2019 Crewmax Panel Vents
Discussion in '2.5 Gen Tundras (2014-2021)' started by secrest6, Jan 12, 2019.
  1. Jan 12, 2019 at 6:50 PM
    secrest6
    secrest6 [OP] New Member
    Russ
    2019 Whilte CrewMax TRD Offroad
    So, I pulled the trigger and purchased a 2019 Super White TRD Offroad! I LOVE it.
    I have noticed something though that has been unexpected: When the floor vents are selected for any function, I have what I consider an excessive amount of air coming from the PANEL vents! This is unlike any other vehicle I have owned - and I have had a few over the years.
    Has anyone else seen this behavior? I returned to the dealer the following day and started up an identical truck on the lot with the same behavior.
    Any thoughts??
  2. Jan 12, 2019 at 6:52 PM
    Welcome from NY.
  3. Jan 12, 2019 at 6:59 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    I’ve noticed that big time going from a Tacoma to the Tundra~ especially being in the middle of winter now. I have to point my vents up in the air or close them as I run mainly on floor or mixed and it pours out of them. There are a lot of threads on here with similar issues and strange HVAC behavior, and like you, many have returned to the dealer and received the usual, huh?, or that’s the way it’s supposed to be.....
    https://www.tundras.com/threads/lack-of-floor-heat.36851/
  4. Jan 12, 2019 at 7:05 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Turn the recirculation button on when the system is off to stop letting in outside air.
  5. Jan 12, 2019 at 7:12 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    Tried that, but even with recirculating button pressed and running the heat, you still have air getting directed to the front vents, while on full floor setting.
  6. Jan 12, 2019 at 7:33 PM
    Sas
    OKC, OK
    Hmm, you may have a problem w/your vents then. I just went for a drive to try and get them to leak w/the system off and the recirculation on. As long as I didn't turn it to defrost (which turns the recirculation off) I could put it to any setting and any temp and I never got a whisper of wind thru any of the vents.
  7. Jan 12, 2019 at 7:45 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    I think we may be talking about 2 different things. I can mimic what you’re doing by shutting everything down and not have air come through. What I think the OP and I are talking about is when you do have the fan on and you choose to direct the warm air to other locations on the dial other than the front dash vents, such as full floor mode, air still continues to come out of the front vents. Air will go to the floor, but like in my Tacoma, if you set the dial to full floor, or mixed defrost and floor, nothing would be hitting you in the face from the front vents. Does that make sense in how I’m trying to explain it?
    GODZILLA likes this.
  8. Jan 12, 2019 at 7:51 PM
    DallasTundra
    DallasTundra New Member
    2014 Tundra CrewMax SR5 4X4 5.7L Silver Sky
    2" MotoFab leveling Kit, 2Crave NX-5 wheels(5X150 +15 offset to fill in fender flares space), 275/60R20XL Nitto Terra Grappler G2 Tires, VLEDs Triton V3 Switchbacks, TRS Morimoto XB LED Fog Lights, CCI Chrome Grille, 2019 LED Headlights, Extang Solid Fold, Texas Edition, Leather, Nav, JBL, OEM Flares, Husky WeatherBeaters.
    Hmm, I just tried that in my truck and yes, floor vents come on by themselves and upper ones do not blow warm air.
  9. Jan 12, 2019 at 7:54 PM
    39 Chev
    39 Chev New Member
    2019 Cement Limited
    My new 2019 does the same thing. My 2011 did not do this as much...maybe a little bleed through the vents, but not as much. I just have the vents shut because in the winter in Minnesota, I don't want the air coming out of the vents, I need it on the floor and windshield.
    Hammy68 likes this.
  10. Jan 12, 2019 at 7:59 PM
    Sas
    OKC, OK
    I see what you're saying now. Mine don't do that. If I say floor, they blow floor. Maybe they changed something in 2018?
    Hammy68[QUOTED] likes this.
  11. Jan 12, 2019 at 10:07 PM
    CrewMaxT
    CrewMaxT New Member
    Alberta
    2018 CrewMax SR5
    My truck does the same thing, only vehicle I’ve owned that does it. Air flowing through the dash vents no matter what is selected. Thought about asking the dealer about it but I don’t want them pulling apart the dash for nothing.
    Hammy68 likes this.
  12. Jan 13, 2019 at 3:52 AM
    rsgt
    rsgt New Member
    2019 crew cab TRD sport 4x4
    all stock
    Yes common problem mine is the same way. Cold feet here in Michigan hot upper body lol
    Hammy68 likes this.
  13. Nov 11, 2019 at 11:14 AM
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    Mine does this too, and I hate having hot air blasted at my face. Any progress or resolution?
