2019 Tundra Front Bench Console
Discussion in '2.5 Gen Tundras (2014-2021)' started by dasunsrule32, Oct 4, 2019.
  1. Oct 4, 2019 at 2:28 PM
    dasunsrule32
    dasunsrule32 [OP] New Member
    Arizona
    2019 Tundra SR5 Silver Double Cab
    Tonneau Cover OEM Headlight LED Lights Morimoto LED Fog Lights Sports Antenna Running boards LED Turn Signals 18" Vision Manx 2 wheels
    I have the front bench with the folding seat console in the front. With the factory cupholders, the drink cups flop all over the place while driving. Are there any custom inserts that can be purchased to alleviate the impending disaster of spillage? Thanks!
  2. Oct 4, 2019 at 2:42 PM
    gratefuljed
    gratefuljed New Member
    john
    Land of Enchantment
    2019 TUNDRA SR5 LB
    I have the SR5 but the cup holders in the shift console came with rubber inserts for 2 of them from Toyota. On the other two I found 2 rubber collapsible cups in the camping section of walmart. They work great.
    dasunsrule32[OP] likes this.
  3. Oct 4, 2019 at 2:45 PM
    dasunsrule32
    Arizona
    Thank you for the reply! Did you have a link to what you bought? That link didn't seem to lead anywhere.
  4. Oct 4, 2019 at 2:53 PM
    gratefuljed
    john
    Land of Enchantment
    2019 TUNDRA SR5 LB
    They put that link in! Just walk into the camping part, they are like 2$ each. My truck had two from Toyota in it when I took delivery.
  5. Oct 4, 2019 at 2:54 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I believe ppl have used some pvc pipe
  6. Oct 4, 2019 at 3:08 PM
    Jota21
    Jota21 New Member
    or reducer ferncos from the plumbing section... definitely on my list to do, too. If i do it before you, i'll post the sizes that worked. I'm pretty sure someone else already has, but i dont have the thread handy.
  7. Oct 5, 2019 at 1:52 PM
    Rider0120
    Rider0120 New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    3” rubber Coupling. You will have to make a relief cut so that way it fits in there
    Paul B and dasunsrule32[OP] like this.
  8. Oct 5, 2019 at 2:04 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Bigger cups???
  9. Oct 5, 2019 at 2:21 PM
    Rider0120
    Bucks County, Pa
    It’s the base that’s the problem. Rtic are to big and sit on a angle. If found the ZAK! Cups from target for the best.
  10. Oct 5, 2019 at 2:25 PM
    dasunsrule32
    Arizona
    The issue is that they are not always the same cups. Could be a chick fil a cup, chipolte, water bottle, etc.
  11. Oct 5, 2019 at 2:31 PM
    dasunsrule32
    Arizona
    This seems like the best solution so far... I'll have to test it out
  12. Oct 5, 2019 at 2:36 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Yep, I don't want a cup holder on the console. That's where the 20lb yorkie sits
  13. Oct 5, 2019 at 2:43 PM
    Gabrielo93
    Gabrielo93 New Member
    Gabriel
    Grand Prairie, TX
    2015 Black Toyota Tundra SR DC
    12 Volt Remote Starter Lockerdown Safe ICS Fab Dash Mount Husky All Weather Beaters Mats Rear Folding Seat Mod Linex Platinum Kicker Sub/Amp Combo CoverCraft Dash Cover Kenwood Headunit Cravenspeed Untenna CupHolderHero Aukee Tailgate Inserts OEM Deck Rails Rolling tonneau cover CravenSpeed Untenna
  14. Oct 5, 2019 at 2:44 PM
    dasunsrule32
    Arizona
    Tundyfundy likes this.
  15. Oct 5, 2019 at 2:48 PM
    dasunsrule32
    Arizona
  16. Oct 6, 2019 at 8:43 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Ordered the Fernco jobbers. Excited to finally use regular cups and cans!
    dasunsrule32[OP] and Gabrielo93 like this.
  17. Oct 6, 2019 at 9:40 AM
    Gabrielo93
    Gabriel
    Grand Prairie, TX
    Haha no
  18. Oct 6, 2019 at 12:55 PM
    dasunsrule32
    Arizona
    Same!
  19. Oct 10, 2019 at 4:37 PM
    dasunsrule32
    Arizona
    Got them in and they look good and fit well (•‿•)
  20. Oct 10, 2019 at 6:27 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    I wish there was more we could do with this set up.
  21. Nov 21, 2020 at 1:54 AM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    I actually 3d printed some spacers. It started out as cup spacers, and then evolved into nugget sauce holders...
    PeakIT, indymanjoe and Dceclipse like this.
  22. Nov 21, 2020 at 5:29 AM
    1rebmem
    1rebmem New Member
    Jef
    TN
    2018 SR5 4x4 Inherited from my dear dad RIP 4/21/2020
    Two years old and 5200 miles when I took ownership
    Well that's not fair........showing us those nice printed cupholders and not offering to sell us some.........
  23. Nov 21, 2020 at 5:46 AM
    PhearCVBz
    PhearCVBz New Member
    2021 Black Tundra DC, 2024 Black Tundra CrewMax
    or share the 3d model (for personal use of course) ;-)
  24. Nov 21, 2020 at 12:48 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    I just joined this forum so I’m not sure what the rules are about selling and vendors etc. If you’d like I could probably print them at cost + shipping for people.
    I thought I did! I’ll have to double-check, but if not I’ll put them up on thingiverse over the next few days
  25. Nov 21, 2020 at 1:13 PM
    Grumpy Uncle
    Pat
    CO
    2016 Black CM Tundra TRD Off Road
  26. Nov 21, 2020 at 10:50 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    Ah, just remembered I never designed the cup spacer, just the nugget sauce holder. LMK if you'd like the nugget sauce holder, but the spacer can be found here:
    https://www.thingiverse.com/thing:3558139
    Creator says he printed in TPU, I printed in PETG and it was fine.
  27. Nov 21, 2020 at 11:16 PM
    Tundyfundy
    Bay Area, CA
    Lol
