2020 Transmission Drain and Fill
Discussion in '2.5 Gen Tundras (2014-2021)' started by mech_engineer09, May 10, 2021.
  1. Apr 29, 2024 at 11:12 PM
    #91
    BrokeTreeSalesman
    BrokeTreeSalesman New Member
    Jacob
    2015 Silver Tundra SR5 double cab
    What would be absolute worst case scenario if all I did for my 15’ transmission drain it ambient temp then pump the same amount back in? Also sitting at 130k with a very good likelihood of only having one trans fluid change (bought it at 100k)
    is it absolutely necessary to get to temp then check the level?
    Sciosh98 likes this.
  2. Apr 30, 2024 at 3:27 AM
    #92
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I'll get chastised for this, but, here goes: (assuming you do not have a trans temp monitor)
    just warm up the engine for 5 minutes. then check the level.
    I'm sure the Toyota engineers will jump in here & tell you to wait for the exact 105* or whatever.....but the difference in thermodynamic expansion between 80* & 120* is so small, it's laughable.
    for theatre of the mind...I add about a quart more than came out...and then use the check valve to perfect the level.
    and, no. I will not define a trickle.
  3. Apr 30, 2024 at 3:30 AM
    #93
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    On your first I wouldn’t replace exactly what you drain. When I drained and filled recently I found it was a little under filled from the factory.
  4. Apr 30, 2024 at 3:35 AM
    #94
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Sage words.
    overfill it about a qt & then do check valve thing.
  5. Apr 30, 2024 at 4:27 AM
    #95
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    That’s what is kinda funny about the process. Very specific conditions under which to initiate the level check, but the level check itself is a “trickle”.
    A few on this forum have drained very warm fluid, and when it cooled to ambient temp, the difference was barely noticeable if at all.
  6. Apr 30, 2024 at 4:56 AM
    #96
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    It’s best to do it correctly and not as hard as ppl make it out to be; I think you’ll be surprised how straightforward it is. For reasons already stated though, my take is it’s better to have fresh fluid than perfect levels. It’s not very sensitive to thermal expansion and the trans isn’t very sensitive to the fluid level. Three 2.5 gens I’ve done were all ~3/4 quart overfilled from the factory. (Made me doubt my process on the second one so repeated it all….)
    TLDR: use the “return what you took out” method is OK.
    Chip_Tundra likes this.
  7. Apr 30, 2024 at 5:28 AM
    #97
    Terndrerrr
    Music City
    6UR-FE
    I’ve read on here a few times that 2019-2021 trucks were overfilled, possibly for the transmission cooler that isn’t there.
  8. Apr 30, 2024 at 7:31 AM
    #98
    Sciosh98
    Sciosh98 ¯\_(ツ)_/¯
    Stephen
    Tennessee
    2020 Black Tundra 1794 TRD
    What’s the biggest down side to being overfilled? More fluid resistance in the tranny?
  9. Apr 30, 2024 at 12:28 PM
    #99
    Chip_Tundra
    Chip_Tundra New Member
    After pumping fluid into the tranmission, I start the truck and drain from the check plug to whatever the subjective definition of a trickle is. Waiting to get to the temp range is damn near unnecessary. Better to have the fluid a little colder than specified range than to overheat it and restart the process.
    I'm sure there is a decent tolerance in terms of correct level. Being toyota, I wouldn't be surprised if it's +/- .5 qt.
    nobodyintexas[QUOTED] likes this.
  10. Apr 30, 2024 at 3:47 PM
    #100
    bonefish
    bonefish New Member
    Peter
    Treasure Coast Florida
    Also somewhere it says the air temperature can't be above 80 degrees. Pretty hard to do summertime in Florida.
  11. May 1, 2024 at 1:40 PM
    #101
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    You’re probably right. Ain’t no way this fluid level needs to be accurate to the degree some folks are making it out to be. I’m not suggesting that you get it within the nearest gallon, but a half quart seems very plausible for a margin.
    If it were that critical, think how many transmissions would be blowed up by going up or down a hill. Or around a corner…
    I’m no rocket surgeon, but it’s just a big pan with go-juice in it.
  12. May 1, 2024 at 4:23 PM
    #102
    ChesterTundra
    Central FL
    2020 Tundra SR5
    Lmao…rocket surgeon. I’ll be working that into conversations from now on. ;)
  13. May 1, 2024 at 6:18 PM
    #103
    Chad D.
    Chad D. New Member
    Western Oregon
    Yeah, it ain’t rocket surgery.
    Longtime personal favorite, for sure.
    Right up there with “It may not be very big around, but it sure is short.”
    Or, “What could go wrong, if we’re smart about it?”
    ChesterTundra[QUOTED] likes this.
  14. May 1, 2024 at 8:46 PM
    #104
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I mean if you wouldn't check the dip stick either then i guess it wouldn't matter but the check procedure isn't much harder than checking a dip stick. Once you do the check procedure once you'll be like wow, why have i been fighting doing this, it's simple. The difference between a stream and trickle is pretty easy to see when you do it as well.
    ChesterTundra likes this.
  15. May 1, 2024 at 9:11 PM
    #105
    Chip_Tundra
    No one is saying fill it and dont check it. All that's being said is that the acceptable level isn't that complicated. These transmissions are very easy to deal with. As long as you're in the ballpark in terms of fluid level, you're good to go. Theres people who literally just replace the amount of fluid that they drained and never crack open the check plug and theres no reports of those transmissions breaking down lol
  16. May 2, 2024 at 3:24 AM
    #106
    Joe333x
    Joe333x Member
    Boston
    I understand that because I also and somebody who at first just did the drain out and replace what came out method and then I realized how easy it is to just do it correcty. If you're going to crack open the check plug why not do it at the correct temperature? There's even a built-in method you can do with the shifter to know the correct temperature to open it at if you don't feel like buying an OBD tool.
