2019 tundra Brake Control
Discussion in 'New Member Introductions' started by Kfraisse, Sep 18, 2020.
  1. Sep 18, 2020 at 2:57 PM
    Kfraisse
    Kfraisse [OP] New Member
    Kevin
    Folsom ,LA
    Hey guys. I new to this and need some help. I have a 2019 tundra SR5 4.6L crew cab. I’m try to figure out what I exactly need to hook up a brake controller. To the right of my steering column I have 3 wire harnesses under the dash can I use those to hook up a brake controller. Can someone tell me what I need please? I’m trying to purchase a camper but I need to get this first. Toyota was no help at all.
    YardBird likes this.
  2. Sep 18, 2020 at 5:03 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
    Kfraisse[OP] likes this.
  3. Sep 18, 2020 at 5:10 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Didn't it come with a Brake Controller factory installed?
  4. Sep 18, 2020 at 5:14 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! I am sure someone will chime in with an answer to your question.
  5. Sep 18, 2020 at 6:06 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  6. Sep 18, 2020 at 6:14 PM
    Kfraisse
    Kevin
    Folsom ,LA
    Thanks guys. @ old man blue no it didn’t. So apparently the 5.7 L comes with it factory installed but the 4.6L doesn’t. These are the wire harnesses I have under the dash to the right of the steering column.
    BravoDeltaRomeo likes this.
  7. Sep 18, 2020 at 6:48 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  8. Sep 19, 2020 at 9:21 AM
    Kfraisse
    Kevin
    Folsom ,LA
    Thanks for the video. It was helpful I don’t think I have the wire I need to hook up the brake control. None of the extra wire harnesses I have look like they match.
  9. Sep 19, 2020 at 11:21 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    None of those harness connectors near the steering column are what you want. Thread below should get you as close to plug-n-play wiring as possible for aftermarket controller on 2018+. You have to run several wires (2 or 3?) across to an empty harness connector on the passenger side. Ground and brake sense connections can be made near the steering column. You can use the supplied Tekonsha harness or one of their universal harnesses, but you'll have to extend the wires (strip/solder/tape or heat shrink) going to the passenger side...none are long enough to reach.
    https://www.tundras.com/threads/2018-tundra-with-4-6-engine-trailer-brake-install.25884/
    Kfraisse[QUOTED][OP] likes this.
  10. Sep 19, 2020 at 11:38 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Or go get a Klein tools wire stretcher :rofl:
    That's what we send rookie engineers to find on their first trip inside a plant or refinery.
  11. Sep 19, 2020 at 12:04 PM
    Kfraisse
    Kevin
    Folsom ,LA
    That’s funny Kelly. I’m in construction and we would tell the new guys to go get the board stretcher if they cut sometime too short.
  12. Sep 19, 2020 at 12:07 PM
    JohnLakeman
    In my rookie days, they sent you for a stryofoam coffee cup of trichloroethylene solvent, but I didn't bite on it. :D
  13. Sep 19, 2020 at 2:45 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    One time I went onsite and was asked by one of the techs to hand him the bucket of amps right behind me. I just told him amps can't be stored in a bucket. They have to be squeezed out of a tube! He and I got along great after that.
  14. Sep 21, 2020 at 10:19 PM
