2019 SR5 Blackstone Transmission oil report at 38k miles...
Discussion in '2.5 Gen Tundras (2014-2021)' started by ddact, Jan 14, 2022.
  1. Jan 14, 2022 at 5:21 PM
    ddact
    ddact [OP] New Member
    2019 5.7L 4WD SR5 DC FFV - Black
    So, after all the hue and cry about how missing external transmission coolers were going to cause our trucks to explode in a fiery transmissionpacolpyse the likes of which has never before been seen, I decided to see what kind of shape the fluid in mine was in.
    TLDR at bottom.
    My 2019 SR5 DC 4x4 FFV was bought shiny and new by us back in 2019. Completely stock (even has steelies!).
    It's my daily driver and a garage queen...except when it's not.
    This past June/July we took it on road trip starting in central Kentucky, going up through Indiana, across Illinois and Iowa, then over to Mount Rushmore, across Wyoming to Yellowstone, then into Montana, down into Idaho, across the Teton pass and then south to Salt lake city. From there down into Arizona, New Mexica, Texas, Oklahoma, Arkansas and then to Memphis and straight back to central Kentucky. We went completely around Colorado, Nebraska and Kansas and were gone over a month.
    This entire trip had 5 people in the cab and a camper shell on the bed that was stuffed to the gills with our crap. We were also pulling a (normally) 4,500lb dual-axle camper that was stuffed with crap as well. Any time the camper is attached to the truck it was in S4 with tow/haul mode enabled. Cruise was generally set at 70mph the entire way. Except when the 80mph speed limit in Wyoming saw us at 75mph. I averaged less than 7mpg on one tank of gas in Wyoming.
    It was so hot in the desert that they wouldn't even let people hike and recommended you not spend more than 15 minutes outside during the day. We put right at 8,000 miles on the truck from start to finish on that trip.
    Between the big trip and numerous other small trips the truck has probably spent around 25% of every mile it's driven pulling that camper. Another 25% with a bed full of dirt bikes.
    As of now the truck has been nearly flawless no matter how hard I flog it. The only problem I've had at all is I got the front rotors so hot coming down the Teton pass that it warped them causing a slight vibration when braking. The camper not having trailer brakes is what caused it. Even with the truck in a lower gear and holding back turning 5k rpm's I was still hard on the brakes slowing it down. Turning the rotors fixed it.
    The truck was at 38,830 miles when I sent a transmission oil sample to Blackstone labs.
    The Blackstone report is attached.
    Here is what the Blackstone summary said:
    Since this was the first service for this transmission, then there's nothing that looks too out of the ordinary. Wear metals tend to read high in factory fill samples from the normal wear-in process, and that would explain the elevated copper and tin levels. Other metals like aluminum, iron, and lead are already below average for a Toyota automatic, with averages being based on ~38,200 miles. Copper and lead should get there after another oil change or two. No moisture or excess insolubles (solids from heat and use) were found, and the 1.8 TAN shows just mild acidity.
  2. Jan 14, 2022 at 5:37 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Good report looks like the fluid can handle the higher operating temperatures, hopefully the seals in the transmission can also.
    2mchfun and AircareTundra like this.
  3. Jan 15, 2022 at 5:18 AM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Was this on the original ATF fluid? What did you fill the trans with after draining?
  4. Jan 15, 2022 at 6:26 AM
    ddact
    It was the original fluid. It was refilled with the same OEM fluid.
    Jtundra81 and Spyker[QUOTED] like this.
  5. Jan 15, 2022 at 6:34 AM
    blanchard7684
    blanchard7684 New Member
    Fantastic. Thanks for sharing.
    TAN and viscosity changes are what should be monitored for breakdown.
    Did you happen to monitor the temps during your recent adventure?
  6. Jan 15, 2022 at 6:38 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Good to see. Thanks for the effort.
  7. Jan 15, 2022 at 6:56 AM
    ddact
    I only have the stock truck temp gauges. The transmission light never came on though. And the engine temp gauge never moved at all, even when going up the Teton pass at normal speed and the truck was definitely working hard. I don't baby it.
    Jtundra81 and JDM FTW like this.
  8. Jan 15, 2022 at 6:57 AM
    JDM FTW
    JDM FTW New Member
    VA
    2021 AG Limited TRDOR
    I wish I could “love” this post. Glad to see that there’s at least ONE other person out there who trusts Toyota engineering instead of getting sucked up into the mass HYSTERIA generated by keyboard cowboys with little or no actual engineering background or experience. Bravo Zulu brother, you shall now surely be shunned by the non-believers.
  9. Jan 15, 2022 at 6:59 AM
    blanchard7684
    Thanks...that was my next question is if the 302F temp light was triggered.
    Your experience with this is valuable thank you for sharing.
  10. Jan 15, 2022 at 6:59 AM
    blanchard7684
    shots fired!
    predicting 25 pages, 3 bans.
  11. Jan 15, 2022 at 7:02 AM
    JDM FTW
    JDM FTW New Member
    VA
    Bring it. :argue: :rofl:
    blanchard7684[QUOTED] likes this.
  12. Jan 15, 2022 at 7:17 AM
    Fearthisbeard
    Fearthisbeard New Member
    Gilbert AZ
    2019 - 1794 TRD Offroad
    Thanks for sharing !
