5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Jan 15, 2022 at 6:40 AM
    #1291
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Any reputable transmission shop should be able to install , really straight forward and instructions are pretty clear .
  2. Jan 15, 2022 at 8:46 AM
    #1292
    GTundraX
    GTundraX Rub some dirt on it.
    Melyssa
    Oceanside, CA
    2019 TRD Off-Road DC
    Thanks!! I'll check out the one in Escondido since I'm in North County
    That's what I thought, too. I took it to Oceanside Transmission, which has great reviews, and showed them the instructions. They said they don't feel comfortable doing it :confused: I don't know lol
  3. Jan 15, 2022 at 9:05 AM
    #1293
    Jtundra81
    Joe
    Wow , ok , I did it In my garage with no lift in around 3 hours overall that drinking my beer and teaching my son wrenching and trust me if I can do it anyone can …
  4. Jan 15, 2022 at 10:04 AM
    #1294
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    Soon to be 4WC Raven host. Mods to come.
    @GTundraX Give M.I.T. Drivetrain a call. Easily one of the best shops in town.
    http://www.mit4x4.com/
    GTundraX[QUOTED] and SoCalRandy like this.
  5. Jan 18, 2022 at 6:51 PM
    #1295
    SoCalRandy
    SoCalRandy New Member
    Randy
    San Diego, California
    2020 MGM Limited Crewmax 4x4
    Does anyone with experience know if it matters which hose goes to which in/out nipple on the radiator? In other words, does the outlet hose from the thermostat attach to the top or bottom nipple of the radiator? Thanks in advance!
  6. Jan 18, 2022 at 7:08 PM
    #1296
    Genuine Cooling Systems [OP] New Member Vendor
    The top port or “ATF to cooler” (see page 5 of the instructions) will route to the bottom port of the cooler.
  7. Jan 18, 2022 at 8:21 PM
    #1297
    SAGE63
    San Diego County
    Did you check with The Truck Shop in miramar?
  8. Jan 18, 2022 at 9:28 PM
    #1298
    GTundraX
    Melyssa
    Oceanside, CA
    I did not, but I will look into it. Thanks!
    SAGE63[QUOTED] likes this.
  9. Jan 19, 2022 at 4:28 PM
    #1299
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    @Genuine Cooling Systems
    Little clarification please on the MHX-514 Kit.
    On the Thermostat to Hard Line Connections...
    Does the top soft line from the thermostat ("To ATF Cooler"/Outlet Hose) connect to the top most "kinked" hard line?
  10. Jan 19, 2022 at 4:38 PM
    #1300
    Yes, the hoses never cross and always run parallel with each other. The top hose will also be on the uppermost portion of the bracket as your route it to connect to the uppermost hardline.
  11. Jan 19, 2022 at 5:10 PM
    #1301
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    GODZILLA likes this.
  12. Jan 19, 2022 at 5:21 PM
    #1302
    Let me know if you have any other questions. The portion of the Setrab 15-Row install video for the install of the Toyota hoses and ATF level check procedure are the same procedures for the MHX-514. The video, combined with the .pdf instructions, should get you through the install fairly easily. Again, email me if you have any questions and I’ll get back to you ASAP.
    t-bear likes this.
  13. Jan 19, 2022 at 5:21 PM
    #1303
    Refusuck
    Refusuck New Member
    Si Tres
    Arch Cape OR
    2021 TRD Pro
    Dam I miss the macho man and his interviews - the good ole days.
    Damie Street and GODZILLA like this.
  14. Jan 19, 2022 at 5:26 PM
    #1304
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    "I
  15. Jan 19, 2022 at 5:29 PM
    #1305
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    Hmmmmmmm Yeahhhhhh.
    AircareTundra likes this.
  16. Jan 19, 2022 at 5:36 PM
    #1306
    Refusuck
    Refusuck New Member
    Si Tres
    Arch Cape OR
    2021 TRD Pro
    pure gold - just like the genuine cooling systems - I'm sure the intercontinental superchampion of the world Randy Macho Man Savage would have had one had he still been around. Cream rising to the top!
  17. Jan 19, 2022 at 6:44 PM
    #1307
    steved0xTD
    steved0xTD New Member
    2020 Tundra SR5 4x4 TRD Off-road
    I had to take a 2.5 hr drive today, first "long" one since I installed the cooler, I wasn't towing but I wanted to compare the OBD Fusion Toyota pack A/T oil temp 1 vs the custom PID from the first post in this thread, as I thought I had seen somewhere in another thread that the Toyota pack temp was higher than the custom formula. In this screenshot, Toyota pack PID is bottom left and custom PID is 2nd from top left, named "ATF Pan". The Toyota pack reading was exactly 1 degree higher F throughout the range of temps I saw.