  17. May 2, 2024 at 4:18 AM
    #107
    nobodyintexas
    nobodyintexas What?
    South of Houston
    @Joe333x - I am not addressing you directly...just using your post.
    Nobody asked me, but here goes:
    doing the check level, without temp check, procedure gets you >95% accurate.
    it's not that important to check the temp.
    yes, it's easy to check temp.
    but, it's not really necessary if you simply warm the engine for...say...5 minutes*.
    and if you lack the ability to check the temp, just warm up the engine and now you are >99% accurate.
    sidebar...don't get all balled up over being under temp and then....not get balled up being over temp.
    you have about 3 minutes to check the level when the truck is running - to meet the temperature window.
    *I say this because EVERY time I've D&F'd, it took about 5 minutes to get to temp. so now I don't even check the temp.
  18. May 2, 2024 at 4:36 AM
    #108
    Chip_Tundra
    I'm confident in my method because by the time im done draining through the check plug, my scangauge tells me im within toyota's specified temp range anyway. Like another person said, it doesn't take that long to wait to be 99% correct, but damn, I don't have a lift and getting under the truck while its running and the cat is hot is not fun for me anymore.
    BR73 and bikedennis like this.
  19. May 2, 2024 at 4:39 AM
    #109
    nobodyintexas
    nobodyintexas What?
    South of Houston
    <read this in a happy tone - as I laughed when I thought of it>
    and for you guys that don't do the transmission fluid check level procedure-
    are y'all the same guys that change your oil & don't check the dipstick?
    because it's the EXACT same thing.
    Joe333x likes this.
  20. May 2, 2024 at 5:50 AM
    #110
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    I check the temp because.......I like following procedures when it comes to vehicles :D.
    However, given the fact that the procedure involves the highly subjective "trickle", I don't think it is that sensitive to over or under filling, to the point that if the procedure weren't followed and you just replaced what was drained, that you'd probably be totally fine.
    Where I think the procedure helps the most is if you add a cooler and then you actually need more fluid, affecting your baseline.
    Or, when you are an idiot like me and accidently knock over your drain pan and don't know how much you actually drained out.
    nobodyintexas and Chip_Tundra like this.
  21. May 2, 2024 at 9:00 AM
    #111
    Joe333x
    Joe333x Member
    Boston
    Technically no one lacks the ability to check the temperature since you can follow the shifter method that will flash at the correct temperature.
  22. May 2, 2024 at 12:26 PM
    #112
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Please expound on the shifter method
  23. May 2, 2024 at 12:45 PM
    #113
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    Joe333x likes this.
  24. May 2, 2024 at 1:06 PM
    #114
    Joe333x
    Joe333x Member
    Boston
    Only because I know people are lazy, here's a link to bring you right to the procedure.
    https://youtu.be/NUAuGmDGntY?t=345
    Here is a post from someone with a 2020 that I guess is missing the pin in the OBD that you need to jump
    https://www.tundras.com/threads/tra...jumper-on-a-2020-trd-pro.126414/#post-3333227
    Apparently newer ones do not even need the jumper wire
    https://youtu.be/XTU_Jt7OJZk
    PKFan[QUOTED] and nobodyintexas like this.
  25. May 21, 2024 at 5:34 PM
    #115
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    So I decided to drain and fill my tranny this past week on my 2020. I felt like it was under filled as it was always a little rougher shifting when cold. Drained out just a hair under 4 quarts and added 5. Used the check valve once it hit 99 degrees and let it get to a point where the stream started to wave a bit right about the 40:02 mark of the video on post #7. Maybe just a bit longer than that. After measuring what I drained out from the check valve it was right around a half a qt. Seems to shift well and it’s summer now so can’t really judge the shifting in the cold, did I not let it drain enough or is it possible I was about 1/2 qt low?
  26. May 31, 2024 at 8:26 AM
    #116
    TX_Tundra214
    TX_Tundra214 New Member
    2021 White Tundra SR5 4x4
    Bone stock... for now
    Bergy24 likes this.
  27. May 31, 2024 at 8:30 AM
    #117
    TX_Tundra214
    My first test drive after changing mine i was about 3/4 quart low and noticed rough downshifts. once i figured out the temp check mode later that day, topped her off and she was golden. Shifting a tiny tiny bit rough when cold is normal though, you could just be hyper analyzing it.
    Nbab23[QUOTED] likes this.
  28. Jun 8, 2024 at 3:29 PM
    #118
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Yeah that’s kind of my thing. I’m a little OCD at times and I did double check my level and it was all good.
  29. Jul 8, 2024 at 2:07 PM
    #119
    drew.c.114
    drew.c.114 New Member
    Andrew
    Gilbert, AZ
    2021 Trail Edition
    After reading the procedures and watching the videos, I’m still left with 1 question in regards to doing this fluid swap. When it says to make sure the truck is level, should I be checking the frame or the ATF pan? Does it matter??
    I have a Bilstein 5100 lift (top setting) with 1” shackles in the rear so I’m about 1.25” higher in the front than stock.
    I have a scan tool and am able to monitor ATF temps, so this is the only thing that I’m not 100% sure on.
  30. Jul 8, 2024 at 2:22 PM
    #120
    Chip_Tundra
    Doesn't matter too much. I jist get the truck on a flat surface and go from there. If you want to get more precise, get the pan level.
    drew.c.114[QUOTED] likes this.
