2020 Sequoia TRD Pro Grill conversion
Discussion in '2nd Gen Tundras (2007-2013)' started by Jbtaco2002, Oct 26, 2019.
  1. Jun 27, 2020 at 10:27 AM
    #211
    TheBigBlackTundra
    TheBigBlackTundra New Member
    Josh
    2007 Toyota Tundra Limited Crew Max
    6 inch Rough Country lift, 37 inch Nitto MTs, 18 inch Moto Metal Wheels.
    Gotcha, thanks @BigArt! Gonna order the rest today.
    here’s a little preview
  2. Jun 27, 2020 at 1:26 PM
    #212
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    did you get all the hw called out in this thread? if bought only the grill and bulge then missing three key components, multiple pieces in each
    53118-0C030 and 53117-0C030 (brackets)
    90119-A0156 bolts (qty 10)
    53191-0C010 plastic clips to receive the new bulge (qty 5)
  3. Jun 27, 2020 at 1:33 PM
    #213
    sensei
    thanks. these are top shelf quality so expect them to be priced accordingly. https://headlightrevolution.com/toyota-tundra-07-13-xb-led-headlights/ if you keep an eye out in this forum sometimes they have 20% off sales. next one i believe is targeted for black friday later this year.
  4. Jun 27, 2020 at 3:56 PM
    #214
    ZenkiS14
    ZenkiS14 New Member
    2012 Tundra TRD Rock Warrior
    Now, correct me if I'm wrong, but if you have a 2010+ Tundra, you will not need the brackets, because the 10-13's came with the correct brackets already, right?
  5. Jun 27, 2020 at 5:01 PM
    #215
    TheBigBlackTundra
    Josh
    Yea I went back and read thru the thread after @BigArt told me the part numbers were higher in the thread. Just ordered my brackets, bolts, and clips.
  6. Jun 27, 2020 at 8:18 PM
    #216
    BigArt
    BigArt New Member
    2008 Tundra Crewmax Limited
    Looking good! got yourself a new 2020 Tundra.
  7. Jun 28, 2020 at 5:56 AM
    #217
    AnotherKaren
    AnotherKaren New Member
    2008 Toyota Sequoia SR5
    Just joined forum because I came across your thread. I've got a 2008 Sequoia and plan on doing the same update to the lights and grille. On the wiring harness did you get option 1 or 2? Is the only difference that option 2 has the amber DRL and option 1 is white DRL? I think I like having the amber. Just thought I would get your opinion on the options or if you would change.
    I just ordered the LED lights. Can you tell me what the part number is for the small plastic trim piece below the headlights? Any other parts you need?
    So far I have ordered:
    TRD Pro Grille
    Buldge
    2018+ LED Headlights
    Wiring harness
    need to order small trim piece below headlights.
    Anything I am missing?
    Thanks!
  8. Jun 28, 2020 at 6:54 AM
    #218
    BigArt
    BigArt New Member
  9. Jun 28, 2020 at 8:51 AM
    #219
    AnotherKaren
    Thanks! I think I like the amber on when DLR's are on also.
    BigArt[QUOTED] likes this.
  10. Jul 1, 2020 at 12:31 PM
    #220
    Swatdude1
    Swatdude1 New Member
    Phoenix, AZ
    2008 Tundra Crewmax Limited TRD
    Icon 3.0 Coilover Stage 2, SDHQ Traction Bars, Nitro 4.88 gears, AlphaRex Headlights, Katskin Leather, Method 17" Vex with 35"Toyo M/Ts, Eaton Rear Locker, N-Fab MRDS
    That is my understanding.
  11. Jul 1, 2020 at 7:36 PM
    #221
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    If you need the 2010+ brackets, it's worth shopping around. When I upgraded my 08 to a 10+ grille I found them on Rockauto for the best deal, but prices did vary.
  12. Jul 3, 2020 at 9:19 AM
    #222
    Swatdude1
    Phoenix, AZ
    For lack of being able to come up with something better, I bought the weatherstrip on Amazon. How did you apply it, just adhesive to the bottom with curve facing motor? Because it still leaves more than a quarter inch exposed on mine. Thanks.
  13. Jul 3, 2020 at 11:47 AM
    #223
    BigArt
    BigArt New Member
    I attached to the top of the bumper[​IMG]
  14. Jul 3, 2020 at 3:58 PM
    #224
    Swatdude1
    Phoenix, AZ
    That makes more sense.
  15. Jul 8, 2020 at 11:14 AM
    #225
    TMC
    TMC New Member
    Tom
    2007 Crewmax
    I wanted to thank the folks that contributed to this thread... Jbtaco2002 and BigArt especially. I was able to get this swap done on my 07 Crewmax ltd, and I'm really digging it. I haven't decided whether to pull everything back off to colormatch or not. Getting the grill on and off is no sweat, but it's a bit stressful wrestling with the bulge. Once it locks in, it's really in there and I haven't found anywhere online that shows the proper way to remove it. I'd hate to do my usual "fiddle with it til something cracks" method. Anyhow, many thanks!
    Busa, Swatdude1, omgboost and 2 others like this.
  16. Jul 8, 2020 at 12:03 PM
    #226
    sensei
    looks great. yeah i wrestled with that bulge. i first tried to put the grill and bulge together then install on truck and that wasnt working. then spent another 20min trying to get the bulge seated properly.
    TMC[QUOTED] and Swatdude1 like this.
