure if the same size KO2s will fit? Or do I need something else since the truck will be stock and I do like the rims so I will keep them…for now anyway. No lift/leveling kit with the stock 5 spoke trd off road alloy wheels
    Hope it’s not a foolish question, totally out of my wheelhouse here
    Thanks
  25. Aug 31, 2021 at 2:30 PM
    #55
    BCTRD
    BCTRD New Member
    B.C.
    Try here:
    https://www.tundras.com/threads/official-tundra-wheel-and-tire-setups-pics-and-info.95/
    normagene[QUOTED] likes this.
  26. Aug 31, 2021 at 2:34 PM
    #56
    BCTRD
    BCTRD New Member
    B.C.
  27. Aug 31, 2021 at 2:37 PM
    #57
    redryder
    redryder New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    so, if I'm understanding this correctly this means that I can put some narrow 34s on some 17-inch wheels with stock suspension and be fine?
  28. Aug 31, 2021 at 4:24 PM
    #58
    Northern Toyota
    Tires and bilstein
    i plasti dipped them on day 1
    BCTRD[QUOTED] likes this.
  29. Aug 31, 2021 at 4:30 PM
    #59
    Elduder
    Elduder New Member
    The 2020+ skids do come without the side coverage. Mine was removed for the Pro skid I put on and can confirm that its just the center piece now.
  30. Aug 31, 2021 at 4:31 PM
    #60
    Elduder
    Elduder New Member
    DoctorBAH likes this.