  13. Jan 15, 2022 at 7:38 AM
    YankeeRon
    YankeeRon New Member
    Ron
    East Windsor, CT
    2021 SR Long Bed
    Cat Security shield, rear headliner molding, BlackVue dash cam, DS grab handle, rear under seat storage, door edge molding, cal trend seat covers, sway bars, hard bed cover, rubber bed mat, intermittent wipers
    ....converter lockup all the way may have something to do with it. Thanks for the real world data - I’ll be pulling a trailer with mine soon as well and I’m pleased to see how you ‘19 fared....
    Ron
    JDM FTW, 2mchfun and AircareTundra like this.
  14. Jan 15, 2022 at 9:47 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Thanks for sharing, I'll be sending my 135k sample to them in a few months, just got a great 130k motor oil report.
    JDM FTW likes this.
  15. Jan 15, 2022 at 10:09 AM
    ddact
    Actually, it would've been more accurate to say it's in S4 with tow/haul mode enabled any time the camper is attached to the truck. I think I'll edit it.
  16. Jan 15, 2022 at 10:19 AM
    LML 3500HD
    Good report, but not surprised though. Freeway towing, half the capacity, etc. 38k miles is a bit premature. Under heavy use the transmission service isn’t scheduled until 60k miles. You are not in “heavy use” territory.
    Good to have a baseline though. There has only been 2-3 transmission failures that I have heard of on 2019-21 trucks under heavy use. Not something I would be concerned about. That’s what warranties are for and savings accounts after that.
    batman900 likes this.
  17. Jan 15, 2022 at 3:29 PM
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    I don't understand. Are you saying that a good trans fluid report at only 38k miles means we should be fine at 200k miles? Maybe I'm misunderstanding you.
    The report clearly stated that there are high wear metals, which are almost certainly all over the magnets now and in the filter. I personally would feel better about regular service, but Toyota doesn't want to service these.
  18. Jan 15, 2022 at 4:18 PM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    One can also drive a Tundra without an air filter upstream from the throttle body for a limited time. Whoopie!
    Chip_Tundra likes this.
  19. Jan 15, 2022 at 11:07 PM
    babyshark
    babyshark New Member
    thanks for sharing
  20. Jan 17, 2022 at 10:25 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    I would still put a cooler on mine if it didn't come with one if towing. lower temps never hurt a transmission
  21. Jan 17, 2022 at 10:29 AM
    babyshark
    Would that cause problems with warranty? Maybe install after the warranty period?
  22. Jan 17, 2022 at 10:38 AM
    Rocko9999
    Rocko9999 New Member
    You changed your oil too frequently-no warranty for you!
  23. Jan 17, 2022 at 10:40 AM
    babyshark
    Sorry, more context - I was asking about installing the oil cooler - if that would raise issues with warranty
  24. Jan 17, 2022 at 10:45 AM
    2mchfun
    Maybe, but what is better a warranty or a good tranny for the long haul? Depends on each individual case. I chose to say to hell with the warranty and some knuckleheads wrenching on my truck. Bought a service manual, have exp., tools, etc., and I will make the time if needed.
  25. Jan 18, 2022 at 3:39 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Thanks for posting, but is one data point out of thousands more needed to track transmission health and stamina.
  26. Jan 18, 2022 at 3:59 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Bro... do you even Magnussen-Moss?
    sd172, JLS in WA and GODZILLA like this.
  27. Jan 18, 2022 at 4:04 AM
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    In short, adding a cooler is very unlikely to cause any warranty issues. That's mostly irrelevant though, if you think about it.
    Let's play out the scenario if you are concerned about the potential damage that could be done to your transmission by running it hot with no cooler, in which case you want your warranty intact. But you would also want a cooler installed if you are worried about the damage. The only time being concerned with the warranty would matter would be if you believe that your driving/use of the truck will cause enough damage that it will require repairs under warranty. Factory warranty is up at 60K-70K miles, right? You are worried your transmission may fail that early because of no cooler. Let's say you are correct and it is causing that level of stress, but what if it holds out until after the warranty period? Adding a cooler then would avail you very little. The damage is done. In this scenario you are definitely better off putting a cooler in as soon as possible.
    Now for another scenario. Let's say you're in the opposite camp. You don't think you're going to crater your transmission with your level of use. These transmissions are proven, and even without a cooler they should easily make it beyond the warranty period, so why not add the cooler? Besides, if you are in the USA, there are protections to keep manufacturers from denying a warranty claim unless they can reasonably show that your modification caused the failure.
    Basically, if you are concerned enough that you feel a cooler would be of benefit, you're silly not to add it. If you aren't worried and don't plan to work the truck hard, you can trust the Tundra as it was built. Either way, don't fret about the warranty.
  28. Jan 18, 2022 at 4:14 AM
    Asimov2025
    Asimov2025 Not Sure
    North Texas
    Non-stop mods
    Didn't someone add a transmission cooler then have to remove it because of cold shifts? I thought there was a thread about it.
  29. Jan 18, 2022 at 4:37 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    @ColoradoCub
  30. Jan 18, 2022 at 4:55 AM
    Bammer
    Monroe, CT
    Well said sir. :hattip:
