2020 TRD Pro Suspension Rebuild Advice
Discussion in 'Suspension' started by thecaptain115, May 7, 2025.
  1. May 7, 2025 at 10:11 AM
    thecaptain115
    thecaptain115 [OP] New Member
    2020 Toyota Tundra TRD Pro Double Cab P275/65R18 Tires 72k miles
    I need to get the Fox struts and shocks rebuilt, and have not been successful in finding someone local to do it, so I am going to have to send them off. I am trying to figure out what a good aftermarket option would be that is a direct swap out that maintains the factory TRD Pro ride height and without having to readjust the rest of the suspension components. I looked at buying factory replacements, and its looking to be $4k+. Ideally, these would be rebuildable as well so I can just swap them when needed.
    I don't do any off-roading, so an external reservoir isn't necessary. Are the Fox 2.5 Factory Series Coilovers going to work for what I am trying to accomplish? What about the 2.0 Performance Series Coilovers?
    edit:
    https://www.shocksurplus.com/produc...ir-2007-2018-toyota-tundra-2wd-4wd-883-02-021
    https://www.shocksurplus.com/produc...rs-front-pair-2007-2018-toyota-tundra-2wd-4wd
    What about the rears? I'm open to other brands, I'm just looking for the easiest option to swap out between rebuilds that maintains ride height and doesnt require making a bunch of adjustments.
  2. May 7, 2025 at 12:09 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    I would rent a car while they are being rebuilt. Far cheaper.
    SC SR5 likes this.
  3. May 7, 2025 at 1:02 PM
    thecaptain115
  4. May 8, 2025 at 5:11 PM
    Diesel5610
    Diesel5610 New Member
    Pine City, NY
    2021 Black TRD Pro
    What about Blistein 6112/5160? I thought I have read guys went with that combo and it was a direct swap. I am about ready to do the same with my 2021.
  5. May 14, 2025 at 4:08 AM
    SC SR5
    SC SR5 New Member
    2014 SR5 CM, 2025 Lifted Platinum
    RC coilovers/level shocks , 2014 Factory lift on the 2025 Platinum
    I actually like someone’s idea about renting a car while rebuilding, I think everything you’ve mentioned is a downgrade
    BillyB likes this.
  6. May 14, 2025 at 4:10 AM
    SC SR5
    SC SR5 New Member
    But actually RC 2” coilovers would do well if you need something to install while the foxes are getting done
