2019 2020 transmission cooler missing
Discussion in '2.5 Gen Tundras (2014-2021)' started by sgtfluffy16, Aug 10, 2020.
Thread Status:
Not open for further replies.
  1. Aug 20, 2020 at 10:26 AM
    #811
    Redcon41318
    Redcon41318 New Member
    I just spoke to my
    Local toyota ship, estimated $700-900 with parts and labor. But the cooler will void warranty, so not for
    Me maybe until warranty ends or heck a F250 gas will fix it.
    Melikeymy beer likes this.
  2. Aug 20, 2020 at 10:36 AM
    #812
    drowhawk
    drowhawk New Member
    '19 Tundra SR5
    A cooler will not void your warranty unless it is the direct cause of a failure.
  3. Aug 20, 2020 at 10:41 AM
    #813
    Redcon41318
    Really prove it?!
  4. Aug 20, 2020 at 10:42 AM
    #814
    timsp8
    NY
    Or take it off before you take your truck in. More work but piece of mind. I bet most dealers won’t even notice its there since some have said they called the dealer about it s removal and they didn’t know it was removed.
    sask3m likes this.
  5. Aug 20, 2020 at 10:44 AM
    #815
    Redcon41318
  6. Aug 20, 2020 at 10:58 AM
    #816
    JWB
    JWB New Member
    2020 Tundra Limited TRD Off Rd
    TRD Exaust, Scanguage II, Tundra inserts for Tundra under radio, Husky X-Act w/Red Tundra inderts,TRD oil cap and Grey/Tundra center console insert
    Can't tell you who I spoke with but I assure you this person knows.
    Change in condenser cooling: "The change to R1234yf is a government mandate and the compressor and condenser were changed to meet the new refrigerant. With that said, we have the same standards/cooling requirements for ATF with or without cooler. We have margin to our standards and the Powertrain calibration change reduced busy shift and temperatures. So the cooler was not providing the benefit and created other issues, thus we removed it."
    Adding a hayden external cooler with OEM thermostat: "What you will see is that the AT temp will drop around 10-12 degrees but the engine temp will rise 5-10 degrees. This is the trade off. Engine performance will be reduced due to higher block temp. The changed in the the engine calibration and shift mapping to improve performance and busy shift for 19 & 20 MY. This reduced trans temp and eliminated the trans cooler need. The trans cooler elimination reduced engine temp which improves thermo cycle efficiency. As is said earlier, I wish I share data but this is our IP.
    SSPey, AZ_Tundra1, betotundra and 6 others like this.
  7. Aug 20, 2020 at 11:05 AM
    #817
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I gather that english is not that individuals native tongue.
    Japanese, perhaps?
  8. Aug 20, 2020 at 11:27 AM
    #818
    JWB
    JWB New Member
    Not Japanese. The one person who designed the truck.
    ryanwgregg likes this.
  9. Aug 20, 2020 at 11:28 AM
    #819
    18" TRD Off Road Wheels
  10. Aug 20, 2020 at 11:35 AM
    #820
    Fearthisbeard
    Fearthisbeard New Member
    Gilbert AZ
    2019 - 1794 TRD Offroad
    You mean to tell me they did proper research and engineering instead of just ripping to cooler out and going with "well it should still be good". I'm shocked I tell you, shocked.
    ‘19pro, Bammer, AZ_Tundra1 and 7 others like this.
  11. Aug 20, 2020 at 11:40 AM
    #821
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    It's written better than my owner's manual is...
  12. Aug 20, 2020 at 11:45 AM
    #822
    JWB
    JWB New Member
    I didn't change his response because I wanted it to be what he actually provided. I am still adding the OEM thermostat, OEM hard lines and Hayden 778. BG Products also makes a plate to exchange fluid on 19 and 20s. You pull off the warmer and add the plate that has two nipples that line up with the two holes in the trans to exchange. I will post a pic when I get to my phone.
  13. Aug 20, 2020 at 12:08 PM
    #823
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I wondering why he thinks the aux cooler would raise engine temps and reduce performance.
    JohnLakeman and sgtfluffy16[OP] like this.
  14. Aug 20, 2020 at 12:36 PM
    #824
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    I'm not an engineer, but my guess is the external cooler would mount in front of the radiator, and extra heat coming from trans cooler through radiator would reduce the engine cooling efficiency of the radiator by enough to see a 5 - 10° temp increase in the engine?
    Jtundra81 and Cpl_Punishment like this.
  15. Aug 20, 2020 at 12:47 PM
    #825
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Trans coolers have been placed in front of radiators for decades. It doesn’t cover much of it at all
  16. Aug 20, 2020 at 12:52 PM
    #826
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    My trans temps didn't drop 10 degrees they dropped 30-40. Also my engine temps never changed.
  17. Aug 20, 2020 at 12:56 PM
    #827
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Yup, even 07-10's had an external in front of the condensor and rad.
    sgtfluffy16[OP] likes this.