    I didn't try the A/T temp 2 (torque converter) to compare.
    I'm towing this weekend to Savannah so I'm excited to see how it does under greater load :)
  18. Jan 20, 2022 at 3:12 AM
    #1308
    That’s weird. I wonder if it’s due to the perimeters of the formula.
  19. Jan 20, 2022 at 8:03 AM
    #1309
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Nick is the MHX-514 cooler with the 2 connections on the side a bidirectional cooler? I saw a couple videos mention it but wanted to be sure for when i connect the hoses from the cooler to the hardline.
  20. Jan 20, 2022 at 8:54 AM
    #1310
    It is however, I recommend you route the hoses according to the instructions. The inlet hose (ATF flow from thermostat to cooler) should be connected to the bottom port of the cooler so it forces any air pockets out of the cooler. The same goes for the Setrab cooler as well.
  21. Jan 20, 2022 at 8:56 AM
    #1311
    MadMaxCanon
    Makes complete sense, thanks!
  22. Jan 20, 2022 at 9:01 AM
    #1312
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    @Genuine Cooling Systems what's your opinion on using one of the Setrab fan pack units, like the 20 row 9 series w/ 2 fans? Would it only make sense for someone who sees high temps during rock crawling or frequent slow speed towing?
  23. Jan 20, 2022 at 10:23 AM
    #1313
    steved0xTD
    I bet it is due to some rounding in the operations/ordering of the formulas. I configured it to display some decimal points, and it tracked like this (custom formulas on top, Toyota pack PIDs on the bottom):
  24. Jan 20, 2022 at 4:39 PM
    #1314
    Like you said, it would only make sense for someone who rock crawls and/or overlands their rig with a heavy load. I thought about adding a unit with a fan but it didn't make sense since the 15-row cooler already maintains the pan temperature just above the thermostat opening range (which is where we want it). If the desire for a fan on a 20-row cooler is there I can design a kit for it but the drastic increase in price is going to sway buyers away.
  25. Jan 21, 2022 at 11:21 PM
    #1315
    MadMaxCanon
    Is there a ballpark of how much ATF is actually needed for the mhx kit? I followed the instructions and my pan was level within a degree with an angle guage and when I drained it, very little came out before it started to trickle. I put slightly more than 1.5 quarts in figuring it would just drain out later, but judging from what came out I would say there is very close to an additional 1.5 qts in there now. I went for a short drive to check for leaks and everything felt normal. Is there a big range for normal total capacity?
  26. Jan 22, 2022 at 3:38 AM
    #1316
    1eyedclyde
    1eyedclyde New Member
    Clyde
    NewCastle CO
    21 SC Pearl Platinum
    Just installed this. Excellent video instructions, super easy.
    MadMaxCanon and steved0xTD like this.
  27. Jan 22, 2022 at 10:21 AM
    #1317
    With the MHX-514, it takes roughly 1 quart to fill the cooler and lines. It’s not uncommon for the ATF level in your truck to be low or over filled with ATF from the factory. As long as you followed the procedure correctly and you had a trickle between 99-111 F you are good to go.
  28. Jan 22, 2022 at 1:29 PM
    #1318
    SoCalRandy
    Randy
    Does anyone know if there is a metal washer that goes on the transmission drain plug? I got completely finished with the fluid level check, and I thought the install was one hundred percent done… and then I found a metal washer under my truck. I can only imagine that it goes on the drain plug. Well, if it turns out to be the drain plug washer, which way should it be oriented? There is a flat side, and a not flat side. I’m assuming that the flat side would mate up with transmission pan. I’m waiting for my ATF pan temp to drop below 80° so I can start the fluid level check all over again… :(
  29. Jan 22, 2022 at 1:44 PM
    #1319
    Drain pan drain plug or check level plug? Either way both should have a washer. Also, it doesn’t matter which side the washer faces the pan, it will be seal either way and not damage the pan.
    SoCalRandy[QUOTED] likes this.
  30. Jan 22, 2022 at 1:46 PM
    #1320
    SoCalRandy
    Randy
    I guess I meant check level plug.
    Thank you for the quick reply!
