2019 build. Will 305/65r18 leave me with regrets ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Greenmacheen, May 18, 2019.
  1. May 19, 2019 at 4:50 PM
    Okietundra
    Okietundra New Member
    OKC OK
    2025 Lunar Rock Platinum
    It is a ready lift level kit. I'll have to take some side pics. Hopefully I can this evening.
  2. May 19, 2019 at 5:25 PM
    BlackRiverGuy
    BlackRiverGuy New Member
    Chandler AZ
    2019 Tundra SR5 4x4 Offroad
    In Process ARE color matched Z type cap. Pro Comp 3/1 leveling kit. Nitto Grappler 295 70 R18's
    I also say 295/70 R18, 3" x 1" lift/level, with Cooper ST Maxx skins!
  3. May 19, 2019 at 6:29 PM
    2chains
    2chains New Member
    Southern Ablerta
    Looks great with the color matched topper! Are you able to clear your garage door? Could you post the height of your door opening?
    I'm going with the Procomp 3/1 a week this monday and it's going to very close if I can clear my garage with 295/70/18's. I want to keep the factory rims and upgrade from factory rubber.
    SiberianTundra likes this.
  4. May 20, 2019 at 1:51 PM
    BlackRiverGuy
    Chandler AZ
    The truck just clears, however I have the door adjusted to be higher than the low point of the door frame and trim work, photos attached! Opening from top of garage floor to bottom of door frame trim work is 6'-9", (6'-7" + 4" the height of tape measure - 2" the door frame and trim width).
    2chains likes this.
  5. May 20, 2019 at 1:59 PM
    Greenmacheen
    Greenmacheen [OP] New Member
    My current 5100s KO2 285/65r18. Kinda hard to pick out from stock Michelin
    2chains and Watt maker like this.
  6. May 20, 2019 at 3:00 PM
    2chains
    2chains New Member
    Southern Ablerta
    Thanks I appreciate you taking the time to provide this info...I'm at 82 1/2" to the rubber trim so it's going to fit!
    Watt maker likes this.
  7. May 20, 2019 at 3:54 PM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    Looks great. Any rubbing?
  8. May 20, 2019 at 3:59 PM
    PilotDude18
    PilotDude18 New Member
    2019 Cement SR5 TRD Off-Road
    Subbing this. I just purchased a 2019 cement SR5/TRD and definitely looking at a 3/1 level with 295’s on Methods. Have you looked at 17’s? Seems to make fitting easier with that same beefy look.
  9. May 21, 2019 at 7:45 AM
    Greenmacheen
  10. May 21, 2019 at 8:05 PM
    Okietundra
    OKC OK
    Thanks. Well I bent the skid plate up on both sides with a table mounted vice when I installed the leveling kit. The passenger side tire ended up rubbing that corner of the skid plate so I just cut it off. But that's the only place it rubbed. No cab mount chop needed.
  11. May 24, 2019 at 5:46 AM
    Kingcastle
    Kingcastle New Member
    I’m running 305/70/18, level kit and a little bit of cutting
  12. May 24, 2019 at 6:17 AM
    ktmsmitty
    ktmsmitty New Member
    Ed
    Murfreesboro, TN
    2019 Toyota Tundra SR5
    Coming REAL soon.............
    Awesome looking truck!
  13. May 24, 2019 at 7:30 AM
    2019_Sport_4×4
    2019_Sport_4×4 New Member
    Jeff
    UPSTATE South Carolina
    2019 Black Tundra Sport 4x4
    Rough Country 3" Lift 20" XD Misfits Micky Thompson Baja 305/55/20
    I have 305/55/20 on my 19 Crew Max no offset.
    TundraDude18, Newm and ktmsmitty like this.
  14. May 24, 2019 at 8:46 AM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Yeah... I'm gonna need more info on this. How much space do those front tires have?
  15. May 24, 2019 at 9:57 AM
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    2019 Tundra CM Super White
    wheels/tires suspension protection
    305 you might have to chop. It’ll be fine going straight but lock to lock is where you’ll have your problem. 295/70 is the sweet spot.
    Mine is on 18s +18 offset with icon stage 2 and cooper stt Pros
    J&ATundra, TundraDude18 and CCLJ03 like this.
  16. May 24, 2019 at 7:40 PM
    Okietundra
    OKC OK
    I'll have to take some photos with the wheels cranked but they fit. I had already taken the flaps off of the front and back of the wheel well.
  17. May 24, 2019 at 7:51 PM
    CCLJ03
    Craig
    Did you use spacers?
  18. May 24, 2019 at 7:56 PM
    Okietundra
    OKC OK
    No spacers
  19. May 24, 2019 at 8:08 PM
    #49
    CCLJ03
    Craig
    Verrrryyy interesting. I thought for sure 295 would need spacers.
    Thanks fo the info!!
  20. May 24, 2019 at 8:10 PM
    #50
    Okietundra
    OKC OK
    No problem. I do have this pic of the uca. It's close but it doesnt rub either.
    Watt maker and CCLJ03[QUOTED] like this.
  21. May 24, 2019 at 8:14 PM
    #51
    CCLJ03
    Craig
    That’s a great shot. Part of me wonders if you were really romping if it would clip that? How flush are the tires to the fenders without the spacers? I’m guessing pretty close to flush.
    If I did this I would probably add small spacers but I don’t want the tires to stick out more than just a little past the fender. Not a big fan of kicking up rocks against my door. Haha
  22. May 24, 2019 at 8:22 PM
    #52
    Okietundra
    OKC OK
    Mmmm... idk. The only way it might would be if the wheel was at full extension. But I still dont think mine would touch. I'll have to take some side pics to show you how flush the tires are. They almost stick out a little already so even small spaces would probably cause some crap to sling up the side of your truck. Could always just add some fender flares to help with that.
  23. May 24, 2019 at 9:49 PM
    #53
    CCLJ03
    Craig
    You’re probably right. As long as its not rubbing I would probably be fine. Thanks for the side pics ahead of time!
  24. May 25, 2019 at 8:43 AM
    #54
    Taofouajarodeve
    Taofouajarodeve New Member
    Tao
    2021 Voo Doo Blue Crewmax
    None
    285/70/17 TRD 9B299405-444F-4FBE-9E7A-1E9E7628DF97.jpg rock warrior wheels bone stock.
  25. May 25, 2019 at 9:06 AM
    #55
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
  26. May 27, 2019 at 9:43 AM
    #56
    Okietundra
    OKC OK
  27. May 27, 2019 at 3:18 PM
    #57
    CCLJ03
    Craig
    Oh god. These pictures for sure cost me some near-future money.
    Thank you!
    Truck is en fuego.
  28. May 27, 2019 at 3:27 PM
    #58
    Okietundra
    OKC OK
    Haha thank you sir
  29. May 27, 2019 at 5:14 PM
    #59
    2chains
    2chains New Member
    Southern Ablerta
    Nice stance!
    Okietundra likes this.
  30. May 27, 2019 at 6:58 PM
    #60
    cforman61
    cforman61 Pupper
    Chuck
    Highlands Ranch, Colorado
    2019 Tundra SR5 TRD CrewMax
    Looks great! What did you do lift wise?
