2019 2020 transmission cooler missing
Discussion in '2.5 Gen Tundras (2014-2021)' started by sgtfluffy16, Aug 10, 2020.
Thread Status:
Not open for further replies.
  1. Aug 19, 2020 at 5:47 AM
    #781
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Having an inefficient cooler has to be more effective than no cooler at all.
    GODZILLA, Bammer and glowblue like this.
  2. Aug 19, 2020 at 11:00 AM
    #782
    jetfishn
    jetfishn New Member
    Dave
    The fix was way cheaper for Toyota if they would just have done it correctly. An aux cooler stand alone is much cheaper than the condensor w/cooler they removed. Rather than cheaping out totally with nothing instead. There is no excuse for these hot temps over 221 F which is the manufactures spec for the trans. It will come back to bite them it will just take time.
    sgtfluffy16[OP] likes this.
  3. Aug 19, 2020 at 11:48 AM
    #783
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Where does the 221°F for the transmission temperature spec come from? Where is it documented that is the spec?
    GODZILLA, tttrdpro and Cpl_Punishment like this.
  4. Aug 19, 2020 at 12:04 PM
    #784
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    There isn't. It's a number that the OP stated that wasn't correct and people just keep repeating it.
  5. Aug 19, 2020 at 12:11 PM
    #785
    BentJr
    BentJr New Member
    Ben
    2019 Tundra Crewmax Limited Cement 4x4
    I have a 2019 Limited and have recently been doing mods and trying to stay up on todays things with these trucks. Coming from a racing background different oils have different boiling points, breakdown points etc. If you are that worried about it currently, you could always switch to a superior oil. A lot of these companies offer great deals of info if you talk to the tech departments.
    Here is a link to amsoil which makes a really good product and is tested to 300+ degrees Fahrenheit.
    https://www.amsoil.com/newsstand/au...ticles/protection-in-extreme-heat-conditions/
    FrenchToasty likes this.
  6. Aug 19, 2020 at 12:27 PM
    #786
    sgtfluffy16
    sgtfluffy16 [OP] New Member
    Corey
    2019 Super White Tunda TRDPro
    Stock
    There are absolutely no temperature specifications published anywhere. That is what I am still trying to get on a daily basis from Toyota. The only thing that I have confirmed is that the truck should throw a p0711 check engine light when the ATF reaches 221 degrees. Which is for high temperatures
  7. Aug 19, 2020 at 12:28 PM
    #787
    sgtfluffy16
    Corey
    Stock
    You, however might be right. But I have already called Amsoil to try and find out some information on there WS approved ATF fluid. They would not tell me technical specifications of fluid temperatures. Because that is all proprietary information
  8. Aug 19, 2020 at 12:29 PM
    #788
    glowblue
    VA
    It was somewhat a rhetorical question. The 221°F came from DTC P0711 which is for a transmission temperature sensor failure.
    ryanwgregg and ColoradoTJ like this.
  9. Aug 19, 2020 at 12:31 PM
    #789
    glowblue
    VA
    Wrong. According to TIS, P0711 indicates a problem with the ATF temperature sensor and the sensor is defective.
    Edit: my transmission temps have been as high as 230-235°F driving normally unloaded, and I’ve never had a P0711 code thrown. Your spreading misinformation that leads people to make incorrect conclusions.
  10. Aug 19, 2020 at 12:37 PM
    #790
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    What are you using to get this readout on your tablet?
  11. Aug 19, 2020 at 12:52 PM
    #791
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The metric system is way too logical and practical. Canada should just swap to our more inefficient system so there's no more confusion.
    Sumo91, ColoradoTJ, hagrid and 3 others like this.
  12. Aug 19, 2020 at 2:06 PM
    #792
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Nope, there is no code set for a 221f temperature.
    glowblue likes this.
  13. Aug 19, 2020 at 2:09 PM
    #793
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Correct. Certain conditions have to be met and the ecm is seeing a constant 221F which will tell the ecu module that the sensor is in error. Has nothing to do with the WS temp.
  14. Aug 19, 2020 at 5:25 PM
    #794
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Just for informational purposes...
