2020 Oil change
Discussion in '2.5 Gen Tundras (2014-2021)' started by T-Guy69, Feb 25, 2023.
  1. Feb 25, 2023 at 5:15 AM
    T-Guy69
    T-Guy69 [OP] New Member
    Long Island
    Black 2020 Tundra SR5
    I have a 2020 Tundra with a TRD factory Skid plate. Toyota did the first two oil changes. I like to learn how to do it myself.
    I went to YouTube and found this: 2014-2020 Toyota Tundra 5.7L V8 Oil Change Step-by-Step How-To - YouTube
    Question: To keep your warranty in effect, do you save your receipts?
    BTW: How many Quarts will I need? I took my owners manual out of the truck and put it in a safe place. So safe, I can't find it.
    Leo's first likes this.
  2. Feb 25, 2023 at 5:55 AM
    Retired...finally
    Yes, save all receipts. Buy the correct oil and since most brands come in 5 qt jugs, by two jugs. Sooner or later you'll have enough left over that buying a few single qts will be enough.
  3. Feb 25, 2023 at 6:16 AM
    cm.soole
    cm.soole New Member
    Cale
    Thornton, CO
    2011 CM SR5 TRD off road
    7.9Q of 0w-20 5w-20 or 5w-30. All are acceptable weights for your engine! You can read many hours forums about which one is better! You pick what you think best suits you.
  4. Feb 25, 2023 at 8:44 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    The owners manual states to use 0w-20 oil nothing else. In case of emergency other can be used but needs to be changed back to 0w-20 asap.
    In my experience the sale recepit will list the weight of the oil bought, that said if warranty work was needed they could see that you used improper oil and could deny coverage.
    Just saying.
  5. Feb 25, 2023 at 8:53 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    I just did an oil change on my 5.7 liter yesterday. And as it has in the past (I'm at 90,000 miles) it takes 8.4 quarts of oil to get to the top of the dip stick range (after filling and running the engine for a few minutes, then letting it settle for 10 minutes min.).
    OP, if you want to consider making your Tunda engine oil change life easier then look into getting a Fumoto oil drain valve to replace oil drain plug with. https://www.fumotousa.com/all-products.html
    Leo's first, bulldog93 and JLS in WA like this.
  6. Feb 25, 2023 at 9:26 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Not necessary to save receipts. I just keep a log of the maintenance I do, for my own record. I have never read a story about a dealer asking an owner to produce receipts for oil in order to perform a warranty claim.
    Leo's first, Rocko9999 and OHwendTrd like this.
  7. Feb 25, 2023 at 10:44 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    8.5 quarts is what you'll use. The Tundra oil change is a little more involved with it's oil filter choice, but it's not too complicated. The Motive X makes thing a lot less messy.
    Motivx Tools Oil Filter Wrench, Drain Tool, and Advanced Engine Oil Funnel Set for Toyota & Lexus 2.0L - 5.7L Engines With Cartridge Style Oil Filter Systems https://www.amazon.com/dp/B0791MWXDC
    Henry1jg, WILLINH, Wallygator and 6 others like this.
  8. Feb 25, 2023 at 8:50 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    This. There would really be no point. Just because you can show a receipt for oil doesn't prove to the dealer that that oil was used in that vehicle.
    Leo's first and Joe333x[QUOTED] like this.
  9. Mar 6, 2023 at 12:59 PM
    T-Guy69
    Long Island
    Thank you. I used your link. But unfortunately it is....."Currently unavailable. We don't know when or if this item will be back in stock."
  10. Mar 6, 2023 at 1:26 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    :confused: Where do you get this information
    OHwendTrd likes this.
  11. Mar 6, 2023 at 2:30 PM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    MotivX seems to be out of the funnel currently, but they have the wrench and drain tool available.
    Wallygator likes this.
  12. Mar 6, 2023 at 2:51 PM
    CTundraForMe
    CTundraForMe New Member
    As stated in other forums, the manual and oil cap say that because of US government requirements.
    The docs for the same engine in other countries lists other weights.
