2019 vs 2020 TRD Pro Rear Tail lights
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by 19Voodoomax, Mar 10, 2020.
  1. Mar 10, 2020 at 4:35 PM
    19Voodoomax
    19Voodoomax [OP] New Member
    Mark
    Dundee,Oregon.
    2023 Tundra TRD Pro
    Saw it the other day and now I cannot seem to find the info but I remember seeing that there is a difference between the 2019 and 2020 Tundra TRD Pro tail lights. The 2019 has regular halogen bulbs and the 2020 are LED ! Can someone confirm ?
  2. Mar 10, 2020 at 4:43 PM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    My 19 PRO has Halogen Bulbs in the rear only, including the bed/cargo light, but I replaced those. All front lights are LED, but only after I replaced the front turn signal bulbs myself.
    DjSamthrax likes this.
  3. Mar 10, 2020 at 4:46 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Do not think they are led.
  4. Mar 10, 2020 at 5:04 PM
    Bad Cow
    Georgia USA
    I can't find anything saying the 2020's have LED tail lights. Are you SURE they are LED?
  5. Mar 10, 2020 at 5:11 PM
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    Pretty sure my 2020 does not have led tails fwiw
  6. Mar 10, 2020 at 5:49 PM
    19Voodoomax
    Mark
    Dundee,Oregon.
    2023 Tundra TRD Pro
    It may have been on a Facebook Group post . I’ll have to check into it. Thanks !
  7. Mar 10, 2020 at 5:50 PM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    :popcorn: My buddys 2020 sport doesnt have LED tails.
  8. Mar 10, 2020 at 6:01 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
  9. Mar 10, 2020 at 9:41 PM
    19Voodoomax
    Mark
    Dundee,Oregon.
    2023 Tundra TRD Pro
    Probably !!
  10. Mar 10, 2020 at 9:48 PM
    dharo
    dharo New Member
    David
    ‘20 Tundra TRD Pro
    no led on mine
    jewsNbrews likes this.
  11. Mar 10, 2020 at 9:51 PM
    19Voodoomax
    Mark
    Dundee,Oregon.
    2023 Tundra TRD Pro
    Well... I’m satisfied with the comments.
    dharo and 1lowlife like this.
  12. Mar 12, 2020 at 10:37 AM
    NuTundra18
    NuTundra18 New Member
    Jimmy
    2020 TRD Pro CM - MGM
    Toyota OEM Hard Flip Tonneau, Predator Steps, Driver Grab Handle, Console Sage, Spray Berliner.
    2nd the fake news!
  13. Mar 25, 2020 at 2:48 PM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    My 2020 TRD Pro definitely did not have LED tail lights. I know for sure because I switched out the bulbs and converted to LED's myself. I really like the result.
    Black Wolf likes this.
  14. Mar 25, 2020 at 2:52 PM
    NuTundra18
    Jimmy
    TampaRD Pro did you change rear turn signals bulbs?
  15. Mar 25, 2020 at 4:42 PM
    buckeyeinlv
    buckeyeinlv International Man of Mystery
    Brandon
    Henderson, NV
    2020 Army Green TRD Pro CrewMax
    OEM Power Tailgate Lock, Peragon Tonneau Cover, S&B Intake, Bora 1” Spacers, ceramic window tint. Interior: OCD Organizer, AJT Designs Cup Tray and Shift Trim, JDMCar Rubber inserts. Tires: 285/70R18 Old Truck: Base:2017 Inferno SR5 CM 4x4 Mods: Interior- OCD organizer, Proclip USA iPhone X Mount, Wireless center console charger, TRD shift knob. Exterior- Backflip G2 Tonneau Cover, Amp Research Powersteps and Bed Step, Pop and Lock tailgate lock, Ceramic window tint, Blackout emblems, TRD Pro Grille, Stubby antenna, Vinyl American flag TRD graphics, Color matched and bullet lined bumper ends, 18x9/+25 Method NV305 Bronze wheels Engine- Stock
    No LEDs on mine
  16. Mar 25, 2020 at 4:44 PM
    TampaRD Pro
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Yes I did. It required that I install resistors so as not to get the "quick flash" error. No biggie though. I preferred to solder them in instead of using the included quick connect line taps. The whole process took about 30 minutes start to finish for the rear turns.
  17. Mar 25, 2020 at 5:29 PM
    NuTundra18
    Jimmy
    Ok thanks do you mind telling me what ohm you used in each side and did you have to add resistors to the front?