    I got the OBD bluetooth adapter today and here are the trans temp results:
    First is just sitting in driveway at idle. Engine warm, no load.
    Second is after about 20 minutes of driving... mix of back roads and stop/go traffic.
    No trailers, no aggressive driving.
    Bone stock 2020 Crewmax with 35" tires.
    GODZILLA, EDDO and glowblue like this.
  15. Aug 19, 2020 at 5:31 PM
    #795
    glowblue
    VA
    ....And you didn’t get a P0711 DTC!
    GODZILLA and Ruggybuggy like this.
  16. Aug 19, 2020 at 5:40 PM
    #796
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    NOPE. :thumbsup:
    Typically Id like to see the trans temp closer to engine coolant temp though.
    GODZILLA and glowblue[QUOTED] like this.
  17. Aug 19, 2020 at 5:44 PM
    #797
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    217F is where mine was last time I did a running check with no load and no cooler. 186F with the cooler so it's doing the job. all in low to mid 80s ambient temps. You should thaw out your engine oil before driving I'd be concerned about that. :rofl:
    jetfishn and sgtfluffy16[OP] like this.
  18. Aug 19, 2020 at 5:52 PM
    #798
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Lol... yeah I was trying PIDs that apparently dont work.
    rebmo[QUOTED] likes this.
  19. Aug 19, 2020 at 5:56 PM
    #799
    FarmerDan1008
    FarmerDan1008 New Member
    Danny
    2020 Limited TRD OR 4x4 Crewmax
    took the words out of my mouth
  20. Aug 19, 2020 at 5:57 PM
    #800
    Kanobi13
    Kanobi13 New Member
    Lol bone stock 35s
    GODZILLA likes this.
  21. Aug 19, 2020 at 6:07 PM
    #801
    FarmerDan1008
    Danny
    well said sir WELL FUCKING SAID
    tttrdpro[QUOTED] likes this.
  22. Aug 19, 2020 at 6:11 PM
    #802
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Hell , look at all the complaints on the 8 speed GM transmissions , I will take the AISIN transmission anyday cooler or not
  23. Aug 19, 2020 at 6:34 PM
    #803
    AZ_Tundra1
    AZ_Tundra1 Gold member
    Phoenix, AZ
    2020 White Tundra SR5
    Bilstien 6112 front shocks set at 1.9"
    It's hot here in Phoenix!
    Melikeymy beer likes this.
  24. Aug 19, 2020 at 6:36 PM
    #804
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I think you might have the wrong PIDs.
  25. Aug 19, 2020 at 6:38 PM
    #805
    Jtundra81
    Joe
    I can roast a chicken on your pan
    co2owen and Ruggybuggy like this.
  26. Aug 19, 2020 at 6:48 PM
    #806
    glowblue
    VA
  27. Aug 19, 2020 at 7:19 PM
    #807
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    I'm with Toyota customer service. This is completely within specs. Nothing to see here. Move along everyone.
  28. Aug 20, 2020 at 7:34 AM
    #808
    co2owen
    co2owen New Member
    VA
    2020 Cement Limited CM TRD Off-Road
    Trans Cooler. 5100's up front at mid-setting. ESP Plastic Storage.
    Just went 200 miles with two adults, two kids, and approx. 500lbs in bed. Max temp I saw was 213 degrees while sitting at stoplights. While cruising in D, without tow haul, I saw between 195 and 201. 78 degrees and sunny. 4E697778-4859-484F-A24E-05C26FE3443C.jpg
  29. Aug 20, 2020 at 7:52 AM
    #809
    Redcon41318
    Redcon41318 New Member
    I talked to my trusted toyota tech who is also a good comrade of mine. His personal opinion is if you really want to install a cooler “go ahead,” he also stated he hasnt seen and tranny failures on tundras and feels a cooler isn’t necessary.
    with that ill probably look into a quote since ill get a deal.
    ryanwgregg likes this.
  30. Aug 20, 2020 at 8:48 AM
    #810
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Tow heavy and often, challenging off road - cooler needed
    Normal use, occasional haul/tow - no cooler needed.
    It's really that simple.
Thread Status:
