2020 Platinum door handle locking sensor
Discussion in '2.5 Gen Tundras (2014-2021)' started by gowithit13, Jan 31, 2020.
  1. Jan 31, 2020 at 6:30 AM
    gowithit13
    gowithit13 [OP] New Member
    Ray
    2023 Platinum
    I have had my 20 Platinum for a few weeks and I noticed an issue with locking the vehicle.
    I have been talking with Toyota and I'm not getting a solution other than I have to keep my head lights in the off position for it to lock properly.
    When I turn off the truck and get out/close the door the door handle sensor will not lock the truck for 10 seconds( when the lights on the inside dim out)
    Is any one else having the issue?
  2. Jan 31, 2020 at 6:31 AM
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Did you swap your interior bulbs and cargo lights for LEDs?
  3. Jan 31, 2020 at 6:32 AM
    gowithit13
    Ray
    2023 Platinum
    Yes I did, is this the problem?
  4. Jan 31, 2020 at 6:32 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    you talking about locking it with the handle? Didn't know it'll do that.
  5. Jan 31, 2020 at 6:33 AM
    Ckatz53
    Ckatz53 Newish
    MD
    Yes. Having LEDs in the cargo lights in the 3rd brake light affect the receptor in the shark fin. Turn your cargo lights to always off and try that. If my cargo lights go on or off when opening/closing doors or starting and turning the vehicle off, I will not be able to lock it until the cargo lights turn off.
  6. Jan 31, 2020 at 6:33 AM
    gowithit13
    Ray
    2023 Platinum
    Yes the 2020 Limited, Platinum and 1794 come with this.
  7. Jan 31, 2020 at 6:35 AM
    gowithit13
    Ray
    2023 Platinum
    I will try that.
    If that is the case I will just put the factory cargo bulbs back in.
  8. Jan 31, 2020 at 6:35 AM
    Ckatz53
    Ckatz53 Newish
    MD
    I may have misread and you're more concerned about the auto locking feature on the door handle. I didnt even know my 2020 Limited had this.
  9. Jan 31, 2020 at 6:36 AM
    Ckatz53
    Ckatz53 Newish
    MD
    Apparently higher end (ie. More expensive LED kits) dont cause this interference. To me, my $20 Amazon kit sufficed and I just only turn the cargo lights on when I need something in the bed.
    Bigolbaddy likes this.
  10. Jan 31, 2020 at 6:37 AM
    gowithit13
    Ray
    2023 Platinum
    I have VLEDS, but I will still try it.
  11. Jan 31, 2020 at 6:42 AM
    gowithit13
    Ray
    2023 Platinum
    It worked!!!
    Thx for your help.
    purplenova and Ckatz53 like this.
  12. Jan 31, 2020 at 6:44 AM
    Bigolbaddy
    Bigolbaddy New Member
    Ben
    Fort Worth
    2020 MGM 1794
    An you link the bulbs you got on Amazon?
    Thanks
  13. Jan 31, 2020 at 6:47 AM
    Ckatz53
    Ckatz53 Newish
    MD
    Awesome, no problem.
  14. Jan 31, 2020 at 6:50 AM
    Ckatz53
    Ckatz53 Newish
    MD
    Fyre Flys 18 Piece White LED Interior Lights for 2007-2019 Toyota Tundra 6000K 5050 Series SMD Package Kit and Install Tool https://www.amazon.com/dp/B07L45QV88/ref=cm_sw_r_cp_apa_i_G5dnEbCB77DW9
    They offer a brighter set if that's your thing. This is plenty bright (I have grey leather and interior so it reflects a lot of the light and looks brighter).
  15. Jan 31, 2020 at 8:55 AM
    Overisland
    Overisland New Member
    Tony
    Polson, MT
    2020 Tundra Voodoo Blue Sport
    I have a 2020 TRD Sport with touch handle locks. I have LED bulbs in the interior, license plate lights, reverse lights and cargo area. Pretty much everywhere except for the visors. My handles work as they should and I always leave my headlights set to auto. Sounds like there is an issue with yours.
