2019 2020 transmission cooler missing
Discussion in '2.5 Gen Tundras (2014-2021)' started by sgtfluffy16, Aug 10, 2020.
Thread Status:
Not open for further replies.
  1. Aug 13, 2020 at 4:33 AM
    #241
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    One interesting thing is I have not seen anyone on here who was able to get a dealer to install a trans cooler on these newer tundras. They claim it already has one with the whole warmer/cooler puck
  2. Aug 13, 2020 at 5:26 AM
    #242
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    what was the exact overhear condition you observed?? I read and re-read the posts and you point to DTC P0711 which the description states is a malfunction in the sensor - not an actual condition of overheating.
    What did I miss? I saw your elevated tranny temps - is that what you’re referring to as an overheating condition?
    Cpl_Punishment likes this.
  3. Aug 13, 2020 at 5:50 AM
    #243
    blanchard7684
    blanchard7684 New Member
    If you compare the following SDS sheets from Mobil, you'll see that WS fluid is very much in the synthetic realm. In fact it has better base stocks than Mobil's own marketed synthetic ATF:
    Mobil atf
    Mobil 3324
    Mobil synthetic
    Mobil Dexron VI
    https://www.mobil.com/en/lubricants/for-personal-vehicles/our-products/products/mobil-type-f-atf/
    https://www.mobil.com/en/lubricants.../our-products/products/mobil-1-synthetic-atf/
    https://www.mobil.com/en/lubricants/for-personal-vehicles/our-products/products/mobil-atf-3309/
    https://cdn.website-editor.net/6622da50fd3744b3b1560a41005a6921/files/uploaded/00289-ATFWS.pdf
    https://www.mobil.com/en/lubricants/for-personal-vehicles/our-products/products/mobil-dexron-vi-atf/
    All these have flash points well into the 300F range, even the conventional, non synthetic ATF.
    You have to realize also that WS is protected by trade secret. So what is reported on the SDS is only part of the story. They are only listing what the have to based on known hazards they have to report based on HAZCOM law. If you add up the different composition percentages on all the SDS it doesn't add up to 100 and also on some goes over 100.
    Mobil looks to be making the WS fluid based on their 3324 ATF. The composition there is listed to show an intentionally vague description. The composition lists the chemical process more than anything. And those processes are typical for synthetic oil manufacturing.
    In fact WS and 3324 have better base stocks than anything else in Mobil's fleet.
    This fluid is FAR from garbage and FAR from a conventional ATF with a temp limit of 175F shown in the charts thrown all over the internet.
  4. Aug 13, 2020 at 7:49 AM
    #244
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Sounds you are the one lacking research on what will or will not void your warranty . by law Toyota would have to prove that the cooler you installed was the direct cause of what ever failure you experience . Like i said before , pick your battles . its not worth it . between this thread and the responses from Toyota you are bound to be made out to look like a joke ... if that hasn't happened already !
    Ruggybuggy and Bammer like this.
  5. Aug 13, 2020 at 8:15 AM
    #245
    jordoncloutier
    Jordon
    Alberta , Canada
    As per Hayden's installation instructions , you can have the inlet/outlet up , down or sideways . it does NOT matter .. Besides most OEM coolers found on other vehicles have the ports at the bottom .. Anyone who knows transmissions will tell you that line pressure will overcome any kind of air pocket or bubble .. transmissions are not sealed , they breathe like differentials and air is able to escape through the breather.
  6. Aug 13, 2020 at 8:15 AM
    #246
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Oh Toyota has already passed all the emails around and made memes about it I’m sure
  7. Aug 13, 2020 at 8:23 AM
    #247
    Wallygator
    Not going to call. Bought a cooler kit off of @chasenicholas93 . Quicker and easier to just do it and get it over with vs trying to convince a billion dollar world wide company to do the right thing. Besides if they did start putting coolers on again the bean counter that got a pat on the back for eliminating it would have to give his/her bonus or raise back. We wouldn't want to take food out of anyones mouth here especially Toyotas, so just put a cooler in if you feel it is necessary....I do.
    Ruggybuggy, Brlowe and jordoncloutier like this.
