2019 Tundra Grille Switch-Sensor ?
Discussion in '2.5 Gen Builds (2014-2021)' started by CKCarlisle78, Jul 26, 2019.
  1. Jul 26, 2019 at 4:17 PM
    CKCarlisle78
    CKCarlisle78 [OP] New Member
    Courtney
    2019 Toyota Tundra XP
    Gunner Package
    Hi all, new here. I am wanting to switch my X Series grille to get rid of all the chrome. Either the TRD Sport or Pro. (prefer Pro) Concerned about the sensor issue that may happen? Anyone experienced having trouble changing the grille and causing any problems the with function of the sensor? If I chose the Sport grille would it be easier since the emblem is the same on the grille or is the Pro grille an easy switch? I have been looking at this site for the parts:
    https://www.sparksparts.com/accesso...tundra-trd-pro-grille-53101-0c070?parent=1325
    Any suggestions/thoughts?
  2. Jul 26, 2019 at 4:25 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    You shouldn’t have a problem with the sensor, it’s been done many times around here.
    You just need to figure out witch one you want. I personally like the new PRO grille better.
  3. Jul 26, 2019 at 4:28 PM
    CKCarlisle78
    Courtney
    Gunner Package
    I do too, obviously more expensive but looks so good. Just want to make sure it won't make anything more complicated with this sensor thing. Does anyone know of a you tube video that shows the switch out? I have not found one.
  4. Jul 26, 2019 at 4:30 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Super easy, the only issue with the pro grill is the garnish piece price. I switched my sensor over and grill swap in under 15 minutes... has worked like a champ for 1,300 miles
    CKCarlisle78[OP] likes this.
  5. Jul 26, 2019 at 4:40 PM
    Omohundro
    Jody
    McMinnville TN
    The swap it’s self is easy
  6. Jul 26, 2019 at 4:50 PM
    CKCarlisle78
    Courtney
    Gunner Package
    So another question is... if I choose the Sport grille, I can't find a 2019 and the 2018 seems to have the old emblem, does this work with the new sensor?
  7. Jul 31, 2019 at 4:34 AM
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    The sensor will work with the 2018 Pro grill but you will need a relocation bracket. A company called Jomax sells them. https://jomaxcustoms.com/new-gallery