  18. Mar 25, 2020 at 6:03 PM
    TampaRD Pro
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    I used the LED rear turn signal kit from Headlight Revolution.
    https://headlightrevolution.com/2014-2020-toyota-tundra-rear-blinker-bulbs-led-upgrade-kit-reflex/
    sku: 1417TUN-RER.TRNLED.REFLEX
    Not sure of the exact specifications of the resistors, as they weren't marked that I remember. However they worked perfectly and the bulbs are very bright, seem to be well made, unlike some of the cheaper ones on Amazon and eBay. I've purchased different brands for some of my other vehicles/motorcycles and these seem to be of a better quality for sure.
    I used HR for all of the tail lights, backups, license plate, cargo light and all the interior lights. Happy with the quality and with the result of the upgrade.
    I didn't change my front turn signals out yet so I can't give you any info there, that's still on my list along with a Coachbuilder TRD Pro kit, 295.70.18 tires, Diamondback HD, etc. ...I'm sure you understand.
  19. Mar 25, 2020 at 6:13 PM
    NuTundra18
    Jimmy
    Hahahah, yes I do. Very nice, thank you again for all the details!
  20. Mar 25, 2020 at 6:15 PM
    TampaRD Pro
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Just checked their website and to answer your question they are 6 ohm resistors in each side for the rear turns. A picture from the site. My bad for not paying closer attention when installing. It happens.
  21. Mar 25, 2020 at 6:26 PM
    NuTundra18
    Jimmy
    No worries and thank you again so much for the information and tracking it down, I really do appreciate it.
  22. Mar 25, 2020 at 6:31 PM
    chrisbusnut
    chrisbusnut New Member
    Pasadena, CA
    2020 Tundra Crew Max SR5 4x4 w/TRD Off Road pkg
    DiamondBack bed cover, SDHQ sliders, SwitchPro, Katzkin leather seats, TRD Pro grille, TRD Pro wheels w/Nitto Ridge Grappers, Toyota OEM leather steering wheel, SSO Slimline Hybrid Bumper w/Baja Designs S8 light bar, Warn Zeon Platinum 10-S winch, Baja Design rock lights & flush mount rear bumper lights
    They are definitely not LED. I also changed my halogens out. I used VLEDS and their inline resistors. Very happy with the results.
  23. Apr 9, 2020 at 6:28 AM
    NuTundra18
    Jimmy
    chrisbusnut, do you happen to have the JDM ASTAR LED turn signals in the front? I'm going crazy trying to get all this to work with VLED resistors. I've come to the realization that Tundras in the new models like resistors on all 4 corners to work I just want to make sure that a VLED VLR-6 on each rear turn signal will work with the JDM ASTAR LED front turn signals. Any advice is appreciated. Thx
  24. Apr 9, 2020 at 9:12 AM
    chrisbusnut
    Pasadena, CA
    @NuTundra18 , I used VLEDs for front and rear. I originally had the resistors installed in the front, but when I installed the rear turn signal bulbs, the rears did the hyper flash. I contacted VLED and they told me to move the resistors to the rear, so they sent me new mounting tape and once I moved the resistors, I have no issues. So resistors are connected to rear turn signals only. None in the front now.
    Hope that helps.
  25. Apr 9, 2020 at 9:21 AM
    NuTundra18
    Jimmy
    That does help, thanks again buddy for the info!
  26. Apr 19, 2020 at 2:17 PM
    19Voodoomax
    Mark
    Dundee,Oregon.
    2023 Tundra TRD Pro
    So, In order to change the halogen bulbs to led bulbs in the rear you need to add a resistor to the wiring harness on both sides ? Anybody have any pictures or done a DIY. Was looking at the Sylvaina Zevo 3157R for the tail, brake lights and 921 for turn signal. Do I need a resistor for each ?
  27. Apr 19, 2020 at 2:32 PM
    Bad Cow
    Georgia USA
    I treat my tail, brake & blinker lights like a sore dick and a rattlesnake, and don't F**k with them. The truck has full LED's in front after installing front LED blinker bulbs. Front blinker LED's were plug-n-play, no resistors, no hyper flash. I'm good with that.
  28. Apr 19, 2020 at 2:33 PM
    NuTundra18
    Jimmy
    Yes you will need a resistor on each rear no matter what you do. Check out VLEDS.com for their VLR-6 resistors with Duo-Tap connectors. Great quality kit. I would also do their 921 led rear turn signal bulbs. Quality is the best out there. Pricey, but you have a nice truck don’t go cheap!
  29. Apr 19, 2020 at 2:40 PM
    Bad Cow
    Georgia USA
    I agree. If you are going to do it, do it right and buy high quality parts. Just please make sure the parts are NOT from China. We have to stop dumping our money into that country.
    :spending:
  30. Apr 19, 2020 at 2:50 PM
    19Voodoomax
    Mark
    Dundee,Oregon.
    2023 Tundra TRD Pro
    so, I would need resistor kit for Turn signal and a separate kit for the Stop brake lights as well ?
