5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Jun 26, 2021 at 10:52 AM
    #841
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    One last remark on the ATF degradation estimate. This article describes how GM is getting that number in their transmissions:
    https://www.jstor.org/stable/44723621
    The PDF is free to access once you register.
    TL;DR 1) bulk oxidation component - how long was the ATF at certain temperature 2) friction degradation component - how well the friction modifiers are doing based on the shift pressure and duration. I can speculate that Aisin is doing something similar.
  2. Jun 26, 2021 at 3:01 PM
    #842
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    Nick has stated that the MHX has the highest cooling capacity, but that they should all work equally well for the Tundra application. He moved from Hayden to Setrab due to his customer service experience, and added MHX for a high quality, USA-made lifetime warranty.
  3. Jun 26, 2021 at 4:40 PM
    #843
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I was able to pull up the ATF degradation on my hacked Trchstream and also the utility. You can see my value is 961 and that's on a 2020 with around 25k for mileage. I'm running a cooler.
    Wallygator, sd172[QUOTED] and sask3m like this.
  4. Jun 26, 2021 at 4:46 PM
    #844
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Do you think it's a function of newer ECUs and not available in earlier ones?
    I asked ViktorG, a Toyota tech who said I don't need to reset anything in my 2013.
    I swapped 9 quarts today, the transmission feels much better. The fluid that came out after the second drain was not hugely less dirty.
    Second drain on the left.
    sd172 likes this.
  5. Jun 26, 2021 at 5:08 PM
    #845
    Genuine Cooling Systems [OP] New Member Vendor
    Couldn't have said it any better.
    SSPey[QUOTED] likes this.
  6. Jun 26, 2021 at 5:51 PM
    #846
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    I’m glad. I read every post about the coolers and install probably 10 times before pulling the trigger. It works so well that I’m looking forward to forgetting everything that I learned!
  7. Jun 26, 2021 at 6:18 PM
    #847
    I'm the same way. I don't even monitor my temps anymore no matter if I have a load or not.
  8. Jun 26, 2021 at 6:59 PM
    #848
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    To be completely honest I have no idea. The reset was something that was never performed at the dealership on any of the vehicles. I would get a copy of Techstream and check if it's available on the '13 and reset it.
  9. Jun 26, 2021 at 7:27 PM
    #849
    e30cabrio
    I have tried TS Version 12,14,15 & 16. None had that value & when I tried to reset it said it was unavailable.
  10. Jun 26, 2021 at 8:02 PM
    #850
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Can you see the data stream for the AT?
  11. Jun 26, 2021 at 8:06 PM
    #851
    e30cabrio
  12. Jun 26, 2021 at 8:20 PM
    #852
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I suspect then it's just not available for the '13.
  13. Jun 26, 2021 at 8:25 PM
    #853
    e30cabrio
    Thanks
    Ruggybuggy[QUOTED] likes this.
  14. Jun 30, 2021 at 9:07 PM
    #854
    SaltTheWound
    SaltTheWound New Member
    Tundra Crewmax 4x4
    Do you mind sharing the cost for this?
  15. Jul 1, 2021 at 3:45 AM
    #855
    Dallas007
    Dallas007 New Member
    Dave
    2021 Tundra Pro Max
    They are on sale for $849
  16. Jul 1, 2021 at 6:00 AM
    #856
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    I have the original Hayden cooler upgrade on crewmax 2021. I just finished towing my 5Klb boat to FLA a 1200 mile round trip with 4 people and 500lbs in luggage, beach stuff, tools, spare tire etc. Outside temps were 93F. Trans temps at 70 mph were 202F at 75 mph 204F. Engine cooling temps 198F. Surprisingly when it started to rain it only dropped trans temps by 1F? Prior to install I was getting 220F by myself with zero load or trailer lol....... Side note at 75 mph I got 10.4 mpg at 70 mph I got 12.3 mpg. I am usually around 195F unloaded on trans temps.
    Terndrerrr, co2owen, dongziye and 5 others like this.
  17. Jul 5, 2021 at 5:06 PM
    #857
    Oerterg
    Oerterg New Member
    2020 MGM sr5 sport crewmax 4x4
    i wish the mhx cooler was all black but thats me lol. says Back order but any idea on possibly when it will ship out id ordered this week
  18. Jul 5, 2021 at 6:00 PM
    #858
    Early August. Improved Racing does not have any MHX brackets available for the next few weeks.
  19. Jul 6, 2021 at 8:08 AM
    #859
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    And so it begins.....
  20. Jul 6, 2021 at 8:24 AM
    #860
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I just did mine last Wednesday. A tip for installing the hard lines, when twisting them back and forth between the engine and frame, place a hand on each end. One by the alternator and one by the transmission. When it feels like it won't rotate just enough to get into place, rotate in the opposite direction.
    By the way, i tried to install the hard lines with the long cooler hoses connected. No go for me. Wasted hours trying to do it. Removed the hoses and had the hard lines in place within minutes.
  21. Jul 6, 2021 at 8:33 AM
    #861
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Make sure you use electrical tape to cover the ends of the hard lines. Keeps the dirt out of the lines as you push them into position.
  22. Jul 6, 2021 at 8:41 AM
    #862
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    The two rubber end covers from the thermostat fit nicely over the hard lines, takes care of one half at least. I installed with hard lines and cooler hoses connected, it was a pain, but doable. I have big hands, hard to fit in small places, so made it work.
    The cooler mount step was more relaxing ...
  23. Jul 6, 2021 at 10:13 AM
    #863
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Transmission steps next....
    Done...
  24. Jul 10, 2021 at 1:34 PM
    #864
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Towed the boat up to Lake Texoma and this is the highest temps I hit in the Pan and Torque Converter.
  25. Jul 10, 2021 at 1:38 PM
    #865
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    232 with a transmission cooler? That doesn't seem right. My last trip I topped out at 220 towing a 30' 6k pound TT.
  26. Jul 10, 2021 at 1:52 PM
    #866
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    The TC was 232 for a breif period "unlocked" at 76 going uphill.
  27. Jul 10, 2021 at 1:55 PM
    #867
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Welcome to the dark side.
    And that is one of my favorite beers from across the pond.
    IndianaGeologist likes this.
  28. Jul 10, 2021 at 2:39 PM
    #868
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Normal
    Wallygator likes this.
  29. Jul 10, 2021 at 2:46 PM
    #869
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Yup. That was my thought on it. The pan temps stayed low and the TC dropped quickly as soon as it locked up. My pre-cooler TC temps would get in the mid-240s briefly in the same section of road. Pan would get to the 220s.
  30. Jul 10, 2021 at 2:50 PM
    #870
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    My temps are very similar. The TC temps spike everytime the TC unlocks. Overall pan temp is the one to be concerned about.
    Jtundra81 and sd172 like this.