  8. Aug 13, 2020 at 11:25 AM
    #248
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Unfortunately, I don't feel comfortable contacting Toyota and telling them sgtfluffy16 said my transmission is overheating and demanding them to fix it immediately.
    As soon as I have evidence of some kind that there is a problem with my transmission, I promise to join your cause.
  9. Aug 13, 2020 at 11:35 AM
    #249
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I stand corrected on what manufacturers recommend. Not knowing anything about transmission line pressure and flow rate, my practice would be to err on the side of guaranteed results.
  10. Aug 13, 2020 at 11:44 AM
    #250
    Clemsonman14
    Same here. Outside of a few people reporting the high temp light we have seen nothing to indicate that this will be a giant issue for the majority of 19 and 20 tundra owners.
    Additionally, arent the old 4.6’s running without a cooler as well?
  11. Aug 13, 2020 at 11:57 AM
    #251
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Everyone is free to handle this situation as they see fit. If you want to worry about it, go for it. If you want to add a cooler, have at it. I’m not going to worry about it. I drive my truck hard and will continue to do so. If the transmission explodes, I have a lifetime power train warranty. They’ll put another one in and I’ll go right back to driving the crap out of it. Have a nice day.
  12. Aug 13, 2020 at 12:09 PM
    #252
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    If mine blows up, I'm going to buy something with more payload, storage under the back seats and a more logical centre console that can play my iPod.
  13. Aug 13, 2020 at 12:16 PM
    #253
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    ....and spend more time getting warranty work done. That unfortunately is the trade off. If the domestics could build something as reliable as the Tundra I would be next in line to buy one.
  14. Aug 13, 2020 at 12:19 PM
    #254
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I think the new Tundra coming out next year will probably meet his requirements.
  15. Aug 13, 2020 at 12:21 PM
    #255
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Yeah, that's the unfortunate reality. I don't think there's a perfect truck on the market right now. The other possibility is that the new Tundra blows everyone else out of the water on every front again like it did in 2007.
    My brother and my boss both have 2019 Sierras so I will also keep an eye on how they perform.
  16. Aug 13, 2020 at 12:21 PM
    #256
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    :fingerscrossed:
    tttrdpro[QUOTED] and Ruggybuggy like this.
  17. Aug 13, 2020 at 12:26 PM
    #257
    JohnLakeman
    Since 2010, 4.6L with the tow package had the warmer/cooler plus an external cooler in the AC condenser up until 2013. No tow package and no external cooler on 4.6L after 2013.
  18. Aug 13, 2020 at 12:29 PM
    #258
    Melikeymy beer
    Muscogee Nation
    Right? Although, after the efforts to get all the rattles fixed, I hope it lasts for awhile. Now if I can just get these damn front tires to quit shaking, lol.
  19. Aug 13, 2020 at 12:30 PM
    #259
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    I don't plan to throw a big fuss over this.
    Toyota obviously feels it was OK to eliminate the additional cooler and use the coolant/puck exclusively. This is exactly how most passenger car and light truck transmissions were cooled for generations. The ATF was plumbed to a heat exchanger in one of the radiator end tanks. If you wanted extra trans cooling for towing/racing/whatever... you added a front mounted cooler and plumbed it in series AFTER the radiator tank for additional trans cooling capability.
    This is 'kinda how I see the Pre-2018's were done. They had both engine coolant AND aux coolers being used.
    I still think it's good practice to add the front mounted trans cooler if you plan to tow or run hard in hot climates.
    The trans fluid may be perfectly capable of handling the excessive temperatures without the front mounted cooler... but I don't want to be that guy taking the chance and possibly reducing the overall life of the transmission.
    Running the extra trans cooler is a "nothing to lose, everything to gain" situation... whereas it's otherwise a crapshoot to run/tow without it... but for the average pavement princess that never pulls a trailer... it probably wont ever be an issue.
  20. Aug 13, 2020 at 12:35 PM
    #260
    Melikeymy beer
    Muscogee Nation
    Well, nothing to lose but the cost of the cooler install, right?
    I tow a TT, but my truck will probably have max 50k miles before the transmission warranty ends or I sell it, whichever comes first.
