2019 Tundra Double Cab rear seats delete
Discussion in '2.5 Gen Tundras (2014-2021)' started by istr, Dec 29, 2019.
  1. Dec 29, 2019 at 4:39 PM
    istr
    istr [OP] New Member
    STL, MO
    2019 White Tundra Limited Double cab
    Hello everyone,
    I haven't found any up to date info on how to remove rear seats from dual cab therefore this topic. This is how it looks like in the end:
    To remove the seats (completely), you'll need 14mm socket and an extra pair of hands.
    I found this PDF (attached), which describes the process pretty well. However, I'm going to add couple of pics to clarify the process.
    1. Unscrew 6 bolts holding the base (single lines on the pic below) and 3 bolts holding the seat belts (double lines).
    2. Seat is kept in place by 2 pins (marked with arrows on the pic above) and 4 hooks at the top (marked with circles).
    Closer look at the pins:
    Closer look at the hooks:
    3. Make sure that the seat belt in the middle is not attached to the seat. You need to lift the whole bench vertically up for at least 2.5' (that's where extra pair of hands will be very handy). Be careful with those 2 pins as you can easily scratch the paint or tear the carpet.
    That's it. So much more space.
    ConcordCarlos likes this.
  2. Dec 30, 2019 at 5:01 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Why did you remove the seats? What are you going to do with the space?
    Rocko9999 likes this.
  3. Dec 30, 2019 at 5:32 PM
    istr
    STL, MO
    I was expecting any question but this...
    Because I'm not using rear seats? I can put 2nd battery system there, and water supply in horizontal tanks. And fridge, until I find some drawers for the bed. Also cabin is sort of more weatherproof than the bed with 200$ cover. Camper is in todo list.
  4. Jun 24, 2020 at 6:57 AM
    Corvus1
    Corvus1 New Member
    Thanks! This will actually help a ton when I get my Tundy in the near future. Any updates on what you may have put back there?
  5. Jul 20, 2020 at 7:04 PM
    istr
    STL, MO
    Just finished the milestone. Fridge and 2nd battery. I'm also planning to add a drawer over the battery and a 2nd one between the fridge and the seat.
    Floor is 2/3, I didn't want to cut the jack mount. Battery is attached too the very corner.
    PS: 3/4 plywood is too much. Also floor paint was a bad decision, carpet ftw.
    Electrical: 100Ah deep cycle, 25A Redarc charger and 400W inverter. Will be adding a solar blanket, fridge dries out the battery in 24h and to charge it I have to move. A lot.
    Fridge Snomaster 56D.
    Pps: first diy project of this magnitude.
    Wallygator, Warreng, MTRock and 2 others like this.
  6. Jul 20, 2020 at 9:22 PM
    Castoroides
    Castoroides New Member
    Drake
    Northern California
    Barc Red 2018 Double Cab 4x4
    Hey, new to the tundras community. @istr any chance you could post more photos of your set up? I'm looking to do something very similar.
    Debating leaving the passenger side single seat in just in case. What would are the dimensions of the usable area in your truck with the seats out?
    Thanks
  7. Jul 21, 2020 at 3:20 AM
    Welcome from NY.
  8. Jul 21, 2020 at 4:26 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Pretty huge space!
    Luckydog likes this.
  9. Aug 4, 2020 at 7:54 AM
    Castoroides
    Drake
    Northern California
    Hey guys how did you get this seat belt base to come out?
    seahaul likes this.
  10. Aug 7, 2020 at 2:20 AM
    unsub1
    unsub1 New Member
    Steven
    2020 MGM Tundra 4x4 SR5 TRD Off-Road Package, Convenience Package,
    Victory 4x4 sliders, RSI SmartCap, ICI Alumilite front bumper, TRD Pro wheels, Nitto RidgeGrapplers, FrontRunner rack, National Luna DC25 dual battery, X2Power AGM main battery, Cascadia 4x4 hood-mount solar panel, NOCO X2 Pro charger
    Currently researching doing something similar for my CrewMax. I wonder how different the fasteners are from the DC to the CM? My plan is to put my ARB 50qt where the 40% rear seat is. Did you get the impression you could remove one section of the rear seat and leave the rest? Thanks for any insight. Searches aren't going well. Nice work, by the way.
  11. Aug 7, 2020 at 2:42 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Hehehe. I slept on the backseat of my 07 dc for about 4 months. It sucked because You just can t stretch out completely. I ve been in the process of making a bed in the cab for some time. I have all but drivers seat out atm, but as soon as I grind off some of the stops on the passenger seat, so I can recline it all the way to the floor, I will re install it. I then will build a platform that will sit over the reclined seat. I planned on leaving seat out, but the airbags are disabled when you disconnect seat. If someone knew how to bypass the passenger seat that would rock.