  16. Jan 31, 2020 at 9:26 AM
    gowithit13
    Ray
    2023 Platinum
    So far it is working with the cargo light turned off but I'm gonna keep an eye on it.
    I still have Toyota looking into it.
    I feel like I'm getting some run around because they don't seem to know why this is happing either.
    The Platinum they have on the lot is doing the same thing.
    I'm gonna put the factory bulbs in and see what it does.
    Thanks for your comments.
    Overisland likes this.
  17. Jan 31, 2020 at 10:14 AM
    Paulismydog
    Paulismydog New Member
    2020 Black Limited Double Cab
    I was unaware of the auto locking function. What are the settings and the procedure? Thanks. Bob
  18. Jan 31, 2020 at 10:16 AM
    gowithit13
    Ray
    2023 Platinum
    Sorry, this is not an auto locking function it is the touch sensor on the door handle for locking purposes.
  19. Jan 31, 2020 at 10:19 AM
    gowithit13
    Ray
    2023 Platinum
    This is park of the keyless (push button) start.
  20. Jan 31, 2020 at 10:19 AM
    gowithit13
    Ray
    2023 Platinum
    Sorry "part"
  21. Jan 31, 2020 at 10:42 AM
    Paulismydog
    I figured it out. Never even knew. I am a stupid stupid man.
  22. Feb 3, 2020 at 6:43 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Can that sensor unlock, can you unluck all doors with it?
  23. Feb 3, 2020 at 6:51 AM
    coTony
    Tony
    Montrose, CO
    Are you sure this isn't something that needs to be enabled through Techstream?
  24. Feb 3, 2020 at 6:57 AM
    gowithit13
    Ray
    2023 Platinum
    Thanks for all of the responses, it was the LED cargo lights causing the problem.
    I installed the factory bulbs Friday and have not had anymore issues.
    Joe333x likes this.
  25. Feb 3, 2020 at 7:17 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
  26. Feb 3, 2020 at 7:23 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I tried it after reading this thread, pretty cool!!
  27. Feb 13, 2020 at 4:42 PM
    2020TundraTRDSport
    2020TundraTRDSport New Member
    MGM 2020 Tundra TRD Sport
    Current Mods: -Add a sub wiring kit from tacotunes.com (to support OEM headunit) -Single 12” Kicker Solo Baric L7 ported box -Matte Black Emblems complete replacement (iForce, Tundra badges) -20” OEM wheels Bronze Vinyl wrap -Matte Black TRD 4x4 Sport Vinyl for bedsides -Red, Orange, Yellow Vinyl Heritage Decals for 2018-2020 Tundra Honeycomb Grille -AmeriLite Black Led Tail Lights with Fiber Optic running lights -VHT nite shade 1/2 in border around tail lights -Carbon Fiber Vinyl for 3rd brake light -Headlight Revolution Complete LED Upgrade Kit (Front turns, Reverse lights, Cargo lights, 3RD Brake light, Dome lights, Mirror lights, Plate lights, footwell light.) -VLEDs 07-UP Toyota Tundra Front Footwell LED Light Kit (Front and Rear) -Diode Dynamics SS3 Fog Lights (Yellow) -Ceramic Tint: Front 20%, Rear 5%, windshield 50% with 5% ASR strip Wish list mods: -BakFlip Tri-fold tonneau cover -Tundra 3UR-FE 5.7L V8 Supercharger System (Magnuson Supercharger) -7” BDS lift kit -BMC (Body Mount Chop) -Fuel Covert Bronze 18x9 +1 offset wheels -BF Goodrich KM3 37/12.50r18 -Honey De 4” Widebody Fenders (Paint Match) -Dawn Custom Style Truck Cab Top Spoiler (Paint Match with Fiber Optic Led 3rd brake light across the entire edge of spoiler end to end) -Bora 1.75” Wheel spacers -Dirty Deeds BAMuffler 6 in exhaust system with Matte Black Tip -Putco Blade Red 60” tailgate light bar w/ plug and play harness -Hood Bulge 40” Baja Designs S8 Driving/Combo Yellow light bar -Lower grille 40” Baja Designs S8 Driving/Combo White light bar -Ditch lights Baja Designs LP6 Driving/Combo Yellow Pods -Baja Designs FPK (fog pocket kit) White fog light pods -Baja Designs OnX6 10” white light bar x2 back up lights (under rear bumper)
    ERROR: LED CAUSING TOUCH SENSITIVE LOCKING HANDLE IN 2020 TUNDRA TO NOT WORK FIX