    However, in the interest of warranty coverage, it's probably best to stick with 0-20.
    I'm using 5-30 in my '15 because of the summer heat here in southern AZ.
    MEWaters likes this.
  13. Mar 6, 2023 at 2:53 PM
    CTundraForMe
    You can find a PDF version of your manual on the toyota website. You'll see it's probably state 7.9qt with oil filter. I did 7.9 for a while, then had enough of bottles sitting around with 0.1 in it. So now I just put in 8.
    Others state put in 8.5 to keep the dip stick happy.
    If you ask Toyota nicely through their website they may send you a new printed manual. They did for me!!
  14. Mar 6, 2023 at 6:28 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    I keep the receipts and do a log of each oil change. I also take pics of the whole change while I'm doing it. I want to make sure they can't deny warranty coverage.
    I honestly think a long and receipts would be enough proof.
  15. Mar 6, 2023 at 6:56 PM
    mgrs
    mgrs New Member
    '20 OR
    -8.5qts of 0w-20. People will recommend 7.9qts, but this is incorrect for a 2020. Your manual will corroborate.
    -Good filter tool. TOY640 is excellent, US made, and not expensive. https://www.amazon.com/Assenmacher-Specialty-Tools-TOY-640/dp/B0015PK3AG
    -Toyota 04152YZZA4 filter kit pay attention to how the housing gaskets fit.
    You will need a 24mm socket to use the above tool. You will also want a torque wrench.
    OEM drain plug fiber washer. Old school parts guys will give you one with the filter free.
    Filter housing drain cap- 10 ft/lbs
    Filter housing- 18 ft/lbs
    Drain plug- 27-28 ft/lbs
    Oil changes on these are very easy and everything is accessible. The worst part is the stupid skid plate hangers.
    EDIT: Get a carfax account and update your oil changes there. You can even upload your receipts. This way it will keep the carfax record good.
    The first thing local service managers here will do is pull the carfax when you state something is up. They will give you crap right away if it does not show oil changes. They do not care what your logbook says.
    Henry1jg, bulldog93 and Mike59 like this.
  16. Mar 6, 2023 at 7:33 PM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    I “log” my oil changes in the Toyota app. All the dealer performed maintenance is logged in there from prior to me buying the truck. I take a picture of the oil and filter I used and have it in a folder on my phone. Carfax is is not the Bible. It, like all sources of information, is only as good as the record keeper reporting to it. Lots of missing info on a Carfax. And I wouldn’t call oil changes on these trucks easy. They are actually kind of a pain in the ass. My wife’s Jeep GC is easy. One drain plug, filter sits in a canister on top of the engine. No skid plate, no draining mess.
  17. Mar 6, 2023 at 8:20 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    There’s really no way of proving any oil changes were done. Receipts of purchased oil/filter is only proof it was purchased. Your personal logbook in your center compartment isn’t any different than logs in carfax. It’s essentially the honor system. Toyota would have to somehow find proof that the oil change or lack thereof caused whatever issue would be present.
    change your oil at your chosen interval and be happy driving your truck :burnrubber:
    Leo's first and Sierradevil like this.
  18. Mar 6, 2023 at 8:36 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    The right filter housing drain tool, the right filter housing socket, and that fancy funnel all are excellent recommendations. After dumping my oil one time, I installed a Fumoto valve. Makes such a difference…
    I bought everything on Amazon.
    I also bought an aluminum filter housing through my dealer. It’s not “for” a Tundra, and has a shorter tube in the center. Takes about 11 seconds to swap tubes, and then it’s a perfect fit. The part number for the housing is circulation here somewhere, but I think it was for a Sienna van, if all things. I could be wrong though!!!
    My ‘18 takes 8.5 quarts. Earlier years called for 7.9 even in the same 5.7L. I just buy two 5-qt jugs of full synthetic 0-20 and do it. I dump one jug and then pour 1.5 into the empty. Dump the other 3.5 in motor.