  12. Aug 7, 2020 at 2:45 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Boy some of you guys sure like to butcher the crap out of an otherwise perfectly good truck.
    Branden, P-Factor and surf760 like this.
  13. Aug 7, 2020 at 4:16 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    When I m done with it; it will be a perfectly good truck, and my home if need be:thumbsup:
    Wallygator and DoublePro like this.
  14. Aug 7, 2020 at 4:21 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Not me.
    When I got rid of the truck it took me less than an hour to make it stock again.
    I only make these mods so that they do not detract in any way from the original setup of the vehicle,notice I didnt even relocate the Jack and Tools.
    At the same time everything bolts down tight to factory attachment points for safety too!
  15. Aug 7, 2020 at 5:23 AM
    Welcome from NY.
    unsub1[QUOTED] likes this.
  16. Aug 7, 2020 at 6:24 AM
    Castoroides
    Drake
    Northern California
    Not sure about the hardware on the CM but I was able to take out the 40 seat on my DC so I imagine it can't be too different on the CM. But someone with a CM will have to come in.
  17. Aug 7, 2020 at 12:46 PM
    surf760
    surf760 New Member
    Surf
    2020 tundra TRD sport
    Sounds pretty janky :bananadead:
  18. Oct 11, 2020 at 8:37 PM
    seahaul
    seahaul New Member
    Anyone??
  19. Oct 11, 2020 at 9:16 PM
    istr
    STL, MO
    Plastic cover is held by 2 clips, ply it from the bottom.
  20. Nov 2, 2020 at 12:01 PM
    Castoroides
    Drake
    Northern California
    Awesome this was very helpful
  21. Feb 11, 2021 at 3:19 PM
    Umka
    Umka New Member
    2019 TRD 4x4 Sport
    Firestone airbags, with Daystar cradles, 17 inch rims. FWC Hawk shell
    This is great and what I've been looking for. Did you remove or some how unhook the middle seatbelt, the one you can't just unclip and push through the seat? I can't figure anyway to do this except to remove the belt from the bolting to the base (near the retractor). I think you've done that, because I don't see it still bolted there.
  22. Feb 17, 2021 at 6:13 PM
    SR5camper
    SR5camper New Member
    AZ / TX
    2015 SR5
    I've contemplated removing the rear seats entirely as well but opted to only remove the single passenger side seat. I was able to fit a Dometic 75L fridge behind the front seat and still have enoug leg room for a normal sized passenger. 20201222_160347.jpg
    Solar is on my list of future mods but after going with a 27f X2 battery it's now nowhere near the top. I can run this fridge for 2-2.5 days before it reaches the medium battery voltage limit and still start the truck.
    You may want to consider upgrading the fridge before doing solar, unless the fridge isn't the only reason for it.
    Wallygator likes this.
  23. Feb 18, 2021 at 6:10 PM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    That's a lot of room for activities.
    ConcordCarlos and Rocko9999 like this.
  24. Feb 25, 2021 at 1:18 PM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    How did you keep the 2 seat side mounted in without the single side bracket? I'm wanting to do the same for fridge room on mine.
  25. Feb 25, 2021 at 7:32 PM
    SR5camper
    AZ / TX
    2015 SR5
    Retained the original bracket but trimmed off enough to clear the fridge.
    I'll be posting a more detailed thread when I make a few final tweaks.
    blackoutt[QUOTED] likes this.
  26. Feb 26, 2021 at 4:21 AM
    blackoutt
    Indy
    OEM+
    Do the seat back/bottom detach easily from the bracket? I'd like to make it reversible so that I can put the single seat back in if needed so I can't go cutting them apart. Might have to be like @Wallygator and source a spare seat to cut up.
  27. Feb 26, 2021 at 6:35 PM
    SR5camper
    AZ / TX
    2015 SR5
    The trimming i did still allows for the single seat to be used by itself. I just removed excess material.
  28. Feb 28, 2021 at 11:01 AM
    blackoutt
    Indy
    OEM+
    Okay I was making this way too difficult without taking the seat out to just look at it for myself. The seat back and bottom simply unbolt from the seat brackets. 2x 18mm headed hex, 1 t40 torx. Bolt the brackets back in and fridge sits on the underseat organizer with enough opening room to take the basket in and out now. Thanks!
    TTracer and Wallygator like this.
  29. Dec 23, 2021 at 10:07 AM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Can you remove just the 40? Looks like the 60 has to use the base of the 40 to stay put
  30. Jan 8, 2022 at 7:03 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    When I search a topic and find my old post lol
    So I'm thinking you are stuck with this extra mount sticking out?
    Can you remove the 60 only instead of the 40?
