2020 trd sport upgrade
Discussion in '3rd Gen Tundras (2014+)' started by Northern Toyota, Oct 11, 2019.
  1. Oct 11, 2019 at 9:41 AM
    Northern Toyota
    Northern Toyota [OP] New Member
    2020 Tundra trd sport premium 2005 Tacoma trd off road
    Tires and bilstein
    just picked up my new truck (Canada) and had 275/65/20 ko2's installed. No rubbing issues so far and it looks to me like the must have canged the skid plate because I don't see how the tires could rub on it.
    georgiey22, Berdine, Jaypown and 7 others like this.
  2. Oct 11, 2019 at 10:24 AM
    attillatundra
    attillatundra New Member
    Looks good. I'm glad to know that size will fit stock suspension. It is possible the skid plate was altered. Can you post a few picks with the wheels fully turned to show how close it is to the mud flaps?
  3. Oct 11, 2019 at 10:38 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I believe it is wider tires that would rub the skid plate. Those tires are about a 1/2' narrower than the OEMs on mine. They are about 1-1/2" taller.
  4. Oct 11, 2019 at 10:51 AM
    Northern Toyota
    Tires and bilstein
    I am Canadian and we use the metric system. A 275 tire is 275mm wide, regardless of the aspect ratio.
    Have a look at the image below
    I've read a lot before purchasing this size tire and a lot of people have rub issues on the skid plate.
    I'll get more pictures at lock to lock next time I'm out
  5. Oct 11, 2019 at 10:58 AM
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    That’s the same width as stock.
  6. Oct 11, 2019 at 10:58 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Here in the U.S. we also use metric measurements for tires and I know how to convert them. The aspect ratio only comes in to play with diameter when converting. Maybe I should have mentioned that my OEMs are 285/55/20. This is why I said the 275s are narrower.
  7. Oct 11, 2019 at 11:03 AM
    Northern Toyota
    Tires and bilstein
    I thought of that after as I know the gulf state Toyota's (or something like that) come with those size tires
  8. Oct 11, 2019 at 11:03 AM
    Mike19
    Mike19 New Member
    Chi town
    I’m here in the US too. The OEM tire size mine came with is 275/55/20. Maybe its bigger in TX.
  9. Oct 11, 2019 at 11:04 AM
    Northern Toyota
    Tires and bilstein
    Everything is bigger in Texas I'm told
    Mike19 likes this.
  10. Oct 11, 2019 at 11:55 AM
    attillatundra
    I wonder if a 285/60/20 would fit then? That may rub the skid plate.
  11. Oct 11, 2019 at 11:55 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    True, but difference is TSS version. I did not want 20s but BFGs were worth it to me because the TRD OR tires are shit
  12. Oct 11, 2019 at 11:57 AM
    Northern Toyota
    Tires and bilstein
    You think the trd off road tires are shit, up here the stock 20" tires are dunlop and I wouldn't put them on a civic
  13. Oct 11, 2019 at 12:49 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I read lots about the Dunflops when I had the Tacomas. Fortunately my last Tacoma was a Baja and had BFGs.
  14. Oct 11, 2019 at 1:14 PM
    phabej
    phabej New Member
    2018 White Tundra SR5 Sport CM 4x4
    they are taller than stock? Hows your speedo? Is it accurate?
  15. Oct 11, 2019 at 3:08 PM
    Northern Toyota
    Tires and bilstein
    About 2+ inches taller than stock. Most speedos I've had are slower than gps speed, so usually larger tires put it closer to gps speed but in this case it's likely a little off
  16. Oct 11, 2019 at 3:37 PM
    Mike19
    Mike19 New Member
    Chi town
    My speedo was 57 and GPS had me going at 60.
  17. Oct 11, 2019 at 3:38 PM
    Northern Toyota
    Tires and bilstein
    You running 275/65/20?
  18. Oct 11, 2019 at 3:47 PM
    Mike19
    Mike19 New Member
    Chi town
    Yes and I love it!!! There’s no gear shifting issue or regear needed.
    I replaced the engine skid plate with the RCI engine and skid plate. Definitely no rubbing. The OEM skid plate on the 19 had the “ears” on them which is totally different than the 2020.
  19. Oct 11, 2019 at 6:39 PM
    TILLY
    TILLY New Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Looks great. :thumbsup: Was thinking about doing the same thing until i can convince the wife that these perfectly good, brand new stock rims really need to be replaced for some reason.;) How do you like the ride/noise of your ko2's so far?
    @Mike19. So the 19's plate definitely needs to be trimmed a little then to accommodate this size?
  20. Oct 11, 2019 at 6:45 PM
    Northern Toyota
    Tires and bilstein
    I had ko2's on my 4runner I traded in for 3 years and on my Tacoma for about a year. They are quiet and work great year round. I use my Tacoma in the woods for work and they are great. All have been load range E.
    I'll look again at my skid plate, but when I checked earlier today I don't see how the tires could rub on it. The tires would hit the sway bar imo before anything else
  21. Oct 11, 2019 at 6:51 PM
    TILLY
    TILLY New Member
    Massachusetts
    Thanks for the reply, i appreciate it.
  22. Oct 11, 2019 at 8:28 PM
    Mike19
    Mike19 New Member
    Chi town
    You don’t necessarily have to trim it. You can bend it inward.
    Boerseun likes this.
  23. Oct 11, 2019 at 8:35 PM
    TILLY
    TILLY New Member
    Massachusetts
    OK, Thanks.
  24. Oct 12, 2019 at 8:45 AM
    Northern Toyota
    Tires and bilstein
    Just looked closer at my skid plate and I don't have the wings like the previous year tundras had
  25. Nov 4, 2019 at 10:00 AM
    eRockAZ
    eRockAZ New Member
    Mesa Arizona
    2018 White CM Sport
    I put the same tires on my Sport (2018, stock) over the weekend :thumbsup: No rubbing so far! I did bend the skidplate "wings" ahead of time. The tires feel just fine on the streets... have yet to spend time on the freeways and offroad. And still need to compare speedo to radar to see how much that's changed.
  26. Nov 4, 2019 at 1:56 PM
    rrod
    rrod New Member
    Rob
    2019 Tundra TRD CM 4x4
    6112/ 5160 lift, RRW, Cooper AT3, Westin Outlaw Fr Bumper.
    Been living in Texas a while now...….Hate to say it but that's such BS! Great (and Proud) State but don't drink the Koolaid! The State itself is MASSIVE tho. :crapstorm:
  27. Nov 4, 2019 at 2:29 PM
    Northern Toyota
    Tires and bilstein
    Google says I'm about 4,200 km away. I like where I'm at in Canada. No koolaid has been drank haha
  28. Nov 4, 2019 at 2:40 PM
    rrod
    rrod New Member
    Rob
    LOL! I hear ya brotha (I love Canada), Canadians are some cool people too. Texas is cool, just don't care for how they look down and criticize other States.
  29. Nov 4, 2019 at 2:52 PM
    Mike19
    Mike19 New Member
    Chi town
    No rubbing on the sway bar at full lock? Mine rubs.
  30. Nov 5, 2019 at 7:00 AM
    eRockAZ
    eRockAZ New Member
    Mesa Arizona
    2018 White CM Sport
    Nope, neither direction, forward or reverse. Haven't tested it on inclines/articulation yet...
