2020 sr5 grill removal
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2020cement_tundra, Feb 23, 2021.
  1. Feb 23, 2021 at 7:03 PM
    2020cement_tundra
    2020cement_tundra [OP] New Member
    Nick
    Changing my headlight bulbs and need to remove grill, I watched a YouTube video on what appeared to be a 2020 sr5 that showed two tabs one one each side on the bottom corners that needed to be depressed. But looking at mine I don’t see them. Anyone have any info/tips for removal? Also replacing fog light bulbs but appears it’s easy access trough plastic panel above front mud flap
  2. Feb 23, 2021 at 7:33 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Two tabs just as you described. Lean the grill out at the top and get a flashlight a look down in the corners. The tab is like a U shape and pushing down on the tab with a long flathead screwdriver will release it. Change the fog lights when the headlights are out. Much easier and you don't have to lie on your back.
    BravoDeltaRomeo likes this.
  3. Feb 23, 2021 at 7:35 PM
    2020cement_tundra
    Nick
    Ok maybe I couldn’t see the tabs with the grille still bolted in. Thanks
  4. Feb 23, 2021 at 7:36 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That would definitely be it!