  18. Aug 20, 2020 at 1:03 PM
    #828
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That heat from the transmission has to go somewhere and using the puck dumps it directly into the cooling system. Since installing my aux cooler I haven't seen any rise in the engine operating temperature.
  19. Aug 20, 2020 at 1:05 PM
    #829
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    mine does indeed
    sask3m[QUOTED] likes this.
  20. Aug 20, 2020 at 1:08 PM
    #830
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I had an 08 with the cooler and towed 6000lb trailer with it for 7 yrs, had around 120,000 miles when I traded and the trans was still smooth as could be.
    pickeledpigsfeet likes this.
  21. Aug 20, 2020 at 1:49 PM
    #831
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    My Hayden cooler reduced pan temps 30F, much more than 10F.
    How does the transmission temperature being Lower affect the engine temperature Controlled by the thermostat?
    My engine temperature before and after adding the cooler was 196-198F no change. Same 80-85F ambient temps.
    My 2010 DC ran around 200 pan temp, my 2020 CM runs 217F no load summer ambient temps in the 80s. How is that the same or cooler?
    I’m sharing my data, funny they won’t share theirs (whoever that is).
    pickeledpigsfeet and GODZILLA like this.
  22. Aug 20, 2020 at 1:52 PM
    #832
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    New.
  23. Aug 20, 2020 at 2:01 PM
    #833
    sgtfluffy16
    sgtfluffy16 [OP] New Member
    Corey
    2019 Super White Tunda TRDPro
    Stock
    Magnuson-Moss act. Google it! They would have to directly prove that the part that you installed caused the failure
  24. Aug 20, 2020 at 2:36 PM
    #834
    Redcon41318
    Is it true thats theres
    No oem tranny cooler for the 19-20’ tundras?
  25. Aug 20, 2020 at 2:40 PM
    #835
    sgtfluffy16
    Corey
    Stock
    The fact that you even asked that in this post is redundant. READ THE THREAD! READ all the threads on this concern!
    Cpl_Punishment and Ruggybuggy like this.
  26. Aug 20, 2020 at 2:44 PM
    #836
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Help me out, plz.
    Let's say a person, SexyTundraGal, has a 2019 TRD PRO, in blue, and adds a ATF cooler. SexyTundraGal's transmission smokes a clutch pack at 25K miles. SexyTundraGal tows her truckee to the dealer for a warranty claim.
    SexyTundraGal: mah truckee broke after I dropped of one of mah boyfriends. Tranny let go and I gots all the warning lights on mah instreement clusters!
    FriendlyNeighborhoodTyotaService: Not a problem, miss. You're still within your warranty period and we take care of everything.
    SexyTundraGal: my period?! We ain't got time fer that sh*t! Mah truckee is broken! Besides, my period dont come fer another 2 weeks (wink wink).
    FriendlyNeighborhoodTyotaService: no, miss... we were referring to the time component of your warranty. And we think you are quite fetching.
    *transmission tech completes diagnostic and begins removal of defective transmission... discovers addition of external supplemental heat exchanger. service manager calls Tyota and describes their findings. Tyota disqualifies the claim.
    SexyTundraGal: got mah truckee done yet?
    FriendlyNeighborhoodTyotaService: ah, yes... aboot that (he's canadian). We found an unsupported element in the hydraulic circuit of your transmission. Tyota denied your warranty claim.
    SexyTundraGal: I'm sorry, I believe I have something crazy in my ear. Come again?
    FriendlyNeighborhoodTyotaService: they sez "hell naw!" You or somebody else altered the system. No dice.
    SexyTundraGal: thought you might say that. (she puts on a fancy robe and hat you would find on a wizard) she raises her supple arms with a flourish and cries, "I summon all my mana and cast Magnuson-Moss, level 4!!"
    FriendlyNeighborhoodTyotaService: (startled and bewildered, looks around) what are you going on aboot? (canadian)
    SexyTundraGal: you hafta prove my Hayden caused that clutch pack to burn up! FIX TEH TRANNY, PLZ!!
    FriendlyNeighborhoodTyotaService: I say you they sez nuh-uh.
    SexyTundraGal: You fix! NOW!!
    FriendlyNeighborhoodTyotaService: Absolutely, miss! Remit all teh moneys, plz. We fix.
    Okay. How does this story finish? Yinz guys help, plz.
  27. Aug 20, 2020 at 2:46 PM
    #837
    timsp8
    NY
    I heard they changed the engine calibration and shift mapping to improve performance, thus there is no need for a cooler.
  28. Aug 20, 2020 at 2:50 PM
    #838
    timsp8
    NY
    AZ_Tundra1, 14burrito and glowblue like this.
  29. Aug 20, 2020 at 2:52 PM
    #839
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    They didn't change it enough.
  30. Aug 20, 2020 at 3:05 PM
    #840
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    That’s a really good story and link. A good point to remember: big corporations (like Toyota) Have an army of lawyers on staff that do this for a living. If want to spend the time and money battling in court that’s up to you.
Thread Status:
