2019 tundra 38 gallon tank.
Discussion in 'General Tundra Discussion' started by Doz3r, Apr 17, 2025.
  1. Apr 17, 2025 at 4:32 PM
    Doz3r
    Doz3r [OP] New Member
    Seeing if anybody else has the same issue or maybe I’m just overthinking it. I have a 2019 tundra with a 38 gallon tank. I’ll get the 50 mile till empty notice and then I’ll keep driving until my fuel light comes on. I don’t rush to the gas station, but I make my way there. I have yet to put over 32 gallons in my tank. Is this normal to have 6 gallons in reserve? Seems like it should be closer to two or three.
    Corndog123 likes this.
  2. Apr 17, 2025 at 4:33 PM
    Tundrav82019
    Tundrav82019 New Member
    Leo
    2019 Tundra Limited TRD Off Road
    Yes, I have same thing happen. I spoke to Toyota mechanic and they keep that reserve to avoid the fuel pump from burning out. Totally normal.
    you could go past it, but it’s a huge tank and needs that reserve to avoid damaging the pump.
  3. Apr 17, 2025 at 5:57 PM
    blenton
    blenton New Member
    Totally normal.
    Toyota has a 6 gallon or so ‘reserve’ when the light turns on - I’d suppose it is to keep the pump cool and keep the user from running it completely dry. Being that the bottom of the tank is fairly flat, 6 gallons equates to 2 inches of fuel or so. The smaller 26 gallon tank has had 6 gallon reserve since 2007.
    And in case you are curious, the 26 gallon tank actually does take 26 gallons of you run it fumes… The 38 gallon tank should also be 38 gallons. I don’t advise trying it for yourself, but take my word on that... I tried it. Once. Ha.
    Lifer, JBplays, Corndog123 and 3 others like this.
  4. Apr 17, 2025 at 8:23 PM
    HappyDad38
    HappyDad38 New Member
    2014 Black Tundra TSS SC 4x4
    6" BDS Lift Fox Coils and shocks 35x12.5r20 nittos
    My Tundra has a 26 gallon tank and I hate having such a small tank! I wish it had came with the 38 gallon tank.
    Rakkasan likes this.
  5. Apr 17, 2025 at 9:19 PM
    blenton
    blenton New Member
    You can change that for a few bucks and some elbow grease…
    mustang67408 and Tundrav82019 like this.
  6. Apr 17, 2025 at 9:31 PM
    RobertD
    Robert
    DFW, Texas
    The tundra tank is shallow and wide, it's not skinny and deep. 5 gallons is not that deep in the tank, pushing yourself more is a risk.
    Totally agree it's dumb and they should have just called it a 33 gallon tank and non of us would have said shit when we only put in 31-32 after the lights been on. But its a little late for anything to change unless you fully change the tank to go larger, but again it will be roughly the same design so you will still fill up about 5 gallons under it's max.
    Tunrod likes this.
  7. Apr 18, 2025 at 4:43 AM
    HappyDad38
    Really, I heard it was a very expensive process and took a lot of work?
  8. Apr 18, 2025 at 4:45 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    My light comes on when there is 8 gallons left
    using the scanguage 3
    half tank mark is 15 gallons
    fill up before the light comes on
    Black@Blue19 likes this.
  9. Apr 18, 2025 at 7:04 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    I've owned multiple Toyota over the years. It seems like they plan on you having roughly 100 miles of fuel left when the light comes on. My 4Runner had about 4.5 gallons, my wife's Rav4 3 gallons and my Tundra 6 gallons. All equal 90-100 miles average.
    JLS in WA likes this.
  10. Apr 18, 2025 at 7:17 AM
    blenton
    blenton New Member
    Like I said - for a few bucks and some elbow grease… :D
    You can use factory parts and they will bolt right in. The only things you will need to sort out are the additional (front) crossmember and the parking brake lines. The lines will need to be moved/modified to fit the crossmember, and the crossmember will need to be snook into place and secured. IIRC, frames from ‘15 or or ‘16 on up have some provisions for the crossmember while older trucks do not.
  11. Apr 18, 2025 at 7:17 AM
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    So does mine, I find it sufficient. There's still 1/4 left on the gauge at around 340 miles.
  12. Apr 18, 2025 at 7:19 AM
    18" TRD Off Road Wheels
    Likely '16 and up because that was when the bigger tank was added to the Tundras.
    blenton[QUOTED] likes this.