    For those of you that have a 2020 Tundra and have swapped your interior bulbs and/or cargo bulbs for LEDs and have experienced the locking issue, I have found a jerry rigged fix. I too changed them out for LEDs and had the issue. I researched to find out what was causing this problem and found only this thread. Once I knew what was causing the problem I dug in a little further to find a temporary fix until Toyota decides to have one of their famous recalls to truly fix the issue. My original plan was to swap out every halogen bulb for LED including the brake, reverse and turn lights. When I swapped out the Taillight turn bulb it had hyper flash. Not a surprise but I can not find a 921 bulb that has a LED resistor built in. The canbus LEDs do not fix hyper flash. I do not want to T tap my wiring harness with a load resistor so I can retain my warranties. So I looked for a 921 plug and play load resistor so I might install my LED turn lights in the tails. I bought a set of the plug and play load resistors. When they arrived I noticed that they were not made to be used as a socket replacement. So because they did not work for my turn lights I decided to use them in my dome light to see if it changed the locking issue. I had my Cargo lights off and Dome lights on, tried to lock it and it worked. I was able to lock and unlock the truck from the handle and key fob over and over again. So I turned on my cargo light to see if it also fixed it there. It had the issue again once the cargo LEDs were on. So I put the other load resistor in the cargo socket and tried again. It worked. I was able to lock and unlock again.
    Long story, but the final outcome was that 921 LED plug and play load resistors fixed the issue for me as long as one was used in the dome light and one used for the cargo light. It does not need one for each individual bulb. Just one for one bulb. I put mine in the Passenger rear dome, and Passenger cargo. I hope that if any of you decide to try this fix for yourselves that it works for you as well.
    gowithit13[OP] likes this.
  28. Feb 15, 2020 at 10:51 AM
    MASTER YODA
    MASTER YODA New Member
    Yoda
    Lewisville, Texas
    2020 Black Tundra Platinum
    (Working on getting it) Blacked out
    So, where did you stuff the resistor [​IMG]wiring?
  29. Feb 15, 2020 at 4:43 PM
    2020TundraTRDSport
    I took off the dome light completely to work on it. First I wrapped the large metal piece on the resistor in electrical tape so it doesn’t touch metal and possibly cause problems. But I put it up top above the dome light in the roof area and turned the resistor to where it would fit in between the support beam seen in the photos that is right above the light location. And I had to ditch the flimsy metal shield because I couldn’t get it to fit around the bulb where it had to sit to make this work. But when the plastic cover is back on, you can’t even tell that anything was done. It looks like OEM with led replacements. I will upload pictures of where I put the one in the cargo light next.
    7FB60975-1F63-47EF-AA32-C9BDF746A0DD.jpg BB824047-879E-47EF-AB00-4FEEF43D62BB.jpg 2CB83A0D-F73C-4640-A7A8-976E96F17E2E.jpg 435519BB-1D54-40A5-8A35-DA03D25FD249.jpg
  30. Feb 15, 2020 at 5:03 PM
    2020TundraTRDSport
    For the Cargo lights, there are holes above and below the socket. I also wrapped the large metal piece of the resistor in electrical tape. I wiggled the resistor into the top hole space. I then zip tied the bulb side socket of the resistor to the plug side wire to keep it center and from moving about. It is a very tedious process but for those of us that want that LED life, it is well worth the time and effort to have everything work right.78D2AA2E-4540-4FE0-9FA0-3899C76540E1.jpgAE465397-45E3-4E95-92F1-FFF899088A3F.jpg 62B52BAD-0B50-411B-B80C-99EB832E9CDF.jpg101F5FD8-5A51-42D4-9897-4D950E28575E.jpg