  17. Jul 8, 2020 at 12:06 PM
    #227
    Maxi13
    Maxi13 GuttenTight
    Montucky
    2020 Cement Sr5 TRD OR
    Nudding yet
    That looks great! Especially with the Sequoia headlight mod. I'm on the fence, mainly due to cost, but its great to see everyone's efforts and how great they look. I have a LTD CM too, and the chrome is getting to be a bit too much...
    TMC and Swatdude1 like this.
  18. Jul 8, 2020 at 1:26 PM
    #228
    ZenkiS14
    ZenkiS14 New Member
    I'm gonna try to get mine installed later today. I'll post up pics. I assume install is pretty straight forward. Any notes I should be careful of?
    Maxi13 likes this.
  19. Jul 8, 2020 at 1:43 PM
    #229
    Maxi13
    Maxi13 GuttenTight
    Montucky
    Nudding yet
    what's the best source for the grills these days? I have a 2013 so don't need the mounts etc.
  20. Jul 8, 2020 at 1:56 PM
    #230
    TMC
    TMC New Member
    Tom
    2007 Crewmax
    There are some tabs underneath the bulge that if you don't get them to slide under the matching part of the grill, it won't pull up flat... and you won't know that until you have it all jammed on there. Don't ask me how I know. The little rubber gap filler won't sit flat on the hood if you don't get those tabs hooked under just right. I fixed it but that was not a fun extra 10 minutes. I know that doesn't help much, but all I can say is don't rush that one part.
  21. Jul 8, 2020 at 2:02 PM
    #231
    TMC
    TMC New Member
    Tom
    2007 Crewmax
    If you have a local dealer that participates in the parts.toyota.com site, that's where I found the best deal locally. I had to drive an extra 20 minutes, but saved $200 over the dealer near my house. People also like Sparks Toyota, although I haven't bought anything from them.
    Maxi13[QUOTED] likes this.
  22. Jul 8, 2020 at 2:36 PM
    #232
    Maxi13
    Maxi13 GuttenTight
    Montucky
    Nudding yet
    My addled brain is having trouble sorting parts for my 2013 Tundra. For those of you with 2010+ Tundras, parts list is:
    Black grill PT363-0C200-BL;
    Bulge 53111-0C240-C0;
    ebay screws and clamps: 90119-A0156 (qty 10) 53191-0C010 (qty 5) BUT looks like you have to buy the brackets also? If not needed, any source for just the hardware?
    Amazon weather strip: https://www.amazon.com/dp/B077P632FC?ie=UTF8&psc=1
    No new brackets needed, correct?
  23. Jul 8, 2020 at 2:55 PM
    #233
    accutech
    accutech New Member
    Irvine, California
    2012 Black Crewmax Platinum
    Pro Comp Pro Runner SS shocks. TRD front and rear sway bars. MB TKO 20x9 (+25 offset) black wheels. Cooper Discoverer ATP 275-65-20 tires. Alpharex LED headlights. Gator EFX Hard Fold Tonneau Cover.
    I’m with you on this. I re-read this post a zillion times and my conclusion is you don’t need anything other than the grill and bulge to mount on later year 2nd gens.
    I looked at my chrome grill from underneath and all the bolts / screws look like they will swap over no problem.
    I also bookmarked the weather strip to mount on the bumper itself to hide the gap.
    I think that’s that.
    Let me know if you find out otherwise.
  24. Jul 8, 2020 at 3:15 PM
    #234
    Maxi13
    Maxi13 GuttenTight
    Montucky
    Nudding yet
    OK great! So I'm NOT crazy...except for all the silly mods I am doing! I guess the clips would be optional if the originals break. I'd like to get them, but don't want to buy the whole kit...am pricing grill now from my local dealer but I'm not holding my breath. When I did the Pro grill on my Tacoma a bunch of the clips on the original broke, and it was brand new. I'll post back if I find another singular source for them.
  25. Jul 8, 2020 at 3:27 PM
    #235
    accutech
    accutech New Member
    Irvine, California
    Best price I found for the grill is $355.09 and bulge / Grill molding $58.79.
    If you have a discover credit card they currently have 5% back on PayPal! Cha Ching!
    Maxi13 likes this.
  26. Jul 8, 2020 at 3:33 PM
    #236
    sensei
    we would need someone with a 10-13 model to chime in but my understanding is those later early gen2's don't need the brackets. i have an 08 so cannot say for sure. i needed them. good luck.
  27. Jul 8, 2020 at 6:07 PM
    #237
    BigArt
    BigArt New Member
    I can tell you from experience taking the bulge back off is not easy.
    I had to remove it because I was impatient and installed before I received the brackets.
    I broke a few clips getting it off and had to re-order some of the clips that came with it. sucked...
  28. Jul 8, 2020 at 6:13 PM
    #238
    accutech
    accutech New Member
    Irvine, California
    Well.... ordered and awaiting for email so I can go pick them up from my local dealer.
    Hopefully I don’t need any other hardware for install.
    Gotta go home and convince my wife that this was a smart decision. HAHAHA!
  29. Jul 8, 2020 at 10:08 PM
    #239
    sensei
    my 'go to' online dealers for toyota parts in general are:
    https://www.sparksparts.com/ coupon code TundraCrew
    https://parts.toyotaofcoolsprings.com/ coupon code forum20
    have to keep an eye on shipping charges though.
  30. Jul 9, 2020 at 7:32 AM
    #240
    Maxi13
    Maxi13 GuttenTight
    Montucky
    Nudding yet
    Thanks sensei. I am checking with my local dealer but they are always higher than anything online. And yes, shipping adds a bit of $$.
