2020 OEM Skid Plate - What Moron Designed This?!?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bakershack, Jan 18, 2022.
  1. Jan 18, 2022 at 1:35 PM
    Bakershack
    Bakershack [OP] Critical of Noncritical Thinkers
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I just changed the oil myself for the first time since I've used up all the freebies from the dealership. I have read about the OEM skid plate but didn't take the posts that seriously - until now! It's likely they designed it to PURPOSEFULLY be difficult to remove, and removal is pretty much required to change the oil filter (at least until I get the MotivX setup complete).
    Now, I have seen different aftermarket skid plates that make it much easier to change the oil and filter without compromising on protection. All I need is basic protection down here - no rock climbing, just sticks and stumps occasionally. Which one is best for my situation?
    WXman and ColoradoTJ like this.
  2. Jan 18, 2022 at 1:38 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I thought the stock skid plate was pretty easy to remove. 3 in the front and 2 in the back...
    If you're looking for a slight upgrade, look into the TRD pro skid plate.
  3. Jan 18, 2022 at 1:38 PM
    D3VA
    D3VA New Member
    NoVA
    2021 TRD Pro in the MGM Master Race!
    My '21 has an access panel.
    ETA - Sorry, reading is fundamental. Missed stock vs TRD.
  4. Jan 18, 2022 at 1:39 PM
    Taco-Spike
    Two Trucks
    I thought so too. I mean a pain coming from vehicles that don't have one, but I've gotten used to it.
    2mchfun and TWJLee like this.
  5. Jan 18, 2022 at 1:47 PM
    This made me laugh. I did the same thing in 2013 when I had to change my oil for the first time.
  6. Jan 18, 2022 at 1:57 PM
    The RCI is nicer than the TRD skid. I just installed my Fumoto recently and used the MotivX tools. :thumbsup:
    Taco-Spike and AZBoatHauler like this.
  7. Jan 18, 2022 at 2:04 PM
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    I have the RCI engine skid, Fumoto valve and MotivX. Sweet setup.
    Taco-Spike and Bakershack[OP] like this.
  8. Jan 18, 2022 at 2:05 PM
    Yep...same here.
    Taco-Spike likes this.
  9. Jan 18, 2022 at 2:07 PM
    Mcoop
    Mcoop Throbbing Member
    Michael
    Berlin, NJ
    2015 Black SR5 5.7L DCLB 4x4
    I spend more time under the truck removing and installing the skid plate than I do opening/closing the Fumoto and removing/installing the oil filter.
  10. Jan 18, 2022 at 2:24 PM
    Time for an RCI. :D
    Mcoop[QUOTED] likes this.
  11. Jan 18, 2022 at 2:32 PM
    AZBoatHauler
    So.Arizona
  12. Jan 18, 2022 at 4:27 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    My Titan's skid plate was MUCH simpler to remove - remove two bolts, loosen two others and slide it off. The Toyota OEM plate had five bolts plus a screw to keep the front bumper cover from rattling. THEN it had hooks in the front that I had to figure out without being able to see them clearly - lift, slide left, then drop, then guide it out.
    Does the RCI or TRD plate cover the oil pan? Or does it stop just prior?
    FWIW, I also noticed that the stock Tundra sits about 1-2" lower than the Titan did, based on my ability to get under it without jacking it up.
  13. Jan 18, 2022 at 4:32 PM
    LJOHNS
    LJOHNS New Member
    RCI. Had one on my last Tundra and will be getting another for my 2018.
    Bakershack[OP] likes this.
  14. Jan 18, 2022 at 4:46 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    OK, thanks y'all. I will order an RCI in time for the next oil change. Is the aluminum appreciably lighter than the steel one?
  15. Jan 18, 2022 at 10:54 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    I bought an RCI skid plate set I have yet to install. While the 2020 skid questions are out there, does anyone know why the TRD skid doesn’t fit a 2020 Sport?
  16. Jan 19, 2022 at 3:18 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    If you want to go the RCI route, aluminum will be the weight savings, 10ga steel would be the one if you’re going to bang it up often.
    But from what you stated, aluminum will be more than sufficient for your needs.
    Bakershack[OP] and hANNAbONE like this.
  17. Jan 19, 2022 at 3:52 AM
    blanchard7684
    blanchard7684 New Member
    I consider it a work out. When I do my 21 Limited 4runner and my tundra in same day I'm usually sore the next day.
    If I didn't love Toyotas and especially 4runners and Tundras the oil changes would really bother me as well.
  18. Jan 19, 2022 at 4:48 AM
    Where are your cat plates?....You are crazy LOL. :stirthepot:
    pvn.beluga[QUOTED] likes this.
  19. Jan 19, 2022 at 5:08 AM
    2mchfun
    Pretty EZ to make an access panel in the stock skid plate and save $$ for other things if you're not hardcore off roading. As a bonus, weight savings.
    WXman, Ayvatr, WILLINH and 1 other person like this.
  20. Jan 19, 2022 at 5:53 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I will definitely consider that as well.
    2mchfun[QUOTED] likes this.
  21. Jan 19, 2022 at 6:06 AM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    What info do you have that states it does not fit?
    There should be no reason why it would not fit.
  22. Jan 19, 2022 at 7:55 AM
    GCanuck
    Gary
    BC,Canada
  23. Jan 19, 2022 at 4:51 PM
    BigRed20
    BigRed20 New Member
    2020 Barcelona Red TRD
    Yea, but the price..:eek2:
  24. Jan 19, 2022 at 5:11 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    The previous owner of my truck cut a hole in the skid to remove the filter. I had to remove it for a different job it was so rusty I just threw it out. At the worst it will see some mud and sand so I'm not worried about any damage.
  25. Jan 19, 2022 at 5:12 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    A friend of mine owns a metal shop. I can get him to cut an access hatch with a hinge. I'm thinking of a hinge that allows travel all the way back so I can stick it up out of the way with a magnet when changing the filter.
    steved0xTD, 2mchfun and WILLINH like this.
  26. Jan 19, 2022 at 10:01 PM
    DoublePro
    DoublePro New Member
    I end up cutting the hooks off my factory skid plates, now I just remove the 3 -10mm bolts and 5 - 12mm bolts
    wiltech and WILLINH like this.
  27. Jan 20, 2022 at 4:00 AM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    bed liner, diamondback se, level kit, nitto ridge grapplers,tufskinz letters, grab handle
    Same experience as everyone else. Got the RCI aluminum but haven't installed it yet.
  28. Jan 24, 2022 at 12:07 AM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    I'm cheap, everyone. Which is the lower cost option - the stock skid plate (mine's gone), the RCI skid plate, or the TRD skid plate?
  29. Jan 24, 2022 at 4:08 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    Lowest cost would be to find an oem take off, chop a hole and there you go. (probably could even find a free take off
    2mchfun and pvn.beluga like this.
  30. Jan 24, 2022 at 6:09 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    While I'm glad I got the RCI skid plate, I was displeased with the finish of it when it arrived. The majority of all the edges were sharp as hell. It's like once it came of the laser jet that they didn't bother to sand the edges down. I sliced the palm of my hand as I unwrapped it from the shipping box and plastic wrap. I took a 4" grinder and a flapper wheel to smooth down the edges myself. SMH.
    D3VA likes this.