  21. Aug 13, 2020 at 12:38 PM
    #261
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    I guess that depends where you place the value of your money.
    Personally I think the cooler upgrade is small change and easy peasy install.
    Much easier and cheaper than smoking a trans outside of the warranty period... while pulling a trailer... 2000 miles away from home. ;)
  22. Aug 13, 2020 at 12:47 PM
    #262
    Melikeymy beer
    Muscogee Nation
    I won't own it outside the warranty period. This truck has already been in the shop for repairs more times in the first year than my previous two Tacomas were in the last 16 years.
  23. Aug 13, 2020 at 1:03 PM
    #263
    18" TRD Off Road Wheels
    Damn. That sucks.
  24. Aug 13, 2020 at 1:07 PM
    #264
    Pappion
    Pappion New Member
    Currently driving a 2016 4Runner which I bought new. Priors: RAV4, Saturn, Camry etc..
    Need more towing power for new TT. Not sure what to buy now. Maybe used 2018 Tundra.
  25. Aug 13, 2020 at 1:12 PM
    #265
    How big a trailer are you gunning for? Even if you put a cooler in or get an older truck that had one, you still have limited payload on the Tundra. You can go over it, and the truck will do it, but you wind up in questionable liability territory if you do.
  26. Aug 13, 2020 at 1:12 PM
    #266
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Your the exception. My 2020 Tundra has been flawless but my 2018 Tacoma had some issues. Even still, compared to the domestics it's been a treat.
  27. Aug 13, 2020 at 1:15 PM
    #267
    Melikeymy beer
    Muscogee Nation
    Well, to be fair to the Tundra, my Tacomas were in the shop 1 time between the two. Zero for my 2004 in 12 years, and once for the 2016 in 4 years.
  28. Aug 13, 2020 at 1:17 PM
    #268
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    You can buy whatever you choose, but is any other 1/2 ton truck more power reliable than a Tundra? The others have transmission issues as well as other known problems. It’s your money, buy whatever you’re comfortable with.
  29. Aug 13, 2020 at 1:18 PM
    #269
    Clemsonman14
    Agreed. Couldn’t be happier with the “outdated” Tundra after owning a 2018 Silverado where everything on the interior rattled and the transmission shifted like a drunk monkey trying to drive a stick
  30. Aug 13, 2020 at 1:20 PM
    #270
    blanchard7684
    Here is another thing to consider in evaluating this issue...
    Toyota may have been testing this change for many years, even while the current production trucks were fitted with a transmission cooler. I don't think anyone just woke up in the morning and said "screw it...I'm gonna ditch the cooler." I also don't think this was something tested only over a few days.
    OEMs have a huge number of permutations they test and evaluate prior to going to production. Some tests take years. The trucks and cars you see on a dealership lot are actually 4-5 years old in the eyes of the manufacturer.
    It may actually be the case that the WS fluid can not only withstand the heat but so can the transmission.
    I think there is a non-trivial amount of bias based on perceptions and expectations. I admit I'm one. I'd like something to manage the thermal stresses on my transmission. However if the transmission and fluid can deal with it, then ok.
    I worked for a company that tested OEM brake systems for company and gov't certifications. We had fleets of trucks that were outfitted differently between tires, rotors, pads, calipers, brackets, bearing hubs, and even brake fluids. My God...the tire permutations...Then they were loaded up at discrete loads up to max load. Then we tested in dirt, sand, mud, snow, rain, hot weather and cold weather.
    We primarily tested Ford, Dodge, and GM half ton and 3/4 ton trucks.
    We got a 1st gen Highlander. It was the companies first Toyota. We were excited.
    More than half way (as I recall as I was putting on the front brake systems) through the vehicle system build, they yanked the fleet.
    Toyota audited us.
    They personally sent a small group of people to install the original brake configuration, install the wheels, and remove vehicles.
    We were told via letter a week later that our processes' were unacceptably undisciplined and Toyota could not trust the results. No more Toyotas for us.
    That experience very much informed my perceptions about Toyota for the better.
    betotundra, SomeGuy4, Bammer and 4 others like this.
Thread Status:
