2019 headlights
Discussion in 'Lighting' started by Rs551569, Mar 17, 2021.
  1. Mar 17, 2021 at 4:22 PM
    Rs551569
    Rs551569 [OP] New Member
    Russel
    2019 Black Tundra tss off road
    I’m trying to black out my 2019 Tundra tss SR5 I was looking for some guidance on what headlights give the effect I’m looking for while still being super bright. Thanks
  2. Mar 17, 2021 at 7:32 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If your SR5 still has the halogen headlights, the easiest and best performing solution for "black out" is the OEM LED headlights. This is the 2019 TRD Pro Gloss Black Housing:
    Right Hand Side
    - Headlamp Assembly Right-Hand - Toyota (81110-0C211)
    Left Hand Side
    - Headlamp Assembly Left-Hand - Toyota (81150-0C211)
    You'll need an adapter harness. PM @iHacker to order the harness according to your needs. Image and part numbers above from his thread. Headlamp housings available from any Toyota dealer or SparksParts (TUNDRADUDE34 used to be good for a big discount).
    https://www.tundras.com/threads/201...lay-harness-for-2014-2020-models-v-2-0.24416/
    Buildn and 1lowlife like this.
  3. Mar 17, 2021 at 7:36 PM
    Or Morimoto XB's
    YotaMan and Tierhog like this.
  4. Mar 17, 2021 at 8:08 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^ This...
    2014 SR5 stock.
    713A8B9C-FDF8-4EAE-B363-D750EB6E34E7_zps_db4e1bbd604b20403f3a66f6dd5e2c7271460825.jpg
    From 2015 TRD Pro halogen headlight sand grille
    94B1C49A-A66D-4F31-99DA-6BD45F492426_zps_5dc888f07f860da2fe984e76b09a2cc76552af55.jpg 8D49F331-C457-471E-8440-BA1B7F921142_zps_c1631bfce52fa157414f67803fafad3e09dbc21a.jpg
    To 2019 TRD Pro LED headlights using @iHacker harness..
    cn1kwhbh_33a1cc89f379f63fdd4854b512b276b6027ccad0.jpg 60jiy207_cb42db2dbf9863dba8e47132e1ac5406ef8e1f5a.jpg gk8itexz_05ccac5dc76dccb05e40b9a94650c436aaa00f0e.jpg 66wbr7ca_03cb95ab36d4b9fe2173b17d12c474d6696228b7.jpg
  5. Mar 17, 2021 at 8:58 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Morimoto... Blacked out like you wanted. Lots of light. Did I mention sequential turn signals? Game over.
    YotaMan likes this.
  6. Mar 25, 2021 at 11:34 AM
    dhutchijr
    dhutchijr New Member
    D
    2020 Tundra
    I bought some of those leds to go on my 2020 tundra. I guess I need the harness from @iHacker too
  7. Apr 25, 2021 at 7:12 AM
    Taco-Spike
    Two Trucks
    Just started looking into this.
    are the Tundra headlights really that much less than the Tacoma LED headlight?! $400-ish less each?
  8. Apr 25, 2021 at 7:16 AM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    Or you could use nightshades. It's essentially a light tint spray paint, use in very light multiple layers if you do. Or always tint via a vinyl wrap type of setup.
    +1 for morimotos :thumbsup:
  9. Apr 25, 2021 at 11:12 AM
    JohnLakeman
    How about $290.89 from Sparks Parts. (I think I paid over $350 each!) Be sure the TRD black version is the headlight you want, because these LED headlights also come in chrome and smoked chrome housings:
    https://www.sparksparts.com/oem-parts/toyota-headlamp-assembly-left-hand-trd-pro-811500c211
    BUT!!!...They also have free shipping over $75 if you use the promo code FREESHIP at checkout. Be advised that once you enter any other discount promo code, they will not let you back out of it for a better deal.
  10. Apr 25, 2021 at 12:05 PM
    1lowlife
    DADA
    2014 MGM DC SR5
  11. Apr 25, 2021 at 12:15 PM
    Willard
    Willard New Member
    2024 F250
    Morimotos have lots of issues, just search the forum. They are also over 2x the cost for worse high beams, and only slightly more candela on low beams. Not worth the scratch.
    1lowlife likes this.
  12. Apr 25, 2021 at 12:29 PM
    Taco-Spike
    Two Trucks
    Awesome! Thank you!
    yeah the black version is what I want.
    Just crazy because I paid just under $1400 (pair) for my taco led’s and wonder why the tundras are significantly less? Maybe the DRL’s don’t switchback as a turn could be a partial factor? Idk, seems like an awesome deal to me though. Win win
  13. Apr 25, 2021 at 12:31 PM
    Taco-Spike
    Two Trucks
    Several issues in the Tacoma version as well. The G2’s seem to be a bit better, but too new to tell longevity wise
  14. Oct 29, 2023 at 3:30 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    I have a 2017 Tundra with the 2019 TRD Pro Black Housing LED headlights using the iHacker harness.
    My DRL/turn signal amber light on my passenger side stopped working today. I'm going to upgrade to LED ambers on both sides, question is, do I need a resistor or can I just buy an LED Amber and install it?
  15. Oct 29, 2023 at 5:25 PM
    Willard
    Willard New Member
    2024 F250
    I needed resistors when I switched to vled turn signals on my 2020 with oem led headlights.
