2020 Sequoia TRD Pro Grill conversion
Discussion in '2nd Gen Tundras (2007-2013)' started by Jbtaco2002, Oct 26, 2019.
  1. Apr 18, 2021 at 11:16 AM
    #541
    TXTundraFan
    TXTundraFan New Member
    For those that have filled some of the gap with weatherstripping, is there a benefit other than hiding some of the gap?
  2. Apr 18, 2021 at 1:08 PM
    #542
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    It’s just to hide the gap
    Cg13055 and TXTundraFan[QUOTED] like this.
  3. Apr 21, 2021 at 7:25 PM
    #543
    Uppermost
    Uppermost New Member
    Just wanted to say thanks to this thread. I got my grille done. It turned out fantastic
  4. Apr 21, 2021 at 7:28 PM
    #544
    Uppermost
  5. May 4, 2021 at 10:29 PM
    #545
    TheBeast The Beach
    looks like a different truck. great choice !
    MTRock likes this.
  6. May 19, 2021 at 12:49 PM
    #546
    shdwkeeper
    shdwkeeper New Member
    2013 Magnetic Gray Tundra 4x4 Limited CM
    Diamondback Bed Cover (Line-X) Bed Rug Mirror Caps (Paint Matched) Door Handles (Paint Matched) 2020 Sequoia TRD Grill Conversion Morimoto XB Fog Lights Alpharex Pro Jet Black Headlights HIKARI 2021 Acme-X H7 LED Bulbs 6112 (top setting) / 5160 Combo @Coachbuilder1 Differential Drop Kit 1.00" @Coachbuilder1 Coilover shims (2 drive-side 1 passenger side) @Coachbuilder1 Front Bump-stop extensions @Coachbuilder1 Front Bumper Shims @Coachbuilder1 +3 Shackles Fuel Vector 18" +20 Wheels 35x12.50x18 Nitto Ridge Grapplers RCI Off-road Engine Skid plate Desert Eagle Off-road transmission/catalytic converter protection plate Interior: VLEDs 5K cabin interior + LED strip footwell Coupe Custom Battery Mount WeatherTech Floor Mats
    I just did the grill conversion as well on my 2013 CM. Here are the before and after photos. Next comes wheels and tires, than headlights.
    20210516_182844.jpg20210517_163848.jpg 20210516_182852.jpg 20210517_163844.jpg
    When pulling off old grill you will probably break the 2 end tabs, I guess they are called break away clips, also you may have some of the yellow tabs break. If so, here are the part numbers for those. The new grill comes with the tabs on them already for the 2nd Gen Tundras. I found it easier to attach the bump to the grill before attaching it to the vehicle, learned the hard way and ended up removing everything and breaking the end tabs on new bump. That's why I bought extra tabs to replace.
    Oey12, hhenry_, WVI and 6 others like this.
  7. May 19, 2021 at 2:12 PM
    #547
    TheBeast The Beach
    a lot better imo ! once you get new headlights it's gonna be very nice.
  8. May 24, 2021 at 11:18 AM
    #548
    shdwkeeper
    Will a 2013-2020 sequoia bumper cover fit onto the 2nd gen Tunrdas plug/play?
  9. Jun 5, 2021 at 3:28 PM
    #549
    Oriolesfn12
    Oriolesfn12 New Member
    Will this work on a 2013 Rock Warrior Tundra?
    MTRock likes this.
  10. Jun 5, 2021 at 3:32 PM
    #550
    shdwkeeper
    It should, its a 2nd gen. Just replaced my headlights as well.
    MTRock likes this.
  11. Jun 5, 2021 at 6:34 PM
    #551
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    yes, but you will also need the upper support bar. I think it was about $50.
    now keep in mind I went from one piece tundra rock warrior to sequoia conversion.
    it might be different going from tundra two piece to sequoia one piece.
  12. Jun 5, 2021 at 9:25 PM
    #552
    YotaMando
    YotaMando New Member
    David
    Idaho
    2012 Limited CM 4X4
    Finally received both pieces via sparkparts. Very happy with the results.
    MTRock and hhenry_ like this.
  13. Jun 5, 2021 at 10:19 PM
    #553
    shdwkeeper
    Nice, headlight time
    YotaMando[QUOTED] likes this.
  14. Jun 5, 2021 at 10:21 PM
    #554
    shdwkeeper
    My bumper is a 1 piece as well I believe
  15. Jun 7, 2021 at 5:50 PM
    #555
    Oriolesfn12
    Hey man! Can you send me the link for this grill? I want it for my 13 Tundra!
  16. Jun 7, 2021 at 6:25 PM
    #556
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Work on mine!
  17. Jun 7, 2021 at 7:37 PM
    #557
    farnsrocket
    farnsrocket New Member
    I got my grill and bulge from Moderntoyota.com.
    The lights are from Yotaleds.com
  18. Jun 19, 2021 at 11:24 AM
    #558
    raymond_hb
    raymond_hb New Member
    Oakland, CA
    07 Tundra Limited 2WD
    Do you have a description or link to the headlights?
  19. Jun 19, 2021 at 1:52 PM
    #559
    shdwkeeper
    raymond_hb[QUOTED] likes this.
  20. Jun 29, 2021 at 6:38 AM
    #560
    ToyoJonTX
    ToyoJonTX New Member
    Did you paint it? I don't see Silver Sky Metallic as an option.
    TundraTRD08 likes this.
  21. Jun 29, 2021 at 7:20 AM
    #561
    ToyoJonTX
    Did you install it on the bumper or on the grille itself? My bumper is on the way.
  22. Jun 29, 2021 at 8:13 AM
    #562
    shdwkeeper
    So you have any pics you can share of your truck and your bumper? You in SoCal also right?
  23. Jun 29, 2021 at 11:22 AM
    #563
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    heres a couple,
    so it’s a give and take with the sequoia bumper. They have slightly different body lines so it doesn’t line up perfect with tundra bumpers. So my high clearance bumper by resz has slightly different lines. But it closes the gap with the grill nicely
    Yeah I’m in SoCal
  24. Jun 29, 2021 at 11:37 AM
    #564
    shdwkeeper
    So did you order the full sequoia bumper and than cut it, paint it etc...
  25. Jun 29, 2021 at 11:46 AM
    #565
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    Yeah. I found one with bottom damage on offer up for cheap. Cut and paint myself
  26. Jun 29, 2021 at 11:59 AM
    #566
    shdwkeeper
    Ok good to know. I'll probably do same thing.
  27. Jun 30, 2021 at 4:52 AM
    #567
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    Has anyone found a light bar that fills that gap nicely? I put some foam in there but it still bugs me...
    Mattyc likes this.
  28. Jun 30, 2021 at 8:58 AM
    #568
    shdwkeeper
    It would have to be a modified mounting bar as the hood release comes right down in middle of it.
  29. Jul 3, 2021 at 5:36 PM
    #569
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    I really like the idea and look, but can’t do that gap or weather stripping. My OCD would keep me up all night. I am curious if a talented body shop could graft or fab the bottom to fit correctly.
    PhotoNerd[QUOTED] likes this.
  30. Jul 3, 2021 at 9:55 PM
    #570
    shdwkeeper
    Just go get a Sequoia bumper as that would fit and fill the gap.
    omgboost and MTRock like this.
