2020 pro lower ball joint bolts
Discussion in '2.5 Gen Tundras (2014-2021)' started by captkrun, May 7, 2020.
  1. May 7, 2020 at 6:14 PM
    captkrun
    captkrun [OP] New Member
    Is the torque spec really 230 on these?
    I don't have a torque wrench that goes that high. Can I just crank them down with a breaker bar?
  2. May 7, 2020 at 6:17 PM
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    They are 221. I had to purchase a torque wrench that went that high. Didn’t want to chance it.
  3. May 7, 2020 at 6:20 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Why are you already doing ball joints on a 2020?
    FrenchToasty likes this.
  4. May 7, 2020 at 6:25 PM
    captkrun
    CB spacer kit on top of the coilovers. I had to remove it to lower the arm.
    EDDO likes this.
  5. May 7, 2020 at 6:26 PM
    captkrun
    loctite required as well?
  6. May 7, 2020 at 6:29 PM
    vhstejskal
    Vic
    I would just torque and Check periodically for movement using a yellow or white marker. 221 pounds is a good amount to begin with. Using loctite may cause issues given the difference between dry and wet torque specs.
    Nightshade Tundra likes this.
  7. May 7, 2020 at 8:39 PM
    captkrun
    Autozone rental and good. :)
  8. May 7, 2020 at 11:28 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I hit mine with a 1/2 Milwaukee impact pretty snug then just tightened tf out of it by hand. Havent had any issues. May be a tad bit tighter than recommended, but it wont hurt anything because there is no gasket to compress. And the chances of you breaking the bolt by hand are pretty slim
  9. May 8, 2020 at 4:40 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    WFD473 and MS22 like this.
  10. May 8, 2020 at 7:30 AM
    cooper4x4
    cooper4x4 New Member
    2016 Tundra SR5
    Always torque those to spec. Bad day if they back out or shear.
  11. May 8, 2020 at 4:08 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Why loosen these bolts with this crazy torque spec? I’ve swapped out my suspension 3 times and just removed the knuckle from the UCA. Torque spec on that bolt is only 85 ft lb and easy to do.
  12. May 8, 2020 at 4:21 PM
    glowblue
    VA
    If your installing like for like that method might be better, a lot of us are installing leveling kits so removing the LCA bolts actually might be a better way for the reassemble.
    To each his own...it really wasn’t a big deal with the right tools. Easy to break the bolts loose and reinstall with the proper method.
    Sumo91 likes this.
  13. May 8, 2020 at 4:23 PM
    ZPhilip
    Philip
    West Chester, PA
    It want fun but I got the 6112 and Pro coilovers in there, swapping out stock stuff. I just didn’t want to buy another torque wrench.
    glowblue likes this.
  14. May 8, 2020 at 4:29 PM
    glowblue
    VA
    I did mine with all hand tools, next time I’m buying impact wrenches.
    Ebrperk and Sumo91 like this.
  15. May 8, 2020 at 4:36 PM
    Sumo91
    TN
    https://milwaukeetool.com/Products/Power-Tools/Fastening/Impact-Wrenches/2763-22
    This is my all time favorite impact. Home depot had a sale for it awhile back, $250 with an 8 amp battery. Worth every penny and has more torque than you should ever need, with different torque settings. It makes quick work of anything
    MS22 likes this.
  16. May 8, 2020 at 4:40 PM
    glowblue
    VA
    Sumo91[QUOTED] likes this.
  17. May 9, 2020 at 11:38 PM
    emdcksn
    emdcksn New Member
    Eugene
    Eugene OR
    2021 MGM Tundra Platinum CrewMax
    Red loctite. Mine had it from the factory when I lifted my truck.
  18. May 10, 2020 at 7:29 AM
    blanchard7684
    blanchard7684 New Member
    I second the Tekton wrench. I got it to put new front hubs on a mustang. Quality unit.
  19. May 10, 2020 at 7:43 AM
    glowblue
    VA
    That’s what I love about DIY projects - justifies buying new tools!
  20. Sep 16, 2020 at 6:30 AM
    MRsminns
    MRsminns New Member
    2014 Tundra SR5 4x4
    Idk if I'm weak af, but could not torque down those 2 bolts to 221 ft lbs, me and friend also tried to trq it down but no click on my 300 ft lb torque wrench I bought from harbor frieght..how did you guys manage to trq it down? idk if the trq wrench I bought is working properly because 221 ft lbs is alot. Just dont want it to fail when im driving down road.
  21. Sep 16, 2020 at 6:40 AM
    TRD423
    TRD423 New Member
    Chattanooga
    17 SR5 TRD 4X4
    -20% tint all around and over factory -2” ToyTec leveling spacer -275 70 18 BFG KO2 -TRD duel exhaust -TRD Pro skid plate -TRD Pro grille -TRD sway bar -TRD performance air filter -vinal wrapped front bumpers -Xenon Vision led head/ fog lights and interior lights -AJT Design billet shift knob
    For me, ass on the ground and a foot on the frame was all the leverage i needed to get it to click..i am 6’2 so that helps
  22. Sep 16, 2020 at 6:49 AM
    MRsminns
    MRsminns New Member
    2014 Tundra SR5 4x4
    Ok I'll try that but unfortunately I am 5'4 158 lbs .. thanks for the reply!
  23. Sep 16, 2020 at 7:12 AM
    glowblue
    VA
    Similar with me. Might try Using a pipe To Slide over the handle to extend your leverage with your torque wrench.
    MRsminns likes this.
  24. Sep 16, 2020 at 4:11 PM
    ZPhilip
    Philip
    West Chester, PA
    Test out the torque wrench in increments. Go 100, then 150 ft lbs to see if it even clicks for you.
  25. Sep 16, 2020 at 5:00 PM
    palehorse
    palehorse @grey_ghost_trdpro
    Mount Pleasant, SC
    2020 TRD PRO
    I used my Milwaukee beast on setting 2. I have sheared 1/2" bolts on setting 3.