    Buy the oil wherever has it on sale. Any good 0-20 synthetic is fine…. Buy the filter elements straight from Toyota dealer parts guys. I think I pay just a hair over $5 per. Tell them to keep that plug washer because you have a Fumoto…
    Only way to make it easier it to get a skid plate with a filter housing door…
  19. Mar 6, 2023 at 9:05 PM
    Joe333x
    Joe333x Member
    Boston
    You might want to give this a watch about the filter housing.https://youtu.be/G_vl2AYe7Yg
    Sierradevil likes this.
  20. Mar 6, 2023 at 10:18 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    I quit watching that idiot after a short while. Did he finally make a point of why the plastic housing is superior on a Tundra, but aluminum one of identical dimension is a better choice for other motors?
    I did not have my plastic housing break, despite numerous Toyota oil change “tech’s” doing their best to torque it till it spins freely. Since I’ve taken the reigns on my own maintenance, I’ve had good luck with the aluminum. I tighten till it stops turning and then just a tad of tension. It’s an o-ring seal. Doesn’t need to be horsed on there!!!
  21. Mar 6, 2023 at 10:25 PM
    Joe333x
    Joe333x Member
    Boston
    No, he did not say one is superior to the other as long as its the correct OEM part. He explained that the tube and spring which is your by pass valve is engineered to release at a certain pressure and by messing with it you could potentially not be getting oil to the engine when you need it or bypassing when it should be filtering. Feel free to watch it and deduct your own reasoning, I dont always agree with everything he says but with this one, its a known fact that the plastic housing has no issues when its not over tightened.
    BillyB, SnrDisregardo and Sierradevil like this.
  22. Mar 6, 2023 at 11:00 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Gotcha. I did keep my original guts out of the housing and transferred them to the aluminum. Didn’t think about seeing if the springs were of the same rate, but they looked close. Tubes definitely need swapped in order to fit the filter correctly and support the inside.
    To be honest, I cannot believe that the plastic one was still on one piece after seeing how tight the LOF guys were putting it on! 3 Ugga Duggas to remove…
  23. Mar 7, 2023 at 3:15 AM
    Wallygator
    Last 2 changes have been 8.5 quarts with a filter change.
    I buy whatever oil is on sale but always buy the oil filter at the dealer so there is a record. Also log everything.
    Also use the motiv x filter drain tool and funnel but have the Volvo Max drain plug system. IMO it's the best. So clean and easy.
    JLS in WA and BillyB like this.
  24. Mar 7, 2023 at 8:43 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    The funnel is the least needed part of the kit. It is nice that it threads into the oil fill tube, but any funnel works.
  25. Mar 7, 2023 at 9:41 AM
    PKFan
    In general I agree with this statement, but for me, it's pretty helpful when using 5 qt jugs to have a funnel that doesn't move when you're pouring. There are cheaper alternatives that are stationary, but I like that I can swap out the bottom of the MotivX and it'll fit the Hondas in our family (plus there's an adapter to fit our Sienna which isn't threaded).
    Wallygator and BillyB[QUOTED] like this.
  26. Mar 7, 2023 at 9:54 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Also it is important to make sure the filter housing wrench is oriented properly on the housing. There are external ribs that need to register with the slots on the wrench. I didn't realize this on my first two oil changes but was careful on subsequent changes.
    Also, the housing can be very difficult to remove if the O-ring is not lubricated during the previous oil change. Found this out the hard way also.
    BillyB likes this.
  27. Mar 7, 2023 at 10:01 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I bought my motivX from there website and got 10% off
  28. Mar 7, 2023 at 2:53 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    I put 7.5qt in mine and it's right in the middle of the dipstick range (yes, with filter and complete drain)... and 5k miles later it's still there.
  29. Mar 7, 2023 at 7:09 PM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    im confused as well. I put 8 quarts in mine and it’s at the top tit on the dipstick. Surely 8.5 would be overfilled.
  30. Mar 7, 2023 at 9:40 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    My 2020 owners manual. As others have pointed out, the amount of oil has changed through the years.
    Doxiedad, Wallygator and Joe333x like this.
