5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Mar 4, 2021 at 8:37 PM
    #481
    BigHornMtnTundra
    BigHornMtnTundra New Member
    2018 Barcelona Red SR5
    Road Armor Stealth Lonestar King 2.5 RR EXT Coilovers King 2.5 RR performance shocks Icon delta joint tubular UCA Coachbuilder +3 shackle kit Durobumps bump stops Cooper discover at3 xlt 275/70/18 ARE Overlander
    My Dad must have lucked out. His 2019 double cab trd off road has the external cooler on.
  2. Mar 4, 2021 at 9:33 PM
    #482
    Genuine Cooling Systems [OP] New Member Vendor
    Must be aftermarket.
  3. Mar 4, 2021 at 9:41 PM
    #483
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Stock 19's don't have a trans cooler. you might have it confused with the cooler on the lower part of the radiator, which unfortunately is only a power steering cooler. :(
  4. Mar 5, 2021 at 4:06 AM
    #484
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    How long did it take you? Haven't watch the videos yet but not looking forward to ripping off the bumper.
  5. Mar 5, 2021 at 4:35 AM
    #485
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    Bumper removal isn't required, only need to remove the grill. At least that's the way it was when I installed my kit last summer.
  6. Mar 5, 2021 at 4:42 AM
    #486
    BrakeDust
    Hill Country, TX
    That's good news!
    How long was the install? I'm going to set aside an entire Saturday, that will leave room for running to the auto parts store or HD if needed.
    Jmn likes this.
  7. Mar 5, 2021 at 4:49 AM
    #487
    Set aside 4 hours max. Ensure you have all the tools required for the install. There are .pdf instructions on my website as well as a YouTube video by a fellow user. Although he has a different kit I no longer sell, the plumbing install and ATF level check are the same.
    KC.Tundra, Drainbung and Bammer like this.
  8. Mar 5, 2021 at 1:57 PM
    #488
    Jmn
    Jmn New Member
    I started around 10am and finished around 5pm.
    I got lunch break for 1h and went really easy.
    It includes a test drive of 1h to check leaks.
    The longest part for me was to remove the skid plate and put it back (that you may not have if you don’t have the PRO trim), easy job but just long by the number of bolts.
    If you have all the tools, this is a plug and play install, I would rate 3/10 on difficulty level.
    I would say the « hardest » part is to fill up+level with new fluid if you have never done it before. It can become messy quick with the fluid but that’s it, everything else just fits in its place.
  9. Mar 5, 2021 at 2:31 PM
    #489
    Which cooler did you install?
  10. Mar 5, 2021 at 2:36 PM
    #490
    Jmn
    Jmn New Member
    MHX
  11. Mar 5, 2021 at 3:42 PM
    #491
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Thanks for sharing. I was planning to install mine tomorrow morning, but not sure I have 5-6 hrs to commit! Might have to do it another time. :-(
    Jmn[QUOTED] likes this.
  12. Mar 5, 2021 at 3:46 PM
    #492
    Jmn
    Jmn New Member
    Yeah I would recommend that you don’t feel the need to rush it .. it’s always when you don’t have time that something goes wrong :)
  13. Mar 5, 2021 at 4:01 PM
    #493
    BigHornMtnTundra
    So it most definitely has an external cooler on there, but he got the last 2018 on the lot at the end of 2019. I always thought he had a 2019 but I was wrong.
  14. Mar 5, 2021 at 4:57 PM
    #494
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Just make sure you know the exact procedure for getting the transmission fluid back to the proper level. That's the part that some have difficulty with. It's not something you want to guess at.
    Jmn likes this.
  15. Mar 6, 2021 at 8:40 AM
    #495
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Husky X-act, front windows tint, Xpel PPF, center console organizer and tray, TRD rear sway bar, touch screen cover, transmission cooler, wireless charger, keyless tailgate lock.
    Great thread and lots to learn. Just ordered the Veepeak scanner so I can check temps. I plan to pull a 4,500lb travel trailer so I think this cooler setup is in my near future.
  16. Mar 6, 2021 at 6:15 PM
    #496
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    I ended up putting in my Setrab kit this afternoon. Like Jmn said, not hard, but is time consuming. It took me close to 5 hrs and i still need to put my skid plate back on in the morning. Definitely a couple tight spots to work around, but if you take your time and aren’t in a hurry, it’s not that bad. Fit and finish is fantastic and definitely looks factory.
  17. Mar 6, 2021 at 6:47 PM
    #497
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    I just got my set up from toyota was delivered Friday now I need to choose a cooler
    Drainbung likes this.
  18. Mar 6, 2021 at 7:21 PM
    #498
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Be careful you don't leave the gauge displayed on your phone for long periods of time. It will burn the image onto your phone. I can still see my gauges on a white background.
  19. Mar 6, 2021 at 8:27 PM
    #499
    Did you happen to take any photos of the Setrab cooler installed?
  20. Mar 7, 2021 at 4:50 AM
    #500
    BrakeDust
    Hill Country, TX
    I installed my Setrab, will post a thread.
  21. Mar 7, 2021 at 5:24 AM
    #501
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    I haven’t put my grill back on yet, so I’ll be sure to get some pics before I do.
  22. Mar 7, 2021 at 5:38 AM
    #502
    BrakeDust
    Hill Country, TX
  23. Mar 7, 2021 at 5:49 AM
    #503
    fishmando
    fishmando New Member
    Wow, this looks slick.
  24. Mar 7, 2021 at 7:00 AM
    #504
    You're the man, thank you for the write-up. It looks like the 30° and 45° fittings work out perfect and run directly to the holes in the air deflector. This is totally personal preference, but you can break the 10mm nut loose on the back of the horn so you can adjust the horn down. This will give it a little more clearance to the bracket. All in all it looks great.
    Saltyhero13 and Drainbung like this.
  25. Mar 7, 2021 at 7:06 AM
    #505
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Did you pull an old ATF sample to send out for analysis?
    Saltyhero13 likes this.
  26. Mar 7, 2021 at 7:07 AM
    #506
    14burrito
    2014 SR5 CM 4x4 5.7
  27. Mar 7, 2021 at 7:13 AM
    #507
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    I did not
  28. Mar 7, 2021 at 7:14 AM
    #508
    14burrito
    2014 SR5 CM 4x4 5.7
    Anyone installing the cooler going to do a UOA so we can get a history/database of how the ATF faired prior to their cooler install?
  29. Mar 7, 2021 at 7:30 AM
    #509
    Punisher29073
    Punisher29073 New Member
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    Has anyone considered adding an additional canister spin on filter to one of these systems?
    Ryan
  30. Mar 7, 2021 at 8:52 AM
    #510
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Additional filtration is typically not a bad thing however there are a few things to consider.
    Is additional filtration necessary?
    Is there a benefit over just increasing oil changes (oil changes for transmission)
    With changing a inline filter, there will likely be fluid loss. meaning, you wouldn't avoid doing a pan oil level check. So is there really a benefit?
    Additional para static drag for fluid going through in-line filter. The OEM system was design for a trans cooler, but not tested with additional restrictions.
    A clogged inline filter could cause starvation and create catastrophic trans failure. What would the maintenance interval be to guarantee this doesn't occur?
    If Toyota didn't include one from factory, I think following the recommendation change intervals as the minimum requirements would ensure max life without adding an additional failure mode.
    I wish there was a thread with Blackstone results on trans fluid to compile information regarding fluid life, particulates, maintenance intervals, etc.
