2019 Sequoia TRD Sport
Discussion in 'Sequoia Builds' started by Beast-2019, Sep 27, 2019.
  1. Sep 29, 2019 at 8:08 PM
    Beast-2019
    Beast-2019 [OP] New Member
    Jesse
    Boulder, CO
    2019 sequoia trd sport
    Matte black finishes USB ports 34" A/T Nitto Terra Grappler G2
    I got the 275/65-20 Nitto Terra Grapplers. They're 34" diameter and a bit wider than the stock tires. I was able to make them run a couple of times by cranking it hard left while going over potholes. It doesnt rub to the right. Im guessing it rubbed on the front skid plate, which is less than 1/4 inch from the right tire when cranked fully to the left.
    I'm going to look into wheel spacers and/or a lift. My wife is short, and she doesn't want any more height to climb up. The wheels added an inch. So I'm going to double measure to see if 1.25" spacers will help. If the spacer wont work, I may trim the skid plate by 1/4 inch.
    Note, the speedometer is more accurate up to 55mph. Above 55mph the speedometer underestimates my speed. By 70mph on the speedometer, I'm actually going 75mph. I need to reset this, as others have described.
  2. Oct 2, 2019 at 5:32 PM
    Slobberknocker
    Slobberknocker New Member
    None so far
    How about MPG? Have you noticed a difference from the Dunlops? That’s what came with mine anyway.
  3. Oct 2, 2019 at 5:40 PM
    Beast-2019
    Jesse
    Boulder, CO
    I didn't notice any drop in MPG. But I haven't done an exact comparison. So I wouldn't notice small drop. But if there is a small drop in computed mpg, then the extra tire circumference should compensate for that.
  4. Oct 6, 2019 at 9:55 AM
    jordan0317
    jordan0317 Just hoodrat things...
    Jordan
    Martin, TN
    2017 White Tundra XP 4x4
    Damn that makes me want a sequoia
  5. Nov 18, 2019 at 3:32 PM
    Cowboys16and0
    Cowboys16and0 New Member
    Black Betty - 2019 trd sport 4x4
    Is your rtt mounted to the stock roof rack? I've got a Smitty built xl but wasn't sure if the stock rack system could handle it. It fold out.
  6. Oct 18, 2020 at 12:32 PM
    Slobberknocker
    None so far
    Can someone point me in the direction of the tire size guide for Sequoias? I’m trying to find out if 28565R20’s will fit a 2019 stock, no lift. I just saw a YouTube vid of a guy putting 28575R18’s on a Pro with no lift and they are almost exactly the same size.
    Thanks.
  7. Dec 20, 2022 at 1:56 PM
    TRD_CM
    TRD_CM New Member
    2017 Toyota Sequoia 4x4
    Hi, Random question but do you have any kind of spacer or bilstein 5100 adjustment shock on the front for the 34" tires? It sounds like you don't but just wanted to see, looking to get the same size for mine.
  8. Dec 22, 2022 at 1:18 AM
    farnsrocket
    farnsrocket New Member
    Go to Tiresize.com and use the wheel offset calculator to see the differences. Stock offset is +60 Here, I checked it out. Your tires will be 1.35" closer all around.