  13. Apr 18, 2025 at 7:21 AM
    blenton
    blenton New Member
    That sound right. I couldn’t remember what year exactly it was added but knew I was in the ballpark.
    GODZILLA[QUOTED] likes this.
  14. Apr 18, 2025 at 8:13 AM
    HappyDad38
    Thanks Blenton, I will be looking at doing this after I get some stuff done to my son's truck. Doesn't sounds too bad actually!
  15. Apr 18, 2025 at 10:08 AM
    catus
    catus New Member
    Centennial, CO
    '19 MGM DC Limited, stock for now
    HappyDad38[QUOTED] likes this.
  16. Apr 18, 2025 at 10:22 AM
    HappyDad38
    catus[QUOTED] likes this.
  17. Apr 18, 2025 at 10:29 AM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    I never get 300 miles out of my 26 gal tank. I average maybe 12.5 mpg though. You must be driving nice to be getting 350+ per tank.
  18. Apr 22, 2025 at 3:48 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    There's a fuel light?
  19. Apr 22, 2025 at 8:22 AM
    Tundrav82019
    Leo
    Well a check light for low fuel once you get to a specific fuel level. It illuminates on the dash.
    atc250r likes this.
  20. Apr 22, 2025 at 10:01 AM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    I was surprised to find the same thing the other day. Drove to "0" miles left and only took 32 gallons. I can understand leaving some room to spare but 6 gallons is a lot.
  21. Apr 22, 2025 at 10:06 AM
    Tundrav82019
    Leo
    It’s a huge tank and generally flat, 6 gallons only covers the bottom by a couple inches or more. It’s to really ensure the fuel pump is not damaged. You can go past it, but I wouldn’t advise it haha.
  22. Apr 22, 2025 at 10:22 AM
    atc250r
    atc250r New Member
    Every car I've had with the pump in the tank was sufficiently baffled that it wouldn't be an issue. I don't condone running it to empty but it's just weird that you have about 1/6 of a tank still.
  23. Apr 22, 2025 at 10:27 AM
    blenton
    blenton New Member
    Another point - if you are towing and getting 10 MPGish... you have 60 miles to dead empty. Most places are 40 miles or less between gas stations. Most... but definitely not all...
    The only time I've personally killed a fuel pump was on an explorer that I drove 20 miles past the fuel light on a hot summers day. So I view it as a forethought on Toyota's behalf to do us a solid favor, instead of an annoying quirk. I'd rather be annoyed by a premature light on the dash than stranded in the middle of nowhere, out of gas or with a dead pump. But that's me.
    mverkaik and Doxiedad like this.
  24. Apr 22, 2025 at 11:24 AM
    2mchfun
    A few gallons in a big tank is almost nothing at one end when going up or down inclines.
    Terndrerrr and nobodyintexas like this.
  25. Apr 22, 2025 at 12:40 PM
    Tundrav82019
    Leo
    I think it’s a testimony to Toyota and their overbuild quality. I love my 38 gallon tank, I generally get 600 miles on the hwy. Especially if I am not using the AC and going the speed limit hahah.
    Bammer likes this.
  26. Apr 23, 2025 at 4:41 AM
    HappyDad38
    I would absolutely love that! Just fill it up all the way and drive forever. It feels like I have to fill up once a week and with the gas stations here in Wichita, KS ...they are always packed for the good stations that have good gas.
  27. Apr 25, 2025 at 4:14 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Yep, so have I. Lol
  28. Apr 25, 2025 at 4:28 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    When your remaining fuel volume drops to a size of compact car it lights up, you know.
  29. Apr 25, 2025 at 5:24 AM
    Retired...finally
    The concept of "burning up" a submerged fuel pump when the tank is almost empty rather scares me. If the idea is that the fuel pump needs plenty of gasoline to cool it and without that coolant it gets hot and fails due to overheating while surrounded by potentially explosive gas vapor?
    Does anyone else see the problem in this plan?
  30. Apr 25, 2025 at 5:29 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yes.
    the remedy is to fill at or before the little yellow light.
    lather in a supercharger to this equation...and you have the makin's of a full hootenanny.
    I refill at 19 gallons. which is that line below half tank.
    because.
    smokint and PermaFrostTRD like this.
