2019 tail lights fit 2020?
Discussion in '2.5 Gen Tundras (2014-2021)' started by MASTER YODA, Feb 15, 2020.
  1. Feb 15, 2020 at 11:50 AM
    MASTER YODA
    MASTER YODA [OP] New Member
    Yoda
    Lewisville, Texas
    2020 Black Tundra Platinum
    (Working on getting it) Blacked out
    Are the tail lights on the 2020 (I have the Platinum) the same dimensions, size & fit of the previous 3rd Generations?
    Looking at a set of smoke replacements but their fitment data only goes to 2019. I can't discern any difference externally, but may be some internal issues.
    JC
  2. Feb 15, 2020 at 12:04 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    yup. they're the exact same. What lights are you thinking of going with?
  3. Feb 15, 2020 at 12:29 PM
    MASTER YODA
    Yoda
    Lewisville, Texas
    There are, from what I can tell, a non-brand specific set on both eBay ($109) and Amazon ($126). They are the same thing.
    Willing to consider options. Just getting into this modification thing. Traded up on a 2016 all OEM black TSS. Not crazy about the chrome headlights either.
    Looking at a replacement set of black rims & tires down in Houston. But …. being patient about all.
  4. Feb 15, 2020 at 2:08 PM
    Welcome from NY.
    Stay away from Winjets they are junk.
    1lowlife likes this.
  5. Feb 15, 2020 at 2:12 PM
    MASTER YODA
    Yoda
    Lewisville, Texas
    Roger that! Thanks.
    Jim LE 1301 likes this.
  6. Feb 15, 2020 at 2:14 PM
    :hattip:
  7. Feb 15, 2020 at 6:57 PM
    2020TundraTRDSport
    2020TundraTRDSport New Member
    MGM 2020 Tundra TRD Sport
    Current Mods: -Add a sub wiring kit from tacotunes.com (to support OEM headunit) -Single 12” Kicker Solo Baric L7 ported box -Matte Black Emblems complete replacement (iForce, Tundra badges) -20” OEM wheels Bronze Vinyl wrap -Matte Black TRD 4x4 Sport Vinyl for bedsides -Red, Orange, Yellow Vinyl Heritage Decals for 2018-2020 Tundra Honeycomb Grille -AmeriLite Black Led Tail Lights with Fiber Optic running lights -VHT nite shade 1/2 in border around tail lights -Carbon Fiber Vinyl for 3rd brake light -Headlight Revolution Complete LED Upgrade Kit (Front turns, Reverse lights, Cargo lights, 3RD Brake light, Dome lights, Mirror lights, Plate lights, footwell light.) -VLEDs 07-UP Toyota Tundra Front Footwell LED Light Kit (Front and Rear) -Diode Dynamics SS3 Fog Lights (Yellow) -Ceramic Tint: Front 20%, Rear 5%, windshield 50% with 5% ASR strip Wish list mods: -BakFlip Tri-fold tonneau cover -Tundra 3UR-FE 5.7L V8 Supercharger System (Magnuson Supercharger) -7” BDS lift kit -BMC (Body Mount Chop) -Fuel Covert Bronze 18x9 +1 offset wheels -BF Goodrich KM3 37/12.50r18 -Honey De 4” Widebody Fenders (Paint Match) -Dawn Custom Style Truck Cab Top Spoiler (Paint Match with Fiber Optic Led 3rd brake light across the entire edge of spoiler end to end) -Bora 1.75” Wheel spacers -Dirty Deeds BAMuffler 6 in exhaust system with Matte Black Tip -Putco Blade Red 60” tailgate light bar w/ plug and play harness -Hood Bulge 40” Baja Designs S8 Driving/Combo Yellow light bar -Lower grille 40” Baja Designs S8 Driving/Combo White light bar -Ditch lights Baja Designs LP6 Driving/Combo Yellow Pods -Baja Designs FPK (fog pocket kit) White fog light pods -Baja Designs OnX6 10” white light bar x2 back up lights (under rear bumper)
    I have a 2020 Tundra. I am running the OEM tail lights and I have swapped out the brake and reverse bulbs for LED. I really want everything to be LED including the turn bulbs. I get hyper flash with a 921 LED replacement. On my 2006 tundra, I just swapped out my turn signal relay for one that was load resistant for LEDs. I don’t want to T-tap into my wiring harness so I can retain the warranties. I would like to stay all plug and play for everything. 921 plug and play LED load resistors that I can find do not have a twist in socketed end. (I will insert and image of ones that I purchased and found out don’t work.)97FFEF26-9B45-4BE5-8E18-817909E20C7A.jpg
    Does anyone know of a fix for the LED hyper flash problem for the 921 rear turn bulb?
  8. Feb 15, 2020 at 7:03 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    T tapping your turn signals at the taillights isn’t going to effect your warranty.
  9. Feb 15, 2020 at 7:15 PM
    18" TRD Off Road Wheels
    It would affect the warranty for anything they can show the modification caused. For example, if he went back to the stock lights an had issues they could potentially deny the warranty claim on them.
  10. Feb 15, 2020 at 7:22 PM
    Danman34
    Danman34 New Member
    Danny
    That’s a farrrr stretch. A resistor does nothing but add a small load resistance to the circuit, the same as any filament bulb would do. If it isn’t popping fuses, it’s doing absolutely no harm.
  11. Feb 15, 2020 at 7:23 PM
    I wholeheartedly agree. I just wouldn't put it past them to fight it. Still, consumers are protected, and if you just drop the Magnusson-Moss name a lot of times they cave. They use fear tactics to get out of it at the dealership level.
  12. Feb 15, 2020 at 7:59 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    My only option on 2019 was to have a shop solder inline resistors for me. Lights on my truck have been running fine ever since.
  13. Feb 16, 2020 at 10:40 AM
    NCTundra1980
    NCTundra1980 New Member
    Stephen
    2019 SR5
    I bought the vled resistor kit and soldered them in, then silicone around solder joints taped and wire loomed. It’s water tight and can’t even tell I was in there.
  14. Aug 19, 2020 at 7:03 PM
    montez25
    montez25 New Member
    SATX
    2020 toyota tundra platinum 4x4
    In the market also for some new tail lights. I'll be keeping an eye on this thread️
  15. Aug 19, 2020 at 10:42 PM
    2020TundraTRDSport
    I ended up purchasing these tail lights from Amazon and I really like them. They are extremely bright and come with load resistors wired in. I just 3M taped the resistors to the inside of the tail light cavity.
    AmeriLite Black LED Parking Light Bar Brake Tail Lights Pair for 2014-2017 Toyota Tundra SR5 TRD SR
    https://www.amazon.com/dp/B07VVTQK1M/ref=cm_sw_r_cp_api_i_urEpFb30J0SC5
    F.N.G MOTO likes this.
  16. Aug 20, 2020 at 12:39 AM
    F.N.G MOTO
    F.N.G MOTO New Member
    2019 Tundra TRD
    Those are nice
